    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Sync issue - error loading data - sync not fully completed
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    sync issue 9 peak pro
    117 Posts 43 Posters 14.0k Views 47 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • L Offline
      Lorse
      Dear, recently my daily runs are no longer synced “full”, meaning when clicking on the map it says “error loading data” as well as no further upload to i.e. mapmyrun seems possible. App completely removed (cache cleared) and reinstalled didn’t fix this issue. Neither worked using the app on another phone. Commenting on my workout isn’t possible as well. Any idea what might have been blocking here? Thx! Lorenz
      Łukasz SŁ 1 Reply Last reply Reply Quote 0
      • flo7zF Offline
        flo7z Silver Members
        I have some problems loading in the app my run activities too, the other activities load just fine
        Florian Z.
        Suunto 9 Peak Pro
        Suunto Wings
        Suunto D4
        Suunto Ambit 3 Peak
        • Łukasz SŁ Offline
          Łukasz S @Lorse
          @Lorse I have this problem too. Downloading .fit file and exporting .gpx or .kml file does not work either.
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @Łukasz S
            @Łukasz-S try to reinstall the app (if the activities are still on the watch, they’ll resync)
            Watch: Suunto Vertical Ti
            Blog: isazi's home
            M Łukasz SŁ 2 Replies Last reply Reply Quote 0
            • M Offline
              misu763 Bronze Member @isazi
              @isazi
              How long the watch keeps the activities? Does it save them for a while even if the logbook widget isn’t active?
              S9PP Ti Slate
              • Łukasz SŁ Offline
                Łukasz S @isazi
                @isazi As Lorse writes, reinstalling app don’t fix the issue. All gps activities after 28.06.2025 synchronizing with data error. Indoor activities without gps works fine. This problem also occurs with other users of 9PP
                  Dimitrios Kanellopoulos Community Manager
                  @Łukasz-S said in Sync issue - error loading data - sync not fully completed:
                  is this ios or android or it does not matter:?
                  Creator of Quantified-Self.io
                  youtube.com/c/dimitrioskanellopoulos
                  https://instagram.com/dimitrioskanellopoulos
                  https://www.strava.com/athletes/7586105
                  • Łukasz SŁ Offline
                    Łukasz S @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos I don’t know. I have an android.
                    I know that the issue affects devices after the last firmware update and without it.
                    In my case, I did not make any changes at that time. I did not install the latest firmware update of the watch, nor the Suunto app, nor the Android update
                    • Ivan SmorkalovI Offline
                      Ivan Smorkalov
                      I have same problem. App for android. 9PP
                        Hi please be specific about what version of the app
                        Łukasz SŁ Ivan SmorkalovI flo7zF 3 Replies Last reply Reply Quote 0
                        • Łukasz SŁ Offline
                          @Dimitrios-Kanellopoulos suunto app ver 5.3.7, watch 2.40.44
                            Could please pm me your usernames ?
                            DRezvoffD 1 Reply Last reply Reply Quote 0
                              Ivan Smorkalov @Dimitrios Kanellopoulos
                              @Dimitrios-Kanellopoulos said in Sync issue - error loading data - sync not fully completed:
                              suunto app v. 5.3.7, watch - both 2.40.44 and 2.43.12
                              • P Offline
                                piotr.bdz
                                Hi ! I have the exact same problem with an important race activity from Sunday. I have contacted Suunto support and I have no answer so far.
                                • DRezvoffD Offline
                                  DRezvoff @Dimitrios Kanellopoulos
                                  @Dimitrios-Kanellopoulos Good afternoon!
                                  I also have a problem with data uploading! The Suunto app shows the workout, but it doesn’t upload to Sport Tracker, Strava, Relive, or Komoot. I’ve restarted my phone, reconnected to the services, and reinstalled the app, but it hasn’t helped.
                                  nikname - drezvoff
                                  Suunto 9 Peak Pro Titanium
                                  Suunto Spartan Sport WHR
                                  Sony Xperia 1, Android 10.
                                  isaziI DRezvoffD 2 Replies Last reply Reply Quote 0
                                  • isaziI Offline
                                    isazi Moderator @DRezvoff
                                    @DRezvoff you should never disconnect/reconnect to third parties in such cases, because the vast majority of third parties will not process activities recorded before you connected to them, so your activities may never sync now.
                                    To check where the problem is there is a simple test. If you see your activity in Suunto App, try to download the FIT file. If it works, the data is in the Suunto cloud and there is a problem in the Suunto-3rd parties connection. If the download of the FIT file does not work, then the problem is between the app and Suunto cloud.
                                    Blog: isazi's home
                                      Hi all we see the issue. Hang tight a solution is implemented.
                                      S 1 Reply Last reply Reply Quote 0
                                        Are you using some suunto plus ?
                                        P Łukasz SŁ 2 Replies Last reply Reply Quote 0
                                        • P Offline
                                          piotr.bdz @Dimitrios Kanellopoulos
                                          @Dimitrios-Kanellopoulos yes, in the case of my bugged activity I had “Hr zones duration” and also a gpx itinerary loaded.
                                          • flo7zF Offline
                                            flo7z Silver Members @Dimitrios Kanellopoulos
                                            By me , it just does not load and I get an error message in the app.
                                            I’m on iOS (SA 2.46.3) and I have tested to revert back to FW ( so tested with 2.43.12 and 2.40.4) on my S9PP and this does not load at all.
                                            And I am using some Suunto Plus.
                                            I created a new sport mode based on running and it loads just fine, even by using some Suunto Plus.
                                            Florian Z.
                                            Suunto 9 Peak Pro
                                            Suunto Wings
                                            Suunto D4
                                            Suunto Ambit 3 Peak
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
