    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Phantom vibrations
    Scheduled Pinned Locked Moved Watches
    21 Posts 12 Posters 4.8k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • sky-runnerS Offline
      sky-runner Platinum Member
      Recently my watch (Race) has been vibrating a lot - both in smartwatch mode and during activities. Many times when that happens I look at the display and there is nothing that would indicate why it vibrated. For example, only this morning this happened at least a dozen times.
      I wonder if it is only me who experiences this? It should absolutely not vibrate unless there is a visual notification at the same time. Needless to say that this must be affecting the battery life too.
      Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
      Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
      Brad_OlwinB S 2 Replies Last reply Reply Quote 0
      • SquirrelS Offline
        Squirrel Silver Members
        Could be due to nearby BT sensors. My recent experience in this thread: https://forum.suunto.com/post/174940
        Race S
        sky-runnerS 1 Reply Last reply Reply Quote 0
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @sky-runner
          @sky-runner I had this happen and no reason why. Soft reboot and was gone. If it happens again I will file a bug.
          Vector/T6c/Vertical 2 Ti
            sky-runner Platinum Member @Squirrel
            @Squirrel Yes, I think it is quite possible that vibrations were triggered by the BT sensor. Today it vibrated when I walked towards my desk at work or away from it. At my desk there was a backpack with Coros HR sensor inside. This happened within an hour of me finishing a run, but didn’t happen later in the day.
            jjpazJ 1 Reply Last reply Reply Quote 0
            • jjpazJ Offline
              jjpaz Bronze Member @sky-runner
              @sky-runner It happens when the watch detects a previously synced BT device (that’s the reason it happens after your run, the armband is still powered on and the watch detects it). When the armband is powered off the vibration dissapears. It seems that BT discovery process is still running in backplane (and also draining battery, another posted bug).
              Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
              Brad_OlwinB sky-runnerS 2 Replies Last reply Reply Quote 0
                Brad_Olwin Moderator @jjpaz
                @jjpaz That was not the case for my experience AFAIK. I have HR belts that are inactive unless on the body.
                  sky-runner Platinum Member @Brad_Olwin
                  @Brad_Olwin in my case it was Coros HR armband.
                  I think another source for phantom vibrations is notification about upcoming climbs or descents. Many times vibrations happened right before a climb or descent but I didn’t see the actual notification. Perhaps the disappears very quickly because it comes up too late.
                  T 1 Reply Last reply Reply Quote 0
                    sky-runner Platinum Member @jjpaz
                    @jjpaz said in Phantom vibrations:
                    Yes, my impression is that the battery was used more quickly recently, perhaps even surprisingly quickly.
                    • Tami999T Offline
                      Tami999 Silver Members
                      Thanks for this thread. I had same situation few times and I thought it just my mind cheating me 😄
                      • T Offline
                        The_77 Silver Members @sky-runner
                        @sky-runner from memory before a proper red ascent/green descent, there is a vibration 50m beforehand. If you’re on the climb screen at the time, it shows the distance counting down at the top, but if not, it just vibrates.
                        Suunto Spartan Trainer Wrist HR / 9PP Refurb
                          sky-runner Platinum Member @The_77
                          @The_77 said in Phantom vibrations:
                          That might be one of the reasons. Personally I think the watch should never vibrate without having a visual notification at the same time. That is just confusing!
                          • sartoricS Offline
                            sartoric Moderator
                            I had this too, and it went away with a restart.
                            My suspicion is that it has something to do with offline map updates.
                            I got the “map update” screen while starting charging yesterday with no update ongoing (AFAIK).
                            After the firmware install, I kept getting that notification every time I was checking the map. Gone after the restart.
                            Hope it won’t bother me this we in Berlin 😁
                            SVTS - 2.50.28
                            SSSWHR BARO Amber - 2.8.32
                            Samsung A5 2016 - Android 7.0
                            Suunto App Android 6.11.12 beta
                            • T Offline
                              the_mr_allen
                              Also seeing this mainly in a workout or walk. I think it’s giving HR zone notifications even if you’ve set it to “no target”. This wasn’t happening until last update on both my Race S and new Race 2.
                              • OutdoorManO Offline
                                OutdoorMan Silver Members
                                Hello, I noticed the same on my watch. I think it happens when I grab a HR strap and it looks like it connects to the watch.
                                • L Offline
                                  loopylou72
                                  Yes my watch is vibrating and beeping continuously today. Also did it a few days ago. I think it started after I repaired my Stryd. I have to switch to airplane mode to stop it. The beeping happens with no activity mode selected. My HR monitor is off. Any suggestions? Super annoying. Really do not like the changes to device pairing with latest update.
                                  • S Offline
                                    Stavrogin @sky-runner
                                    @sky-runner I have not had the chance to test this, but I am wondering if this is because BT is always in discovery mode now. I also had weird vibrations with the update on my Race S. (That coupled with disconnecting HRM during activities)
                                    I have since turned off the BT discovery and hoping that the random vibes will go away.
                                    This would also explain why HRMs would randomly not work if there was more than one HRM active during an activity. Just speculation, but will try.
                                    Suunto Vertical, Race, Race 2, Race S and Run. Rocking the Vertical 2 Titanium at the moment.
                                    Garmin: Fenix 7X, Epix Pro 51mm, Forerunner 265.
                                    Coros: Pace Pro, Apex 4
                                    VoiGASV 1 Reply Last reply Reply Quote 0
                                    • VoiGASV Offline
                                      VoiGAS Gold Members @Stavrogin
                                      @Stavrogin How did you turn off Bluetooth discovery?
                                      Race S
                                      Ambit3 Vertical
                                      Eon Core
                                      SquirrelS 1 Reply Last reply Reply Quote 0
                                      • SquirrelS Offline
                                        Squirrel Silver Members @VoiGAS
                                        @VoiGAS said in Phantom vibrations:
                                        Look under Settings > Connectivity
                                        Race S
                                        VoiGASV 1 Reply Last reply Reply Quote 2
                                        • VoiGASV Offline
                                          VoiGAS Gold Members @Squirrel
                                          @Squirrel Thank you! I did it and can still sync to the app and connect my HR belt. So what is this settings meaning?
                                          Race S
                                          Ambit3 Vertical
                                          Eon Core
                                          OutdoorManO 1 Reply Last reply Reply Quote 0
                                            OutdoorMan Silver Members @VoiGAS
                                            @VoiGAS this enables that other devices which are not paired to your watch yet can see your watch as an available Bluetooth device. If you turn it off, your already paired devices will work normally, but nobody will be able to see your watch as an available BT connection.
                                            VoiGASV 1 Reply Last reply Reply Quote 1
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
