    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Charging issue
    Scheduled Pinned Locked Moved Suunto Vertical 2
    11 Posts 7 Posters 784 Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J Offline
      JoeBloggs2791
      I have a V2 I bought last month.
      I’m having issues charging, it takes forever to charge, like 5% per hour as if it’s constantly trickle charging. It was stuck on 22% and I turned it off and on again and it jumped to 36%. It’s getting to the point that I charge it for a few hours every week to keep it going. There is no damage to the contacts, cable it charger and the watch is clean from grime.
      Any ideas what this can be?
      EzioAuditoreE 1 Reply Last reply Reply Quote 0
      • EzioAuditoreE Offline
        EzioAuditore Gold Members @JoeBloggs2791
        @JoeBloggs2791 Maybe do a soft reset first and try again? You can also try and leave it to fully drain the battery and start from 0. Finally, hard reset and if persists contact service.
        Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
        Suunto Wing
        • Horizontal_2H Offline
          Horizontal_2 Bronze Member
          Are you sure the adapter is fine?
          L J 2 Replies Last reply Reply Quote 0
          • L Online
            larrybbaker @Horizontal_2
            @Horizontal_2 I agree - would check cable/charging set up. What are you plugging into?
            Vertical Ti Solar
            Vertical 2
            Race 2
            iPhone 17 Pro
            J 1 Reply Last reply Reply Quote 0
            • Bigb0zzB Offline
              Bigb0zz
              Cleaning the charging contacts
              • J Offline
                JoeBloggs2791 @Horizontal_2
                @Horizontal_2 it’s 4 weeks old with no visible damage…?
                Horizontal_2H 1 Reply Last reply Reply Quote 0
                • J Offline
                  JoeBloggs2791 @larrybbaker
                  @larrybbaker I’ve tried an Apple and Anker plug and a battery pack
                    Horizontal_2 Bronze Member @JoeBloggs2791
                    @JoeBloggs2791 I mean: is the out put strong enough? Sometimes there are weak adapters like 5W. I use a 15W adapter to charge my SV2
                    • J Offline
                      @Horizontal_2 is the output high enough on an apple USB-C plug?!
                      SuperFlo75S 1 Reply Last reply Reply Quote 0
                      • SuperFlo75S Offline
                        SuperFlo75 Silver Members Bronze Member @JoeBloggs2791
                        @JoeBloggs2791 I use the Apple 25W adapter with USB C… its working fine
                        Suunto Vertical 2 Titanium Sage
                        Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                        Suunto Wing
                        Suunto 9 Peak Pro Titanium (owns my wife now)
                        Suunto Spartan Ultra
                        SA iOS 3.9.0 (22101)
                        Instagram @superflo75
                        • SquirrelS Offline
                          Squirrel Silver Members
                          @JoeBloggs2791 said in Slow charging continued.:
                          To continue the saga of my Vertical 2 slow charging, I’ve contacted Suunto and they are ‘reviewing’ my case with a 5-7 day timeframe.
                          I can’t even hard reset the watch as it hasn’t reached 40% battery. It was charging from 1900 to 0530 and went from 7% to 26%. Its now been stuck at 30% for an hour or so.
                          I read about Suunto’s poor customer service but I’m beginning to regret leaving Garmin.
                          It is either a defective cable, or the watch. Unless you can do some self tests with multi meter, I’d recommend to send the watch AND the cable to service designated for your location. Unless they have the watch with the cable in for testing, any remote “reviewing the case” is nonsense and won’t solve anything.
                          Have you tried powering the watch down and then putting on the charger?
                          Settings > General > Power off
                          Race S
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
