    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Goodbye Suunto, hello Garmin
    Scheduled Pinned Locked Moved Digital service transition
    208 Posts 63 Posters 78.8k Views 64 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User @freeheeler
      @freeheeler said in Goodbye Suunto, hello Garmin:
      I fully agree with @DMytro and @Brad_Olwin , too.
      …if you would have asked me 2 years ago my answer would have been: you can’t plan on a 6" screen. BUT, you can and it is very useful and intuitive. And it became absolutely great when editing points between start and finish became possible!
      maybe some people have to get used to it (like myself… ;-)), but I guess the majority appreciates the route planning in SA
      You guys did a good job…next planning I would do, I will try on the tablet with SA…
      Normally use komoot, google maps and sometimes basecamp to plan routes/trips on a 27 screen.
      • MiniForkliftM Offline
        MiniForklift Platinum Member
        I plan routes on my phone and on my laptop, can’t say I have any issues with either. Both are pretty easy
        SV Titanium Solar Forest
        • Jamie BGJ Offline
          Jamie BG Bronze Member @DMytro
          @dmytro - and that is what I love about the ClimbPro feature on the Garmin - absolutely awesome for seeing those climbs and your progress along them.
          DMytroD Brad_OlwinB 2 Replies Last reply Reply Quote 0
          • DMytroD Offline
            DMytro @Jamie BG
            @jamie-bg I think I wouldn’t be against this feature either:)
            However, I’m much more interested in my performance not dependent on slope but rather on the terrain difficulty: i.e. via ferrata, scrambling, hiking trail
            Jamie BGJ 1 Reply Last reply Reply Quote 0
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @Jamie BG
              @jamie-bg said in Goodbye Suunto, hello Garmin:
              Agree with you on this, we need something similar but better for Suunto.
              Vector/T6c/Vertical 2 Ti
              T 1 Reply Last reply Reply Quote 1
              • Jamie BGJ Offline
                @dmytro - would be nice if it was included.
                For MTB there is grit and flow which pretty much does that - gives a pretty good indication of the type of terrain. My BiL regulary does MTB and you can actively see when he hits really rough spots in the course. Of course that is unfortunately all during (seems a bit pointless) and post activity.
                cosme.costaC 1 Reply Last reply Reply Quote 1
                • T Offline
                  TyreseJ4 @Brad_Olwin
                  @brad_olwin Lol Suunto needs to do ALOT of things to keep up with Garmin. I’m not knocking Suunto, Just being honest with ya. 😊
                  Brad_OlwinB 1 Reply Last reply Reply Quote 1
                    Brad_Olwin Moderator @TyreseJ4
                    @tyresej4 said in Goodbye Suunto, hello Garmin:
                    I disagree as the companies clearly take different approaches. Suunto is much more minimalist, so compare the Enduro to the 9Peak. The major differences would be 1 sec battery life, complex interval workouts and ClimbPro. The major features are quite similar. I prefer a smaller watch with FusedTrack instead of a very large watch, I don’t mind the tracks or distances with FusedTrack. I find the Suunto interface much less confusing and cleaner, so it is a personal preference. I think Suunto’s approach to navigation is far, far, far superior to Garmin’s. I have an inReach mini and the difficulties in using and configuring routes is a Byzantine nightmare. Navigation matters to me and watch size matters so I don’t think Suunto has much catching up to do. I would argue something similar or better than ClimbPro, complex interval for those that want it, I don’t think there is much else.
                    TonyGT freeheelerF 2 Replies Last reply Reply Quote 3
                    • TonyGT Offline
                      TonyG Silver Members @Brad_Olwin
                      @brad_olwin I use a Garmin GPSMAP (if were talking about handhelds) to Map out areas of ecological interest and create and follow existing routes to narrow down the search parameters when out in the field, and find the process of creating, using and configuring a route very easy and a pleasure to do, in fact I also have ordnance survey maps 1:25000 loaded onto the unit as well making the whole gps experience a pleasure to use. The one limitation I found in the past for me was a track limited to 10,000 points recorded in any one instance, but the latest version has extended to 20,000 points.
