    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    VO2Max and walking/hiking
    Scheduled Pinned Locked Moved Suunto Race 2
    23 Posts 7 Posters 2.9k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Tomas5T Offline
      Tomas5 Gold Members
      Hello, is there reason why Race 2 doesn’t calculate VO2Max with walking/hiking activies?
      With Suunto 5 it worked. Since i bought Race2, graph is empty in Suunto App.
      Suunto Ambit 2 > Suunto 5 > Suunto Race 2
      S SquirrelS Brad_OlwinB 3 Replies Last reply Reply Quote 0
      • S Offline
        Stavrogin @Tomas5
        @Tomas5 What HR zones are you in while hiking? My understanding is you need to be at at least 70% of your max HR for the watch to make adjustments.
        Also have you adjusted the max hr in the preferences? If it is not correct and your zones are off this might be part of the issue.
        Suunto Vertical, Race, Race 2, Race S and Run. Rocking the Vertical 2 Titanium at the moment.
        Garmin: Fenix 7X, Epix Pro 51mm, Forerunner 265.
        Coros: Pace Pro, Apex 4
        Tomas5T 1 Reply Last reply Reply Quote 1
        • Tomas5T Offline
          Tomas5 Gold Members @Stavrogin
          @Stavrogin i configured it same way as i had on Suunto 5.
          Rest HR 60
          Max HR 184
          Zone 1 <133
          Zone 2 <142
          Zone 3 <151
          Zone 4 <160
          Zone 5 >160
          While walking i am usually in zone 1 and 2. I don’t do much hiking lately, but today short 5km hike , but intensive i was 19% in zone 5, 17% in zone 4,… and 46% in zone 1.
          70% is 128bpm, so i reach it for at least some time everytime.
          • SquirrelS Offline
            Squirrel Silver Members @Tomas5
            @Tomas5 So are you using Hiking or Walking activity? Those are two different things. While walking can generate VO₂ max, Hiking activity does not. Since VO₂ max calculated from walking is questionable at best, I never use walking activity. Try running or trail running if you can, but trail running will generally produce lower score than flat road running or track running. Ideally, there should be an option to disable VO₂ max in trail running.
            Race S
            • Tomas5T Offline
              Tomas5 Gold Members @Squirrel
              @Squirrel i do both walking and hiking. I don’t run for at least 6-7 years. But still it was working with Suunto 5, i can’t tell how accurate it was but it measured something.
              SquirrelS 1 Reply Last reply Reply Quote 0
              • SquirrelS Offline
                @Tomas5 You can disregard all hiking activities as they do not calculate VO₂ max. But it can depend on when you first used Walking activity on this new watch and how many times you used it, before you get VO₂ max score. For me, it took over a month of running to get VO₂ max. Some people get the score sooner, no idea what it depends on.
                Race S
                • Brad_OlwinB Offline
                  Brad_Olwin Moderator @Tomas5
                  @Tomas5 I would not trust ANY device to compute a VO2M from walking or hiking. Why do you think athletes do lab tests? Sorry but I don’t think devices should do this under any circumstances as the result has to be completely invalid.
                  Vector/T6c/Vertical 2 Ti
                  Tomas5T 1 Reply Last reply Reply Quote 4
                  • Tomas5T Offline
                    Tomas5 Gold Members @Brad_Olwin
                    @Brad_Olwin to be honest i don’t need this metric. But if i have device with some features, i like them all to work correctly regardless i need them right now or not. Based on what you say, i would prefer if suunto really does just metrics that is capable of duing in right way. It would reduce number of features and helped focus developers work on rest of features that really works.
                    Is there any way to hide metrics that doesn’t work from app? I found lot of customization but not sure if this is possible.
                    • D Online
                      dulko79
                      This is from SR2 manual: Your aerobic fitness level is defined as VO₂max (maximal oxygen consumption), a widely recognized measure of aerobic endurance capacity. In other words, VO₂max shows how well your body can use oxygen. The higher your VO₂max, the better you can use oxygen. The estimation of your fitness level is based on detecting your heart rate response during each recorded running or walking workout. To get your fitness level estimated, record a run or walk with a duration for at least 15 minutes while wearing your Suunto Race 2.
                      For a walk under certain conditions SR2 should provide VO₂max estimation. Even if not precise as in lab, for someone at the beginning of fitness journey it could be a good indicator of progress and also a motivation. 😄
                      App: beta
                      Phone: Iphone
                      iOS
                      Tomas5T 1 Reply Last reply Reply Quote 0
                      • OutdoorManO Offline
                        OutdoorMan Silver Members
                        I never understood why walking / hiking is producing vo2max. I noticed that when Race S once calculated that when my wife couldn’t figure out how to get a vo2max reading for running. It took one walk to finally get it. And since then also running calculated vo2max. For me only Baro 9 produced vo2max while hike, no other watch, and I hated it 🙂
                        • Tomas5T Offline
                          Tomas5 Gold Members @dulko79
                          @dulko79 thats even more confusing as i did mostly walks with Race 2. Only few hikes, and just few bike rides.
