    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7
    Scheduled Pinned Locked Moved Suunto 7
    1.1k Posts 110 Posters 483.7k Views 99 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Fly RivieraF Offline
      Fly Riviera
      How to see Heart Rate directly on screen without doing any exersise? That would be great.
      How can I add BLE sensors to register activities like “Indoor cycling”, for example? You can do that on Suunto 9 easily, but it is impossible on Suunto 7. If the problem is battery… at least give the opportunity to users to get all sportwatch experience as possible (like a HR band as well for swimming or cycling)
      I think google Fit is not the solution. If someone buys a Suunto 7 is to get as much data you can get from the Suunto App, and depend as less as possible from google Apps, specially if you have an iPhone. (ok, if you use Android, none of this matters…)
      I’ve tested Suunto 9 and 7, and honestly, for UX and resources, I’d choose Suunto 9. Easier to use, WYSIWYG.
      pilleusP Jamie BGJ 2 Replies Last reply Reply Quote 0
      • pilleusP Offline
        pilleus @Fly Riviera
        @Fly-Riviera said in Suunto 7:
        As complication in a watchface? 😎
        https://www.instagram.com/moves.are.life/
        Suunto Vertical Black Lime
        Suunto 9 Peak Pro Black
        Suunto Spartan Ultra Stealth Titanium
        • Jamie BGJ Offline
          Jamie BG Bronze Member @Fly Riviera
          @Fly-Riviera As pilleus stated use a watch face complication and or use the HR tile.
          If you are running 24/7Hr monitoring both will update when a reading is taken, otherwise you can press on the complication (watch face dependant) and or tile and take a manual reading.
          For 24/7 HR reading - go into google fit, settings - HR - and switch on background HR.
          • pilleusP Offline
            pilleus
            Here a Suunto watch face, called Original.
            Fabio D'AllevaF 1 Reply Last reply Reply Quote 1
              Fly Riviera
              thank you! I guess we need to touch more all those settings!
              today I’m wondering if Suunto App has something similar like emergency contact and livetrack on Garmin, or beacon on Strava.
              1 Reply Last reply Reply Quote 3
              • SteffS Offline
                Steff
                Hi,
                I’m thinking of buying a Suunto 7 and I have some questions:
                1. The longest activities that I will do will be 10 hours hikes where I will also bring my phone.
                  Because the trails usually have many turns, using good GPS mode is not an option.
                  Will the watch last for 10 hours with best GPS mode, AOD off, and a map loaded with checking the map 1-2 times per hour ?
                  Will the fact that it will be connected to the phone help ? I know that is sharing the phone GPS and I’m thinking that it should help the battery life, but I saw on the forum that users experienced lower battery life when connected to the phone.
                2. I also do several runs per week and I’m interested in improved recovery times, similar with what Garmin recently introduced, where they also use the sleep and daily activities for recovery times and vo2max. I know that improved recovery times might be a long stretch for Suunto considering that they don’t even have native sleep tracking but vo2max should not be something complicated because even 50$ fitness bands have it.
                  Are there any plans for sleep tracking and improved recovery times in the future firmware updates ?
                3. If I will use 3rd party apps for sleep tracking (like Sleep as android), which sync with Google Fit, will this data be transferred into the Suunto app ? If not, are there any plans for this in the future updates?
                Thanks
                • Brad_OlwinB Offline
                  Brad_Olwin Moderator @Steff
                  @Steff said in Suunto 7:
                  Hi,
                  Thanks
                  1. Good GPS mode is an option, it does not matter if there are a lot of turns, FusedTrack is an algorithm that uses all the sensors to determine where you have been, it works amazingly well on tight turns. It is not simply a 10s GPS fix. This will give you ~16h of battery run time or longer. Connection to a phone does not matter, in fact, you will get better battery life with the watch in airplane mode.