                      The InReach mini I would have thought was primarily a gps communicator with other functions built in as a by product, I find it difficult to hold it as a comparator to a brands experience of using and configuring routes.
                      I guess its all subjective within each individuals experiences.
                      • cosme.costaC Offline
                        cosme.costa @Jamie BG
                        What is the utility of grit and flow? For me none, and I’m using a Garmin 530 as MTB computer. How a bike computer can know something about the terrain? The same computer that can count jumps and only counts the 20% of them and being very generous. ClimbPro, until the update 8.XX was not working well in 80% of the cases, a little bit better if you are doing road cycling but always loading the track in Connect, if not doesn’t work at all. As I have said several times, parameters that are not useful or reliable are pointless or another parameter the you delete from your screen, but well we can say that it has a lot of things.
                        BTW, in Garmin you can configure everything which is good but also a pain in the ass.
                        1 Reply Last reply Reply Quote 3
                        • freeheelerF Offline
                          freeheeler @Brad_Olwin
                          @brad_olwin
                          …and Suunto does not try to convince us to start golfing… just that this is being said as another big plus on Suunto 👍
                          I’ve had a Garmin and told Garmin customer service the vice versa of this threads title 😉
                          There is so much I appreciate in Suunto over Garmin
                          living sideways
                          MiniForkliftM 1 Reply Last reply Reply Quote 7
                            MiniForklift Platinum Member @freeheeler
                            Good… I have enough frustrations in my life already 😳
                            I’m with Brad, would love to see a dedicated climbing/elevation screen. I used the Polar Grit X Pro for a month or so and that had one and it was excellent; it told you exactly where you were on your run, you could see the upcoming climbs and all of the climb info was there on the screen as you were ascending
                            alt text
                            If we could get something like this or better for Suunto that would be a massive plus in my eyes, and I think it would really put us head and shoulders above the rest 👍
                            Tomas5T 1 Reply Last reply Reply Quote 7
                              I just realised that the OP posted this ages ago and he never came back on to say which watch he ended up getting
                              After 150+ posts on Garmin Vs Suunto it seems like he went with an Apple Watch 4 ?! His last post was a year and a half ago and pretty much all 16 of them were anti-Suunto. Sounds like his Apple watch ticked all of the boxes, obviously wasn’t too fussed on battery life 😁
                              Dimitrios KanellopoulosD Tomas5T 2 Replies Last reply Reply Quote 3
                                Dimitrios Kanellopoulos Community Manager @MiniForklift
                                @miniforklift lol
                                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                                • Tomas5T Offline
                                  Tomas5 Gold Members @MiniForklift
                                  @miniforklift well apple watch is great smartwatch and good sports watch too but battery life is joke 😄 not usable for all day hiking.
                                  Suunto Ambit 2 > Suunto 5 > Suunto Race 2
                                  MiniForkliftM 1 Reply Last reply Reply Quote 0
                                  • T Offline
                                    titus_fromnewtown Bronze Member
                                    So upset with the latest news about Ambit/Traverse with no more possibility to edit/modify/create apps. I was really fan of my Ambit 3, and it is going to be a basic watch instead ot the best ever sport/adventure watch you could find !
                                    Don’t think I’m going to purchase another Suunto if nothing is done to restore APPS edition/modification.
                                    freeheelerF T ? 3 Replies Last reply Reply Quote 2
                                      freeheeler @titus_fromnewtown
                                      @titus_fromnewtown
                                      what apps exactly do you miss?
                                      living sideways
                                      T 1 Reply Last reply Reply Quote 0
                                        MiniForklift Platinum Member @Tomas5
                                        @tomas5 said in Goodbye Suunto, hello Garmin:
                                        I believe that was his primary sport
                                        • T Offline
                                          titus_fromnewtown Bronze Member @freeheeler
                                          @freeheeler : all my private apps, with the possibility to modify some parameters of them (I had all my interval trainings with parametric settings)
                                          • T Offline
                                            Tetrix22222 @sebchastang
                                            @sebchastang unbelievable!
                                            1 Reply Last reply Reply Quote -3
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
