    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Wrong elavation gain- Running&Hiking
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    4 Posts 3 Posters 431 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Veronika DonáthováV Offline
      Veronika Donáthová
      Hello, i would like to ask if anyone else have problem with wrong elavation gain in activities like running, hiking and climbing. Few days ago i was in holiday with my fiancee, he also owns 9 peak pro watch and in same activities We had different data about elavation gain. My elavation was about 800-1000m higher than his (and his was the right one). Thx
      C inkognitoI 2 Replies Last reply Reply Quote 0
      • C Offline
        cheetah694 Bronze Member @Veronika Donáthová
        @Veronika-Donáthová Do you go by barometer or GPS? There is a setting in the app, probably either one of you have it set up differently.
        Suunto 9 Peak Pro
        inkognitoI 1 Reply Last reply Reply Quote -1
        • inkognitoI Offline
          inkognito Platinum Member @Veronika Donáthová
          @Veronika-Donáthová I’d suggest trying to clean the barometer holes. You could let the watch soak in lukewarm water for about 15 minutes, then perhaps use a soft toothbrush or let water run gently over the area. The key is to be very gentle and not insert anything deep inside!
          Also, if you could post the elevation chart, it might give us a clue – are there any obvious spikes, for instance?
          SV: fingers crossed :D
          S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
          Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
          Despite some pretty bad luck, I still love Suunto!
            inkognito Platinum Member @cheetah694
            @cheetah694 That setting should relate to the Suunto app only (for when you record an activity with the app, not your watch) and shouldn’t matter for exercises recorded with a watch. The watch uses the barometer all the time and constantly uses the FusedAlti algorithm to automatically calibrate it with GPS.
            • First post
              Last post
            Suunto Terms | Privacy Policy
