    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Movesense not compatible?
    Scheduled Pinned Locked Moved Suunto Race
    9 Posts 6 Posters 1.4k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • E Offline
      enneo Bronze Member
      I recently found my good old Movesense BT sensor, that I was using with my Ambit 3 and tried to use it with my Race.
      The sensor correctly pairs but then when I start recording I get only a graied out symbol of the HR belt with no HR readings.
      The sensor I am talking about is:
      I have also changed the battery and then asked my father for his Movesense (again aging in his drawer) but I am getting the same result.
      Anyone knows if it is no longer supported?
      Ambit 3
      9 Baro
      Race Ti
      A 1 Reply Last reply Reply Quote 0
      • Stefano M64S Offline
        Stefano M64 Silver Members
        did you wear the belt?
        Suunto Vector . Vector HR . Core . Race & Race S
        E 1 Reply Last reply Reply Quote 0
        • E Offline
          enneo Bronze Member @Stefano M64
          @Stefano-M64 Yep, with water and tested both of them
          Ambit 3
          9 Baro
          Race Ti
          • A Offline
            Artus Diver @enneo
            @enneo said in Movesense not compatible?:
            Watch this video from the link below, maybe it will help you 🙂
            A Great Trick Solving your Heart-Rate Strap Problem
            Suunto Viper
            Suunto HelO2
            Suunto Ambit 3 PEAK
            Suunto 9 Baro Titanium
            Suunto Vertical
            Suunto Vertical Solar
            Suunto Race 2
            • suzzloS Offline
              suzzlo Moderator
              Make sure it’s not in use by other watch/app
              Suunto: Race, S9Peak, Spartan Sport Wrist
              Garmin: FR745, Edge 530
              SA topics:
              • Guides - https://forum.suunto.com/tags/guides
              • E Offline
                enneo Bronze Member
                @Artus-Diver said in Movesense not compatible?:
                Very interesting input, I am measuring 1.5kΩ so the belt is not worn out!
                I was about to buy a new one, thanks for the feedback
                @suzzlo said in Movesense not compatible?:
                Make it’s not in use by other watch/app
                Not paired with my phone and both Ambit 3 and 9 Baro are off
                Ambit 3
                9 Baro
                Race Ti
                Mff73M 1 Reply Last reply Reply Quote 1
                • EgikaE Offline
                  Egika Platinum Member
                  no idea why it is not properly connecting for you, but it definitely is compatible.
                  Let’s continue tracking down your issue.
                  Flight mode off? (there are two switches)
                  HR belt selected in activity pre start options?
                  • Mff73M Offline
                    Mff73 @enneo
                    @enneo
                    Did you try to pair it/them to any other apps or devices? Even the Suuntoapp itself…
                    You may also change the battery again (some are weak even if new, just in case).
                    SSU (retired), SV1, SV2
                    Wife : S9PP
                    SA: Always the latest beta :)
                    Android + Galaxy S205G
                    • E Offline
                      enneo Bronze Member
                      @Egika said in Movesense not compatible?:
                      Yes to both!
                      @Mff73 said in Movesense not compatible?:
                      @enneo
                      That helped! After connecting to the Suunto App I was able to get the HR reading starting the activity.
                      But I also noticed that connected with the Suunto App both sensors give me ~80bpm while the watch is ~60bpm and I am measuring ~60bpm manually.
                      I guess I will have to toss both Movesense sensors… In the end electronics does not age well, unlike a good red wine!
                      Ambit 3
                      9 Baro
                      Race Ti
                      Register Login
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
