    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 baro, gpx, more than 1000points possible?
    Scheduled Pinned Locked Moved Suunto app and other software services
    9 Posts 6 Posters 889 Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • O Offline
      ofriend2000
      Problem solved, deleted
      Brad_OlwinB E 2 Replies Last reply Reply Quote 1
      • AudaxjoeA Offline
        Audaxjoe
        I can’t answer the limit but the 9 easily uploads a 2778 point file (200km). 80’000 points is one massive file - if my maths is correct on the same ratio as I have above that is a near 6000km event!
        Suunto Vertical
        Suunto 9 BARO
        Garmin Fenix 3, 5
        Suunto Vector
          Dimitrios Kanellopoulos Community Manager
          https://en.wikipedia.org/wiki/Ramer–Douglas–Peucker_algorithm
          That is what is used to simplify. 80.000 is too much for 120Km afaik
          Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @ofriend2000
            @ofriend2000 I have uploaded 200km routes into my S9 for a 200k race with no issues. Does it matter how many points there are? What we need are waypoints recognized when imported into SA.
            Vector/T6c/Vertical 2 Ti
            • O Offline
              ofriend2000
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
              • sartoricS Offline
                sartoric Moderator
                Out of curiosity, what’s the length for a 80k points track ?
                SVTS - 2.50.28
                SSSWHR BARO Amber - 2.8.32
                Samsung A5 2016 - Android 7.0
                Suunto App Android 6.11.12 beta
                  Dimitrios Kanellopoulos Community Manager @ofriend2000
                  @ofriend2000 i have not seen anyone get lost from the simplification. You can split the trips to parts of the route as of per day. If you trek i dong think you will cover 80km per day.
                  • E Offline
                    estevez Bronze Member
                    @sartoric e.g. I have 1 gpx file with cca 78.000 nodes, and it is cca 93km. However I am able to simplify to cca 3.500-2.000 nodes, without loosing details important to me…
                    @Dimitrios-Kanellopoulos Well, the question was - how many nodes (points) per gpx file can Suunto 9 handle?
                    • E Offline
                      estevez Bronze Member @ofriend2000
                      @ofriend2000 said in Suunto 9 baro, gpx, more than 1000points possible?:
                      But the website always trim the gpx to only 1000 points, which makes the gpx file less accurate
                      I have just tried to import .gpx file to Movescount website with 3.500 nodes, and there was no problem. Then I downloaded it to the watch Ambit 3 Peak (via synchronization) and there was no problem either. However I do not know, if there was any simplification, when synchrozing with the watch. In Movescount website I still see original file with 3.500 nodes…
                      Register Login
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
