    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Spartan Trainer - Frozen Screen after Soft Reset
    Scheduled Pinned Locked Moved Spartan
    22 Posts 4 Posters 1.4k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • AlexanderA Offline
      Alexander
      I have a new problem with my Spartan Trainer. The HR measurement did not work. I wanted to do the soft reset. This screen is now frozen. If I connect them with the cable to Suunto Link I get only the message that the clock must be reset. But she can not reset, frozen screen for hours.
      Ambit 3 Peak / S9 Baro / Vertical Titanium Solar
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
      • Dimitrios KanellopoulosD Online
        Dimitrios Kanellopoulos Community Manager @Alexander
        @Alexander-Scharl try holding the upper 2 buttons for some time. Sorry I dont use a trainer 😞 so it took time to search / ask
        Creator of Quantified-Self.io
        youtube.com/c/dimitrioskanellopoulos
        https://instagram.com/dimitrioskanellopoulos
        https://www.strava.com/athletes/7586105
        AlexanderA 1 Reply Last reply Reply Quote 0
          Alexander @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos I was hopeful because the battery was empty overnight. But even after loading and restarting everything was unchanged. I’ve tried the buttons, because only once the display is dark and bright again. I will send them in to Suunto, this is the fastest way. And then I think about a Spartan Sport. 😉 Thank you
          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
            @Alexander-Scharl so it went out of battery and the same issue persists?
              @Dimitrios-Kanellopoulos yes
                @Alexander-Scharl 😮
                So after power on its in the stats of boot and connecting it to SL does not do anything ?
                  @Dimitrios-Kanellopoulos yes, is strange. The only thing that has changed for a moment is an additional point in the status display. everything else the same.
                    @Alexander-Scharl perhaps its some usb cable issue?
                      @Dimitrios-Kanellopoulos I do not think so. I also use the cable for an Ambit3. Here is it ok. And SA recognizes the watch.
                        @Alexander-Scharl but wait now I am confused. The watch is still on the boot state and SA recognizes it ?
                          @Dimitrios-Kanellopoulos jep
                            oh! oh oh . Let me ask about this.
                              Alexander
                              I have the pickup ready for shipment. I would have sent her to suunto, tomorrow.
                                @Alexander-Scharl give me a few I am asking internally if there is a way to recover this
                                  Could you try holding all buttons for a long time (more than 12s ) ?
                                    Also this:
                                    Holding all 5 keys for 15 seconds, and when releasing holding still the middle button should go to bootloader.
                                    Going to bootloader will enable you to connect to SL
                                    EgikaE AlexanderA 2 Replies Last reply Reply Quote 2
                                    • EgikaE Offline
                                      Egika Platinum Member @Dimitrios Kanellopoulos
                                      @Dimitrios-Kanellopoulos yey - secret button configuration. 👍
                                      Maybe there are more?
                                      (btw: I could have used this last year, when a Trainer was stuck and I had to wait a couple of days until the battery ran out and I could get it back to work…)
                                      t6, S6, Elementum Terra, Ambit 3 Sapphire, Spartan Ultra Copper, Traverse Alpha, S7 Graphite LE, S9B Ambassador, S9P Granite Blue Titanium, S9PP Titanium Sand, Vertical All Black, Race Titanium Charcoal, Race S All Black / Titanium Courtney, Run Lime
                                        @Dimitrios-Kanellopoulo I test it at home. Thank you. I am hopeful.
                                          Alexander
                                          the 5-finger-trick does not work, unfortunately. The first message (1.Image) is always “reset the clock required”, then he works, (Image 2,3) “the clock is updated” and then again message 1.
                                          UPS comes tomorrow, the Watch is coming Home
                                            @Alexander-Scharl if you let the watch continue what does happen? Hangs there in the down arrow screen?
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
