    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    My Vertical 2 Wishlist for Next Update in 2026
    Scheduled Pinned Locked Moved Suunto Vertical 2
    vertical2wishlistvertical
    92 Posts 38 Posters 14.6k Views 35 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • TieutieuT Offline
      Tieutieu Platinum Member @dreamer_
      @dreamer_ is it specifically the shortcut that triggers the report, or pressing any button does it also ? On my race s sometimes pressing a button triggers it, sometimes not
      Suunto’s devices at home :
      Vertical titanium solar
      Suunto Race S
      S9pp titanium sand
      Suunto Wing & Spark
      S9B titanium Ambassador edition, A3P, X6
      dreamer_D 1 Reply Last reply Reply Quote 1
      • dreamer_D Online
        dreamer_ @Tieutieu
        @Tieutieu I have the flashlight shortcut in the top button. If I long-press that button it triggers the morning report instead the flashlight but it depends on the hour is pressed.
        It can happen at 5.00AM but not at 1.30AM. But I have seen this issue at 4.00AM.
        I usually wake up at 6.10AM. The very first thing I do is press the shortcut for the flashligh and the watch triggers (every day) the morning report instead the flashlight.
        Garmin Fenix 8 Solar 51mm, Suunto Run
        • M Offline
          maszop Bronze Member @Ze Stuart
          @Ze-Stuart “If it ain’t broke, don’t fix it.”
          Are you sure contour lines are more accurate? There are plenty of areas where they are completely wrong (e.g., the Dolomites). And even their theoretical accuracy often comes with a much larger error than barometric altimeter readings. It’s no coincidence that barometric altimeters are the most popular and the most accurate.
          Ze StuartZ 1 Reply Last reply Reply Quote 0
          • Ze StuartZ Offline
            Ze Stuart Gold Members @maszop
            @maszop ha. Well…
            1. Is broke (at the moment), do fix it.
            2. That’s a valid reason to have all three. The way I’d put it, as an algo…
            if (FusedAlti confidence is < x)
            use contour datum
            else
            use FusedAlti
            fi
            Or just expose it to the end-user in the alti calibration options. I’d really appreciate that functionality. FusedAlti confidence can be determined in the same way other Fused* is: improbable data change, eg altitiude change greater than a rate of x, with x having multiple vars depending on activity.
            https://zulusierra.co
            Fenr1rF 1 Reply Last reply Reply Quote 0
            • Fenr1rF Offline
              Fenr1r @Ze Stuart
              @Ze-Stuart Is there any evidence that the contour lines represent embedded elevation data (rather than being simply image elements)?
              Mff73M 1 Reply Last reply Reply Quote 2
              • Mff73M Offline
                Mff73 @Fenr1r
                @Fenr1r
                There are more evidences that contour lines are precomputed data from various sources and converted into graphical elements when maps are generated.
                No elevation data in map themselves.
                SSU (retired), SV1, SV2
                Wife : S9PP
                SA: Always the latest beta :)
                Android + Galaxy S205G
                Ze StuartZ Fenr1rF 2 Replies Last reply Reply Quote 1
                  Ze Stuart Gold Members @Mff73
                  @Mff73 @fenr1r who wants to download a map file and grep it for strings?
                  Joking aside, it’s just an idea. We don’t need to solve the problem; if Suunto like it they have, somewhere, the elevation data. They can figure it out. Mebbe there’s a way to write a S+ extension, but I’d rather not.
                  • Fenr1rF Offline
                    Fenr1r @Mff73
                    @Mff73 That’s my understanding but @ze-stuart seems to be assuming otherwise, hence my question.
                    Mff73M 1 Reply Last reply Reply Quote 0
                    • Mff73M Offline
                      Mff73 @Fenr1r
                      @Fenr1r
                      I understood, it was indirect answer 😊.
                      @ze-stuart
                      https://forum.suunto.com/post/187990
                      Then you can search in the Web, all vectorized map are having only graphical data, precomputed before map generation by the map builders, based on any external data they want / can access (for free or not).
                      For elevation usable data, you may also read for example how some people are trying to create them in a reedable format and as much precise as they can.
                      https://sonny.4lima.de/
                      It is also a huge work to create them, and then, look at the amount of GB for the whole world.
                      For my country, I use them with android app, and it is taking 6GB.
                      Wife : S9PP
                      Ze StuartZ 1 Reply Last reply Reply Quote 2
                      • M Offline
                        MikeC30 Bronze Member
                        I think a tide widget would be really useful as well. Either when walking the dog on the beach or timing a run to avoid high tide.
                        Suunto Ambit3 peak
                        Suunto 9
                        Suunto Vertical 2
                        Suunto Wing 2
                        COROS HR monitor
                        Z 1 Reply Last reply Reply Quote 3
                        • Z Offline
                          zhangschmidt Bronze Member @MikeC30
                          “Stealing” this from other post/thread:
                          A night mode would be a good idea, indeed.
                          I’ll have to run my upcoming ultra with a headlamp, anyways, but if the watch didn’t blind me, it would still be appreciated.
                            @Mff73 always nice when someone else has done the work! Thanks, I didn’t know about that post, or Sonny’s work.
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
