    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Route plan using "birdroute" + GPX file import problem
    Scheduled Pinned Locked Moved Suunto app and other software services
    13 Posts 4 Posters 1.1k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Erkki WrangenE Offline
      Erkki Wrangen
      Hi, I just bought Suunto 9 and now Im testing route planning and how to import GPX route to suunto app.
      Is it possible to plan route using non-route planning “bird route” within suunto app? I can use routes but if I have to use routes + non routes within one route plan.
      I try to import GPX file from TOPO GPS app. Suuntoapp does not understand this file?
      Cheers to all
      Suunto 9 and finnish nature
      sartoricS 1 Reply Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @Erkki Wrangen
        @Erkki-Wrangen said in Route plan using "birdroute" + GPX file import problem:
        Yes you can
        What’s the problem ?
        Which app version / os do you have ?
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.7.12 beta
        Suunto App IOs 3.8.0 (21526) beta on MBP M1 Max
          Erkki Wrangen
          Thanks,
          Android 4.10.4 (4010004)
          I cannot find bird route selection during route plan. Where this option can be selected?
          GPX route import shows:
          HUPS! Problem occurred when importing GPX file. File may be corrupted or format is not supported.
          Okay…I found the route selection. Sorry to disturb!! 😉 I have big fingers 🙂
          GPX file importing unsolved.
            Erkki Wrangen
            Problem to inport Topo-GPS route to Suunto app may come specially topo-map and suunto app map sync problem perhaps? Does anyone else has this same problem to inport Topo-route?
            Another thing is that does Suunto App use Topo-maps?
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @Erkki Wrangen
              @Erkki-Wrangen The route does not include a map and Suunto uses Map Box maps that do have topographic contours. Unless there are issues with the gpx header information SA should be able to import gpx files.
              Vector/T6c/Vertical 2 Ti
                Erkki Wrangen
                Thanks Brad. After your message I went to see again suunto app map. That is topo map. Only thing is that I have to zoom really close so I can see paths. But yes, that really is. Thanks again.
                  @Erkki-Wrangen I agree, it would be great to see trails at low zoom, I find this a problem too where the trails are only visible at a high zoom.
                  Erkki WrangenE 1 Reply Last reply Reply Quote 2
                    Erkki Wrangen @Brad_Olwin
                    Well, I was too fast. I compared topogps map and suuntoapp map. Suuntoapp does not include all trails. I try to insert pictures here but i dont know how.
                    • sartoricS Offline
                      sartoric Moderator
                      Could be.
                      But you can plan your route in your preferred app and then import the GPX in SA (ok I know you have some trouble)
                      You can also collaborate to OpenStreet project adding the missing trails
                      do you have a sample route to share here ?
                      SVTS - 2.50.28
                        Erkki Wrangen
                        test_route_at_Suomu.gpx
                        Mff73M 1 Reply Last reply Reply Quote 0
                        • Mff73M Online
                          Mff73 @Erkki Wrangen
                          I don’t catch your point
                          @sartoric advise is the best : not all maps contains all trails, and openstreetmap is collaborative : you can add the path missing.
                          With your GPX i see that mapbox contains exactly the path you need to follow, and SA shows it as well.
                          On the left copy of SA with manual route planning routing on the path known by mapbox, on the left your gpx on the same map provider on desktop.
                          SSU (retired), SV1, SV2
                          Wife : S9PP
                          SA: Always the latest beta :)
                          Android + Galaxy S205G
                          • Mff73M Online
                            Mff73
                            Oups, maybe i see your point : your gpx file is not OK in SA :
                            there seems to be header metadata still wrongly interpreted by SA.
                            Without the selected data on the right in the gpx file, it is imported
                            Wife : S9PP
                            Erkki WrangenE 1 Reply Last reply Reply Quote 1
                              Erkki Wrangen @Mff73
                              Super Thanks Mmf73!!! It works! I really appreciate your effort and time.
                              • First post
                                Last post
                              Suunto Terms | Privacy Policy
