    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    When Ambit 3 Peak will transition to Suunto APP?
    Scheduled Pinned Locked Moved Digital service transition
    66 Posts 16 Posters 16.8k Views 16 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • CookiemonsterC Offline
      Cookiemonster @LudovicTheRunner
      @LudovicTheRunner Yes, they could not get anything to work and said to send the watch in for repair. Speakimng to another Ambit3 user with iPhone 11 they have the same problem so it is clearly not the Ambit 3. I have decided to use my back-up phone (iPhone 😎 with teh Suunto App for syncing which works OK but truncates the routes on the map. Bizarrely though it transfers all the data to Strava that displays the route correctly so that has to be a Suunto App bug.
      Dragon Boat Paddler, leisure/fitness Cyclist & Scuba Diver
      Suunto 9 Baro
      Ambit 3 Peak (retired)
      Eon Steel + Tank pod Awesome primary dive computer
      Zoop - great back-up dive computer
      F 1 Reply Last reply Reply Quote 1
      • F Offline
        francescobaldi @Cookiemonster
        @Cookiemonster nice to find another DB paddler here!!
        And we also are new owners of A3P!
        Hope it will be a great experience…
        Ambit 3 Peak vs Suunto app "sad" owner.
        Flatwater kayaker, runner, road and mountain biker & hiker
        • L Offline
          LudovicTheRunner
          So, in the end, was someone in this thread able to move to Suunto APP using his A3P with all the moves correctly synchronized ?
          M freeheelerF 2 Replies Last reply Reply Quote 2
          • M Offline
            margusl @LudovicTheRunner
            @LudovicTheRunner , I went through the transfer about a week ago, wanted to get over with it before May as they seem to plan some Movescount data handling change:
            Moves that have been deleted in Movescount after May 2019 will be transferred to Suunto app and may still appear in the Diary. If this is the case, we kindly ask you to manually delete them in Suunto app.
            https://www.suunto.com/Support/faq-articles/movescount/how-do-i-transfer-my-move-history-from-suunto-movescount-to-suunto-app/
            I had synced Ambit3P to both MC & SA since Oct. 2018, maybe just missed some activities in MC, also had few deletes sometimes from both services, sometimes only from one. So the content wasn’t quite 1:1 and there was a great potential to double nearly everything I had done during 2019, but after transfer it turned out quite OK:
            2019 Movescount		439 moves		411:37 hours	4344    km
            2019 Sports-tracker	456 workouts		425    hours	4457    km
            2019 Suunto App		461 activities		425:23 hours	4457.49 km
            After transfer I did remove some activities through sports-tracker as I discovered that feed view in ST dashboard was basically a live status view of transfer progress and once the activities from overlapping time frame started to appear there, those were mostly some super-short test activities that I had once already deleted from SA.
            Though note that during the time I synced to both services, I made only few changes to those activities in MC and SA - so almost no tags, comments nor manual duration changes, this probably helped as well.
            It’s actually quite easy to get a list of activities from both Movescount and sports-tracker to track down those differences, but so far I haven’t really bothered with this. Diff between Suunto App and ST activity number comes probably from some kind of SA caching.
            Before transfer I disconnected all my 3rd party services to avoid duplicates there and reconnected once finished. And also exported & backed up all Movescount data (http://www.movescount.com/settings#export) ; also all summary data with all tags & notes that are not included in export (http://www.movescount.com/Move/MoveList , it’s json and needs some processing to be useful, also works only if you are logged in to Movescount )
            • freeheelerF Offline
              freeheeler @LudovicTheRunner
              @LudovicTheRunner
              yes
              living sideways
              • L Offline
                LudovicTheRunner
                Finally, after one week one synchronization to get all my moves from movescount to be inserted into Suunto link, I can now fully rely on Suunto link app.
                Register Login
                • First post
                  Last post
                Suunto Terms | Privacy Policy
