    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Vibrations et tonalités fantômes
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    35 Posts 17 Posters 4.1k Views 19 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      Greennorth @duffman19
      @duffman19 Okay, thanks for that info. I guess there is not too much we can do about it? I understand they have stopped providing new updates for the S9PP. I have two watches and the one stopped doing it but the other one still does. Hopefully it just stops too!
      Traverse / Suunto 3 Fitness / S7 / S9PP
      • EfejotaE Offline
        Efejota Bronze Member
        Phantoms vibrations reaturned, in my case. Not very often, but still… I will try to check if it is related to phone presence.
        • D Offline
          duffman19 @duffman19
          said in Vibrations et tonalités fantômes:
          My current guess is that it may have something to do with the compass auto-calibration.
          I am almost certain this is this issue now. To check this, I performed the following:
          • Open the compass widget (make sure it is already calibrated).
          • Bring a magnet close to the watch (doesn’t have to be strong, a refrigerator magnet will work).
          • This will reset the compass and bring up the “Calibrate Compass” notification.
          • Without moving the watch, back out to the watch face.
          • While on the watch face, perform the calibration movement (figure 8).
          • The watch will eventually vibrate, signaling that the compass has been calibrated.
          • Go back to the compass widget to verify it has been calibrated.
          I’ve performed this several times and every time I get the “phantom vibration.” My assumption is that some of us are perhaps in situations that cause the 9PP’s compass to reset often, and thus we get the phantom vibrations more often than others. I know for me, getting in and out of my car tends to mess with the compass calibration. Even a simple act like opening the refrigerator (with all those magnets on it) could reset the compass, triggering the background auto calibration and thus the phantom vibration.
          @isazi @egika Is there a chance this could be verified by Suunto? Would this qualify as a bug? Although a minor inconvenience, it seems like something that could be an easy fix as it seems to only affect the 9PP.
          Edit: You can perform an even easier verification. Simply bring a magnet close to the watch while on the watch face (locked or not). Then perform the figure 8 movement. You’ll get the phantom vibration once it calibrates, no need to check the compass widget. Checking the widget just verifies that the magnet reset the calibration.
          Vertical Ti / S9PP Ti / S9P Ti
          D 1 Reply Last reply Reply Quote 2
          • D Offline
            Some more observations confirming that it is indeed the compass auto-calibration causing the phantom vibrations:
            I’ve been paying more attention to where I am when the phantom vibrations occur. Most often they occur when I am in the kitchen or the car, or shortly after I have been in the kitchen or car. This makes sense. Lots of magnets and electric fields in both places.
            To test, I loaded the compass widget while going about my daily routine in both locations. As suspected, it frequently resets (“Calibrate compass” warning) while moving throughout these spaces.
            For the kitchen, there are three main culprits: the refrigerator (grabbing the handle near a magnet), the stove (induction cooktop), and a wall-mounted, magnetic knife bar. The compass resets if the watch gets within a few inches of these items.
            For the car, it was simply grabbing the door handle. My car has a touch sensor in the handle that unlocks the vehicle if the key fob is nearby. The compass resets every time I open the car with my watch hand. It will also reset if I place my arm on the inside door armrest. The culprit here seems to be the window controls or some other electronics within the door frame.
            Obviously the phantom vibration doesn’t occur until the watch auto-calibrates by moving through a range of motion (figure-8). So, even though the compass resets throughout the day in these spaces, the calibration may not take place until some time later after the watch has moved about a bit. The motions involved with driving (turning the wheel, moving through corners) seem to be enough to trigger it, so I’ll often get several of them while in the car. But if I simply grab something out of the fridge, I may not get the calibration and phantom vibration until some time later.
            This is very much a 9PP specific bug. My SV1 does not reset in any of the above locations. Even placing it next to a very strong magnet has very little effect on the compass. This is probably why the bug slipped through when the auto-calibration feature was added as most testers were probably not wearing 9PPs at the time.
            Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 3
            • Łukasz SzmigielŁ Offline
              Łukasz Szmigiel @duffman19
              @duffman19 I’ll have to investigate based on your findings as it’s possible to download logs from the watch with vscode addon for s+ development.
              S9PP 2.50.28
              • D Offline
                duffman19 @Łukasz Szmigiel
                @Łukasz-Szmigiel Sounds good, thanks.
                Also just discovered that getting too close to my laptop triggers the reset. I think it’s the magnets for the tiny built-in speakers. Man, this thing is sen-si-tive.
                I think I recall some discussion when the watch was first released cautioning against using the original 9P charger with the 9PP because the magnets were too strong and it could brick the watch. I don’t think that was ever actually the case, but it sounds like Suunto was at least aware of how delicate the 9PP’s magnetometer is.
                T 1 Reply Last reply Reply Quote 0
                • T Offline
                  tmclr Bronze Member @duffman19
                  @duffman19
                  I think you might be on it!
                  I’ve just pulled up the compass widget and placed my 9PP close to my iPad (with magnetic keyboard cover) - bingo - the compass losses calibration. Performing a cal is hard by waggling the watch on your wrist (people in the office are wondering what I’m doing 😉 ), but when it is complete I get the vibration confirming calibration complete.
                  I then held the watch close to my iPad again without the compass widget active, and confirmed that it has lost calibration. I’m now waiting to see how long it takes to ‘naturally’ calibrate and give me the phantom vibration.
                  Thanks for solving the mystery, just need a fix now!
                  T 1 Reply Last reply Reply Quote 1
                  • T Offline
                    tmclr Bronze Member @tmclr
                    I’ve repeated several times this morning - bringing my watch close to the magnetic cover of my iPad. It is VERY sensitive and resets the compass very readily as duffman has worked out!
                    With me working at my desk, it seems to take between 30 and 60 mins to ‘naturally’ recalibrate the compass and give the phantom vibration alert.
                    • E Offline
                      Elipsus Gold Members
                      Yes Its the compass for sure.
                      I worked for a few hours yesterday on my 3D printer, and that thing is full of magnets, and …oh boy… the watch did vibrate every 5 minutes !
                      Good job @duffman19
                      Now lets hope for a fix !
                        Łukasz Szmigiel @Elipsus
                        @Elipsus yeah, can confirm that. I’ve observed that too while I was working on fixing my friend’s laptop.
                        S9PP 2.50.28
                        • M Offline
                          MirkoP
                          So? Anyone close to Suunto that could tell us if we should downgrade the firmware to fix it or we could expected an update just to fix the bug?
                          Thanks to everyone
                          Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                            Łukasz Szmigiel @MirkoP
                            @MirkoP get used to it 🙂
                            S9PP 2.50.28
                            LisztoL 1 Reply Last reply Reply Quote 1
                            • LisztoL Offline
                              Liszto @Łukasz Szmigiel
                              @Łukasz-Szmigiel any news from Suunto here on that topic ?
                              The Suunto 9PP of my wife have the issue and it is worst and worst, now it’s battery is draining something like more than 20% per day probably due to that and the amount of vibration is very annoying 🫠
                              She hopes to have a fix for that and she hopes it’s battery won’t be “damaged” by that…
                                Łukasz Szmigiel @Liszto
                                @Liszto I doubt that it’ll get fixed.
                                S9PP 2.50.28
                                LisztoL 1 Reply Last reply Reply Quote 0
                                • LisztoL Offline
                                  @Łukasz-Szmigiel ok 😞
                                  @isazi for the follow up just in case
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