                  2. and 3. Those here that know what is coming will not tell you because of NDAs, so these questions about future firmware updates cannot be answered. I can say there will be future firmware updates as S7 development is ongoing. The watch will give you a recovery time but no VO2Max. Google Fit is integrated and you can get data from that. Search for sleeping apps, they are available.
                  Vector/T6c/Vertical 2 Ti
                  • SteffS Offline
                    Steff
                    Thank you for the answers.
                    1. I will definitely try good gps mode, but just in case I will not be satisfied with the accuracy, how many hours should I expect from best gps mode in those conditions (AOD off, loaded map with 1-2 checks per hour) ?
                    2. and 3. Understood. Just one question. Is the sleep data transferred from Google Fit to Suunto app?
                    • Fabio D'AllevaF Offline
                      Fabio D'Alleva @pilleus
                      @pilleus strange I do not have the HR complication? Did you have to install it from the play store?
                      pilleusP 1 Reply Last reply Reply Quote 0
                      • pilleusP Offline
                        pilleus @Fabio D'Alleva
                        @Fabio-D-Alleva install Heart Trace 2 from the PlayStore and it should be available. 👍
                        Fabio D'AllevaF 1 Reply Last reply Reply Quote 0
                          @pilleus thanks that did it👍
                          • pilleusP Offline
                            @Fabio-D-Alleva said in Suunto 7:
                            Deactivate 24/7 in Google Fit and use heart trace 2 with the option to sync to Google Fit.
                              @Steff No, sleep is not transferred to SA, but this is a highly requested feature from users. I imagine Suunto is working on some sort of solution.
                              My longest in best GPS is 7-9h and in good gps 16-20h, it is difficult to tell the tracks apart.
                              1 Reply Last reply Reply Quote 4
                              • olymayO Offline
                                olymay Gold Members
                                @Steff just add to what @Brad_Olwin has already mentioned about Good GPS, I did a two hour walk today, through some twisty residential streets and some open fields, all while using Good (10s) GPS. The track was SPOT ON!! This was my first time using Good GPS and I am amazed at how accurate it is! I think I will be using this mode a lot more in the future.
                                I think you can be confident that it will be plenty good enough for what you are after 🙂
                                Suunto 7 Graphite Copper
                                Suunto App Beta (Android - Pixel 6 Pro)
                                Luís PintoL 1 Reply Last reply Reply Quote 1
                                • Luís PintoL Offline
                                  Luís Pinto Platinum Member @olymay
                                  Suunto 7 questions from users experience until now:
                                  1. How many hours hiking/running/cycling with navigation on, battery at beginning 100%, wrist hr on, best gps ?
                                  2. How many hours hiking/running/cycling with navigation on, battery at beginning 100%, wrist hr on, fusedtrack gps on?
                                  SR
                                  Site (gr7vel spin): https://youtube.com/channel/UCfHM0mXWS8S61h70Rzj9mfA
                                  M 1 Reply Last reply Reply Quote 0
                                  • M Offline
                                    Mi_chael Bronze Member @Luís Pinto
                                    @luís-pinto
                                    1. 5-7h
                                    2. GPS set to Good? 15-17h but if you use navigation the watch set GPS to Best.
                                    Nigel Taylor 0N Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                    • Nigel Taylor 0N Offline
                                      Nigel Taylor 0 Bronze Member @Mi_chael
                                      @mi_chael said in Suunto 7:
                                      @luís-pinto
                                      I’ve found it works just fine on Good for running (might be less usable cycling and covering more ground in the 10 second intervals) - in fact I’ve ended up defaulting all my running profiles to Good.
                                      • pilleusP Offline
                                        pilleus
                                        GPS set to good is no option for cycling. It is cutting corners and the GPS track is not really good. My opinion.
                                        EgikaE 1 Reply Last reply Reply Quote 1
                                        • M Offline
                                          For me « Good » work pretty well for running, trail running and hiking.
                                            Brad_Olwin Moderator @Mi_chael
                                            @luís-pinto
                                            1. 5-7h
                                            Why set to Best for navigation? I use Nav in Good fix.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
