First run and newbie question
So yesterday got my SV2… what an amazing watch. Really intuitive UI, so easy to navigate through it. Only took a couple of hours to get the hang of it. And it’s fast! No lag. Really happy with what Suunto came up with. If they continue in this way I would not be surprised that they begin slowly edging Garmin in this sector.
A newbie question: on the default face there are two coloured semicircles. I presume that the top one shows daylight hours. What does the bottom one shows? Also, what do the two small white triangles indicate on these semicircles?
TIA for any help!
@Wenzudeg The top triangle moves with the remaining time to sunset. The bottom one moves with the temperature between the max and min range based on the weather forecast.
@runsgrun thanks! Much appreciated.
Register Login