                          Some say hiking doesn’t count, but my older Suunto 5 few times rapidly changed fitness age after hiking and if i am correct it is related to VO2Max.
                          • Tomas5T Offline
                            Tomas5 Gold Members @OutdoorMan
                            @OutdoorMan i don’t understand why running should, walking/hiking shouldnt. I just know i don’t run because problems with knee for a long time. But still my previouse suunto watch (S5) did calculate this. How correct value was? I don’t know, but i know OHR didn’t worked well on S5 for me (lot of spikes and sometimes 20% of excercise it dropped to half of actual HR or it jumped to double which was even worse (like 200bpn while walk). So i assume this was really not calculated correctly since it is based on heart rate.
                            OutdoorManO 1 Reply Last reply Reply Quote 0
                              OutdoorMan Silver Members @Tomas5
                              @Tomas5 how many people do you know who train to improve their vo2max by walking? By definition it’s maximal oxygen consumption and maybe I am uneducated, but you improve it by reaching a certain percentage of you max HR, by running/cycling intervals, hiit, anything that brings your heart rate up for a certain amount of time. At least this is how I do it. Certainly not by walking. Maaaybe hiking uphill. For me measuring it for sports other than running or cycling doesn’t make sense. But that is my opinion, I am not arguing.
                              Tomas5T Brad_OlwinB 2 Replies Last reply Reply Quote 7
                              • Tomas5T Offline
                                @OutdoorMan hey, i am unedicated here, thats why i have this silly questions. I don’t know anyone training to improve VO2max by running, hiking, walking, cycling etc. My questions are based on uneducated observing that it worked with S5, don’t work with Race 2. I see that all you agree it is related mainly to running. So i am glad for this feedback and i will ignore it.
                                OutdoorManO 1 Reply Last reply Reply Quote 1
                                  @Tomas5 well in the end it doesn’t really matter because it’s not very accurate no matter what you do 🙂 I personally take it just as an informative number/ trend over a period of time. Going up = improving fitness, going down = decreasing fitness over time.
                                    Brad_Olwin Moderator @OutdoorMan
                                    @OutdoorMan said in VO2Max and walking/hiking:
                                    @Tomas5 By definition it’s maximal oxygen consumption and maybe I am uneducated, but you improve it by reaching a certain percentage of you max HR, by running/cycling intervals, hiit, anything that brings your heart rate up for a certain amount of time. At least this is how I do it. Certainly not by walking. Maaaybe hiking uphill. For me measuring it for sports other than running or cycling doesn’t make sense. But that is my opinion, I am not arguing.
                                    So, I think here for a trained individual the only way to improve VO2M is to exercise above VO2M. That is the case for me and for @OutdoorMan. I probably am a minority here, just about 69y old with a VO2M in the low to mid 50s (watch says 47-50). I train 11-15h per week with 2-3h of body weight and the rest trail/mountain running or SkiMo.
                                    Individuals with no or low training history will have a low VO2M and thus, the walking is likely providing an estimate that can be used for improvement. However, unless the untrained individual does higher intensity cardiac work (begin running or walking steep hills, etc) there will be no change or improvement in the VO2M estimate. Because of this, I see why Suunto and other manufacuturers (Apple, Garmin, Coros, etc.) provide these estimates.
                                    The idea behind this is to improve cardiac fitness. @OutdoorMan (depends on age) may be able to improve VO2M, for me I cannot as I peaked years ago and as I age improving VO2M is simply not possible. I am trying to hang on to what I have.
                                    More importantly, if you are seeking to improve cardiac fitness and you are untrained, observing VO2M trends is a good idea and improving the number will improve your health.
                                    For example @Tomas5 here is my graph. The Race2 should give you values walking. I will try to test a walk today. As you can see my values are flat for VO2M.
                                    Tomas5T OutdoorManO 2 Replies Last reply Reply Quote 3
                                    • Tomas5T Offline
                                      @Brad_Olwin thanks 🙂
                                        @Tomas5 I added my graph so you can see it. I’ll test walking on Race2 today.
                                        • Tomas5T Offline
                                          @Brad_Olwin last 3 days i did short but quick 5km hikes, 2,5km up hill in quick pace. I was in 3rd or 4th zone even in 5th. But yes it was mentioned hiking doesn’t count. And when i track walking usually i have only zone 1. Thats maybe reason why watch doesn’t measure at all.
                                          I can track it next time as walk. Until now i used waling only for activity in city (commute tu work) but in hills i always tracked hiking.
                                          Brad_OlwinB CHRGBRC 2 Replies Last reply Reply Quote 0
                                            @Tomas5 Two solutions….track as trail run if you are on trails or walk as you suggested. That should give you the VO2M. I don’t know if Trekking works either.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
