    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Entering a POI directly on the watch using coordinates
    Scheduled Pinned Locked Moved Suunto Vertical 2
    12 Posts 6 Posters 1.2k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • C Offline
      CarlW
      Hello
      Just moved from Garmin to Suunto and trying to figure out the Vertical 2 when navigating beyond and out of reach of any kind of phone/internet connection…ie, I do not want / I can not, use my
      iphone/phone.
      User Scenario question:
      Seeing, in the dead of winter, a storm brewing and closing in fast, creating, on the fly, a new POI, being a possible place for sheltering, using only coordinates taken from the paper map held in front of me, in this case not Lat, Long since these are not optimal using a 2-d map, but for example MGRS or similar coordinates…
      Is this possible on the suunto Vertical 2?
      If not, what are possible workarounds that people on this forum have found?
      Many thanks for reading my question and even more thanks for any answers/input 🙂
      Carl
      W sky-runnerS EgikaE 3 Replies Last reply Reply Quote 0
      • W Offline
        Wenzudeg @CarlW
        @CarlW I believe that maps on SV2 are not routeable so you cannot choose a place (POI, coordinates, point on map…) and a route is built up. A workaround would be to have an app on the phone with routeable offline maps, build a route on the app and export it to the Suunto app for eventual transfer to watch via BT.
        I stand to be corrected by other more knowledgeable members of this forum who are more than willing to help with any queries.
        C 1 Reply Last reply Reply Quote 1
        • C Offline
          CarlW @Wenzudeg
          @Wenzudeg
          Thanks for your answer.
          No routing is necessary, only a straight line, point-to-point (your current location, to your newly plotted end destination), and a view of the compass, pointing at your end destination. Just like doing dead reckoning with map and compass.
          This has to be the most simple, straight forward application of as gps device! Even my first garmim, several centuries ago, before smartphones and digital mapping, did this 😞
          smutnakS 1 Reply Last reply Reply Quote 0
          • sky-runnerS Online
            sky-runner Platinum Member @CarlW
            While I don’t have an answer for the original question here is what was possible on an ancient Garmin Forerunner 610 15 years ago:
            1. Start creating a POI for the current location
            2. Modify the current location using the touch screen - considering the POI is not that far away, only a few digits would need to be modified. And yes, the watch had the touch screen and I could spin every digit up/down with touch
            3. Save the POI with modified coordinates and start navigating to it. The navigation was non-routable as the watch didn’t have a map, but it pointed me in the direction of the POI and displayed the remaining distance. I think Suunto POI navigation works the same way.
            Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
            Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
            • smutnakS Offline
              smutnak @CarlW
              @CarlW If you are only interested in a straight line, you could use azimuth navigation. The compass will still show the direction to the azimuth determined from the paper map.
              Suunto Race
              Suunto Race 2
              • EgikaE Online
                Egika Platinum Member @CarlW
                @CarlW afaik you cannot put in exact coordinates directly, but you can easily move the map around on the watch screen until you reach your desired point. then bring up the navigation menu und choose “Save as POI”. Voila, there you have your POI to add as a navigation target on the watch.
                C sky-runnerS 2 Replies Last reply Reply Quote 5
                • C Offline
                  CarlW @Egika
                  @Egika
                  Thanks!
                  That was exactly the sort of answer I was looking for, straight to the point and pragmatic! Thanks Egika 🙂
                  BR
                  Carl
                    sky-runner Platinum Member @Egika
                    @Egika But that isn’t the same as entering by coordinates. There are situations when coordinates are known but it is unknown where it is on the map. Think about something like looking for obscure hot springs or a source of water, or for example a geocache.
                    EgikaE 1 Reply Last reply Reply Quote 2
                    • EgikaE Online
                      Egika Platinum Member @sky-runner
                      @sky-runner said in Entering a POI directly on the watch using coordinates:
                      Yes. That’s exactly what I wrote.
                      No coords input on watch, but a possible way to define a target point on the watch.
                      If I am looking for a hot spring position, where I know ccords, currently the only way is to enter the coords in the app.
                      • C Offline
                        CarlW @Egika
                        @Egika
                        Lets hope for an update to fix this issue…in my humble opinion, this should be on the top of sunnto’s To-Do list…no serious navigation watch should lack this very basic application.
                        R 1 Reply Last reply Reply Quote 0
                        • R Offline
                          raphaelh @CarlW
                          Hi @CarlW @egika
                          I am glad you bring this up and I am not the only one thinking this is a very basic but essential feature of a GPS watch. I created a feedback to the Suunto team requesting the capability to create a POI with a custom coordinate on the watch or be able to edit POIs. Later would be even better as one like is looking for a coordinate within a couples of km so editing a new POI with current location will save some tiping. If you have not done this I would ask you to do the same. The more people ask for it the more likely it will become a feature (maybe). I really wonder whats the opinion of the Suunto team here.
                          Cheers
                          C 1 Reply Last reply Reply Quote 0
                          • C Offline
                            CarlW @raphaelh
                            @raphaelh
                            Will do, and thanks!
                            BR
                            Carl
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
