    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPX Import into SA - How To Guide (Android)
    Scheduled Pinned Locked Moved Suunto app and other software services
    featurefaqandroid
    61 Posts 25 Posters 14.3k Views 24 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • surfboomerangS Offline
      surfboomerang
      Even after the 3.53 update the Suunto App still isn’t selectable as Open With… app for me. Tried several file explorers, but no luck.
      Suunto Vertical Titanium Solar
      OnePlus Nord 4
      • stromdiddilyS Offline
        stromdiddily Gold Members @Jonathan Newby
        @Jonathan-Newby said in GPX Import into SA - How To Guide (Android):
        @ColdBeer I thought it was something new. I did that with mine last week.
        I mentioned it in another thread and got asked to post about it. Seems like it only works for some which may be why it was kept under wraps
        Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
        User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
        • Mff73M Offline
          Mff73
          Please post here for GPX import that doesn’t work.
          link
          SSU (retired), SV1, SV2
          Wife : S9PP
          SA: Always the latest beta :)
          Android + Galaxy S205G
          • O Offline
            Oli_Ver @stromdiddily
            @stromdiddily said in GPX Import into SA - How To Guide (Android):
            On mobile, navigate to GPX file and open
            works great, many thanks Dude!
            Watch: Spartan Sport WHR Baro
            Watch fw: 2.6.54
            SuuntoApp Version: everytime the latest beta available in Play Store
            Smartphone: Google Pixel 2 XL
            • C Offline
              cdcg82
              Hi mates, try the Open it! File Explorer.
              • N Offline
                nottie
                Hi,
                First of all I’m very glad I found this forum and this post. Googling for GPX import for SA is very unsuccessful…
                I have SA v3.54.3 and I exported a route manually created in movescount to GPX. Opening this GPX on phone (oneplus2 android 9) does open the SA but remains still just showing a zoomed out worldmap.
                Just to try if it worked with another GPX I exported a route from Strava run by some random person. Opening this on the same phone configuration opened the SA and within seconds showed me the option to save the route.
                Is there something special I have to do to Movescount (exported) route to make it a valid import?
                sartoricS 1 Reply Last reply Reply Quote 1
                • sartoricS Offline
                  sartoric Moderator @nottie
                  @nottie said in GPX Import into SA - How To Guide (Android):
                  You shouldn’t, but you can try (if not already done) to enable BT and connect watch before importing the GPX.
                  That version of SA sometimes get stuck during saving (an maybe import) if not connected to the watch
                  you can also check this : https://forum.suunto.com/topic/1476/gpx-import-doesn-t-work-for-you-post-here
                  SVTS - 2.50.28
                  SSSWHR BARO Amber - 2.8.32
                  Samsung A5 2016 - Android 7.0
                  Suunto App Android 6.8.9 beta
                  • N Offline
                    nottie
                    No luck.
                    I also tried the 0_1542738001197_BigFoot40.gpx but that didn’t work for me either.
                    [Edit] Well,
                    Now I reopened my own route in movescount, changed the route to closed and the mode of routing to “Don’t follow roads” (I only have dutch, so don’t know the exact translation). Exported it again and Now it imported fine into the SA.
                    Almost the same for the bigfoot route. I imported that into movescount, exported, imported into SA. Now it works fine…
                    • F Offline
                      Felipe Pose Velasco
                      it works!
                      can I buy you a beer? 🙂
                      This was the main reason I did not install the suunto app until today.
                      • FinnsAwayF Offline
                        FinnsAway
                        I finally got this working. It’s not that simple because Suunto App is not on the list to open GPX file if you using dropbox, drive etc app in your phone. This depends what Android model you have, probably.
                        But when I opened GPX-file from web page (dropbox) I was able to select Suunto App from the list.
                        I think this is huge problem because there definitely should be importing option in the Suunto App itself. Can you please add that in next version. Thank you
                        1 Reply Last reply Reply Quote 6
                        • O Offline
                          Oli_Ver
                          Hey guys, good morning.
                          yesterday I tried to import an exported Komoot GPX file into SA, in the same way I have done multiple times before. But I get an error that shows:
                          Sorry, your file can not be importet because its damaged or wrong format.
                          (my onw translation)
                          Anybody with same problems?
                          Brgds Olli
                          Watch fw: 2.6.54
                          jordiigmJ Dušan KovićD 2 Replies Last reply Reply Quote 0
                          • jordiigmJ Offline
                            jordiigm @Oli_Ver
                            @Oli_Ver me too!! Only opens GPX with 500 points Max.
                            AudaxjoeA 1 Reply Last reply Reply Quote 0
                            • Dušan KovićD Offline
                              Dušan Ković @Oli_Ver
                              @Oli_Ver Happened to me also… I had to import GPX to Movescount and than download it again so that Suunto App recognised it as correct. Not sure what is going on in the background.
                              SR
                              SA latest beta
                              Polar Verity Sense
                              Polar H10
                              Vivo x300 Pro
                              O 1 Reply Last reply Reply Quote 0
                              • O Offline
                                Oli_Ver @Dušan Ković
                                @Dušan-Ković thanks, will try in that way!
                                Update: yes, it worked for me too with Movescount export!
                                Watch fw: 2.6.54
                                • AudaxjoeA Offline
                                  Audaxjoe @jordiigm
                                  @jordiigm I have no issues opening much larger files - haven’t tried anything over about 3000 points but currently have 6x 200k rides for a trip next week all loaded correctly.
                                  Suunto Vertical
                                  Suunto 9 BARO
                                  Garmin Fenix 3, 5
                                  Suunto Vector
                                    Dimitrios Kanellopoulos Community Manager
                                    File size is not an issue.
                                    Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                                    • jordiigmJ Offline
                                      jordiigm
                                      I tried to import GPX to Movescount and then export it again and that way SA opens any file size. But importing directly doesn’t work for me with some files.
                                      • AnthonyBA Offline
                                        AnthonyB
                                        The main solution of this topic works very well.
                                        I use SA on my XIAOMI MI8 (Android). And I create my routes on MC in order to have them in the most compatible format possible with SA. I import all my routes into MC for those I do not create personally. Moreover, I myself have created itineraries of more than 1000 points but if I want to import them into my watch I divide into several parts the more practical and precise route for the trail navigation.
                                        On my mobile, I have FATMAP and SA.
                                        On my computer or mobile internet browser, I export the MC route by registering it to a google drive GPX. I open my cloud from my mobile to “open with” the route. SA opens it automatically, it only remains to save or modify some details. The route is imported into SA with the others. I can then enjoy my trail runs 🙂 ✌.
                                        I then check the routes to use on my Suunto 9 Baro.
                                        Anthony for France
                                        • M Offline
                                          makruiten
                                          This works for iOS too, so maybe the title can be changed again to reflect this. In the share menu there is now a “copy to suunto” option. I have already added 4 gpx routes to the Suunto App in this way.
                                          • John van WinkelJ Offline
                                            John van Winkel Bronze Member
                                            great stuff, i also was wondering iff they would upload all created routes of the movescount web into the suunto app, cause there is such a welth off tracks in there,
                                            i found some old trailrunning races and routes of 30+ km’s, and all i have to do is upload them to my watch, for me that is the raw power of the suunto experience,
                                            i also noticed that on the map there are campingsites, its just perfect to drop my car and set up basecamp!!!
                                            after 2020 wil suunto shut down movescount or will it still excist but not be upgrading it anymore?
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
