    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Bike Sensor disconnects with Suunto Race
    Scheduled Pinned Locked Moved Suunto Race
    6 Posts 3 Posters 643 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      simspi
      Since some firmware updates ago, my Suunto Bike Sensor connected to a Suunto Race doesn’t work as expected. When doing a ride with the Bike Sensor connected the distance reported is by far incorrect (32km instead of 25.5km). In addition the cadence measurement only shows some samples with many dropouts in between. I double checked the circumference setting, reconnected the Bike Sensor in the watch, checked magnets are placed correctly (green and red LED comes up) and replaced the battery in the Bike Sensor however with no luck. When checking the Settings => Connectivity => Connected Devices menu on the watch, one can see the Bike Sensor connecting / disconnecting approximately every 10 seconds. However when I use my smartphone to establish bluetooth connection to the Bike Sensor, the connection remains stable.
      The problem most likely started with the firmware update that dropped all connected devices (heart rate belt and Bike Sensor).
      Is there any advice regarding how to fix the issue? Because I already tried quite a number of troubleshooting steps I suspect it is a firmware issue. Are there other users seeing the same issue?
      mickywickyftwM 1 Reply Last reply Reply Quote 0
      • mickywickyftwM Offline
        mickywickyftw Bronze Member @simspi
        @simspi I thought my sensor was just dying, but now I’m getting suspicious…
        I have a combi sensor from Coospo that is similar to yours (but crucially, no LED). Swapped the battery a week ago to be sure this wasn’t the issue.
        Speed and cadence metrics seem to drop at random intervals during rides, you don’t see it while riding but can see the gaps in the FIT file afterwards.
        3 days ago a 93k ride was reported as 82k despite a good gps trace - and correcting distance in Strava added the missing 11k.
        2 days ago it simply wouldn’t connect at all at the start of a long ride (also about 95k); I got no apparent sign of life from it during the whole activity.
        Yesterday it mysteriously connected again during a very short ride, but only displayed zero cadence throughout, and no cadence data was in the FIT file.
        Now that I’ve read your message I’ll do some more testing to narrow it down, starting with using a phone app to connect the sensor.
        S 1 Reply Last reply Reply Quote 0
        • S Offline
          simspi @mickywickyftw
          @mickywickyftw Mine really frequently disconnects / connects and this is results in the watch nearly constantly vibrating during the excercise. It is incredibly annoying thus I now just disconnected it manually. I’m pretty disappointed because it is an original Suunto part which is unusable anymore.
          • S Offline
            simspi @simspi
            @isazi : I saw that you requested a user in an other post to create a proper bug report. I’d be happy to do one for the issue described in this post and direct it to the correct receiver. Can provide me with the directions to do so?
            Mff73M 1 Reply Last reply Reply Quote 0
            • Mff73M Offline
              Mff73 @simspi
              @simspi
              https://forum.suunto.com/post/188102
              SSU (retired), SV1, SV2
              Wife : S9PP
              SA: Always the latest beta :)
              Android + Galaxy S205G
              • S Offline
                simspi @Mff73
                @Mff73 thanks for the link. I unfortunately wasn’t able the past days to create the bug report, but will do as soon as possible.
                Register Login
                • First post
                  Last post
                Suunto Terms | Privacy Policy
