Battery drain
Re: Battery drain - share your settings
I have a Suunto 9 Peak pro. After the the 2.50.26 and especially 2.50.28 update the battery drains very fast. In one day without any activity the battery from 57% goes to 28%.Has anyones else the same problem?I tried a soft reset but nothings happens.Also i checked the backlight but is off.
@JohnnyB Yes indeed, I also realized after the last january update (2.50.26) that my battery is draining much faster than before!
Me too. I have already send my watch to the support, but nothing change… still battery drain problem.
@Loïc-Gangloff same here ! 10 days without bt connections and no wake off the backlight when i move m’y hand.
After the 2.50.28 update, I also have some battery drain issues. It’s not as bad as what you guys have, but the battery goes down twice as quickly as before.
Hi guys! I’m new here, made this forum just for this problem:
Since the firmware update as you guys report 2.50.28 on my Race S I have big battery drain about 1% an hour even in airplane mode and the dumbest digital watch face.
From some Chat GPT help I uninstalled offline maps, made a soft reset, factory reset, now I’m leaving it in airplane mode overnight to see. But it’s doesn’t look good, it already dropped from 74% at 18:45 to 71% 21:45.
Register Login
