    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Using Stryd as power pod AND foot pod (inconsistent pace info on SA, PowerCenter and Strava)
    Scheduled Pinned Locked Moved Suunto app and other software services
    11 Posts 5 Posters 1.2k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Joe HuiJ Offline
      Joe Hui
      So I have gone for a run today and did a little test.
      Setting:
      • Stryd paired to Spartan Baro as power pod and foot pod with auto-calibration switched off right after paring.
      • Spartan Baro GPS set to “OK”. I did this intentionally to make sure if Spartan picked up pace info from the imperfect GPS then I would know.
      Expectation:
      1. Spartan would pick up pace and cadence info from Stryd, and display on watch.
      2. SA, PowerCenter and Strava would pickup pace and candence from Stryd
      What actually happened:
      1. As expected, I can see realtime pace and cadence info on watch - good.
      2. SA, PowerCenter and Strava, all showed different pace info. PowerCenter should be the most accurate as data came from Stryd directly. Total distance, avg power, avg pace on SA are all consistent with PowerCenter. The lap summary screen on watch is also very close to PowerCenter. **However, the lap summaries on SA and Strava show very different pace info. **
      Any idea?
      F Brad_OlwinB 2 Replies Last reply Reply Quote 1
      • F Offline
        fleshymutant Silver Members @Joe Hui
        @Joe-Hui Unless you set the Strava activity to “Race” the pace data will be coming from Strava’s algorithm that attempts to show moving time vs actual time. Set the activity to race and see how the numbers compare.
        Suunto 9 Baro Titanium
        iOS 13.1
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @Joe Hui
          @Joe-Hui Strava does a lot of filtering as well, it is not useful for metrics…it is a social site.
          Vector/T6c/Vertical 2 Ti
          • Joe HuiJ Offline
            Joe Hui
            Thanks. The remaining question is then why the lap summary in Suunto App can’t show the correct pace info. It looks like it gets the pace info from GPS instead of Stryd.
            • Joe HuiJ Offline
              Joe Hui
              I had another run with the same setting today. And I am quite sure this is a bug of the Suunto App. While the watch can pickup pace info from Stryd (display when running, and lap summary after running), lap summary after running in Sunnto App uses the pace from GPS.
              Is this a known issue? The attached screenshots are from my last run.
                @Joe-Hui Good find. I will check to see if this occurs on iOS as well. This needs fixing. @Dimitrios-Kanellopoulos
                Joe HuiJ 1 Reply Last reply Reply Quote 2
                • Joe HuiJ Offline
                  Joe Hui @Brad_Olwin
                  @Brad_Olwin thanks a lot!
                    Dimitrios Kanellopoulos Community Manager
                    sA issue . We are working on laps
                    Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                    suzzloS 1 Reply Last reply Reply Quote 0
                    • suzzloS Offline
                      suzzlo Moderator @Dimitrios Kanellopoulos
                      @Dimitrios-Kanellopoulos yes please…
                      Will Intervals be considered as laps?
                      Suunto: Race, S9Peak, Spartan Sport Wrist
                      Garmin: FR745, Edge 530
                      SA topics:
                      • Guides - https://forum.suunto.com/tags/guides
                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                        Dimitrios Kanellopoulos Community Manager @suzzlo
                        @suzzlo yes. Its a big feature coming
                        suzzloS 1 Reply Last reply Reply Quote 4
                        • suzzloS Offline
                          @Dimitrios-Kanellopoulos 🙂 Great!
                          SA topics:
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
