    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Watchfaces Drop 2025 Q1
    Scheduled Pinned Locked Moved SuuntoPlus™ WatchFaces
    115 Posts 45 Posters 35.3k Views 43 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Olaf GottschalkO Offline
      Olaf Gottschalk Bronze Member @pavel.samokha
      @pavel-samokha something is definitely broken with the latest update and watch faces.
      The App behaves weird, I cannot install some watch faces and whenever I do anything in the App, the selected active watchface of the Race is lost and it falls back to its default digital watch face. So sad to see problems with firmware updates so often.
      I want my Modern Analog watchface back working.
      This is what a “working” watch face looks like in the App. It is installed and I can make it the active watchface using the blue big button.
      alt text
      This is what Modern Analog looks like (and many others): you can “install” them but you cannot select them - not here and not on the Race itself. It’s not on the list of watch faces…
      alt text
      What should we do??
      pavel.samokhaP 1 Reply Last reply Reply Quote 0
      • pavel.samokhaP Offline
        pavel.samokha @Olaf Gottschalk
        @Olaf-Gottschalk it could be the watchface number limit. Try to go to your installed watchfaces list. Uninstall some you don’t need. Sync app and watch.
        Opinions expressed are solely my own and do not express the views or opinions of my employer
        S Olaf GottschalkO M 3 Replies Last reply Reply Quote 0
        • S Offline
          SailingP @pavel.samokha
          @pavel-samokha I have opposite issue. I have the watchface Modern analog installed in watch, but it is missing in both app and store.
            pavel.samokha
            Two more watchfaces are published
            safariS Inge NallssonI 2 Replies Last reply Reply Quote 13
              @pavel-samokha said in Watchfaces Drop 2025 Q1:
              Nope. No watch faces anymore. As I said, so have already deleted ALL watch faces.
              Just now have gone through resetting the device to its defaults and went through onboarding again with exactly the same result.
              It is impossible for me to get this watch face active.
              Nothing installed. Fresh watch. Went to the store, wanted this face. Now it’s looking as if installed, but nothing on the watch itself, there is just a bright yellow screen telling me to go to the store to download watch faces.
              No blue button to activate that watch face either.
              What else to do?
                @Olaf-Gottschalk record a Suunto App screen video:
                • Go to your watchfaces library and shows that there are watchfaces there
                • Then in SA go to your main watch settings screen, click sync and wait till sync process finish
                Olaf GottschalkO 4 Replies Last reply Reply Quote 0
                  Done everything you described.
                  Here’s the SA screen showing the faces:
                  alt text
                  But this is my watch:
                  alt text
                  And here the “list” after the yellow note:
                  alt text
                  I did of course sync many, many, many times today.
                  Thanks to the reset I already lost every setting, connected device, etc.
                  I am kind of extremely annoyed right now.
                    And here, also for you a video showing it love:
                    https://photos.app.goo.gl/9tBHhCBWpd4XRj1Y9
                    It is impossible to select the “installed” faces and on the watch it still claims that none are installed.
                      @pavel-samokha logs are also sent to support. DM me for my account email.
                        @pavel-samokha not-so-fun-fact: none of the new watch faces work. 😞
                        • M Offline
                          mabe2k Bronze Member @pavel.samokha
                          @pavel-samokha very nice. “Forest Ranger” looks awesome.
                          Just the Always on display could show a little more details.
                          • EgikaE Offline
                            Egika Platinum Member @Olaf Gottschalk
                            @Olaf-Gottschalk try two things:
                            Disable and enable BT on the watch and also on the phone.
                            Then sync again.
                            If this does not help, uninstall and reinstall the app.
                            Olaf GottschalkO 1 Reply Last reply Reply Quote 0
                              Olaf Gottschalk Bronze Member @Egika
                              @Egika said in Watchfaces Drop 2025 Q1:
                              Then sync again.
                              Tried this. Sadly, doesn’t solve the problem.
                              I did reinstall the App. No change in behavior.
                              Here is the video proof: https://photos.app.goo.gl/UQ44dr4LrEm1v9NM6
                              When playing the the menus, there are so many inconsistencies in what is installed, why it cannot be selected to be used and some Infos are contradicting themselves on the same screen, e.g. the list only shows one watch face while the other (Modern Analog) also claims to be installing (there is an uninstall option).
                              Whenever I play around and sync, the active watchface breaks on the watch and falls back to the default digital watch face.
                              Now. What else could I possibly do?
                              • the watch has been reset to factory settings
                              • the app was uninstalled and reinstalled
                              • synced a trillion times
                              • BT disabled and enabled
                              • safariS Offline
                                safari @pavel.samokha
                                hello
                                wouldn’t it be better if there was a completely empty space instead of a hollow ring when you select “empty” in complications?
                                (Rangelands analog)
                                then it will have a complete analog appearance with the white color
                                history:
                                Suunto Vertical 2 titanium Black
                                suunto vertical solar titanium
                                suunto 9 baro
                                suunto ambit 3
                                suunto ambit 2
                                Suunto Heart Rate Belt
                                Suunto Smart Heart Rate Belt
                                suunto App: apple iphone 14 pro
                                L 1 Reply Last reply Reply Quote 6
                                • marbjoM Offline
                                  marbjo
                                  Is this expected behaviour? It is not completely centered and moves around every minute. I think it would be better to stay in the middle. 1000012824.jpg
                                  Suunto Ocean (2024)
                                  Suunto D4f (2018)
                                  Suunto t3d (2011)
                                  • EgikaE Offline
                                    Egika Platinum Member @marbjo
                                    @marbjo yes. Designed this way to prevent the screen from burning in
                                    M 1 Reply Last reply Reply Quote 4
                                    • Inge NallssonI Offline
                                      Inge Nallsson @pavel.samokha
                                      There was a bit of a snafu when trying to install these two on my Race S. Going to SuuntoPlus Store --> Watch Faces and entering Forest Ranger Analog and Rangelands Analog I could mark them by clicking the little blue outline of a ‘bookmark’ in the upper corner. And a text about them being added to my list came up. But then going back to “My SuuntoPlus watch faces” nothing new was visible. I tried several times with different entry points including going from *inside of the ‘list’ to the ‘store’ but marking/unmarking made no difference.
                                      At long last I just clicked on the “INSTALL ON WATCH” bottom bar in the ‘store’ and went to the ‘main page’ showing a picture of the watch and clicked on “SYNC NOW”. It used more than the normal time to sync “SuuntoPlus” so I figured the new faces were being added to the watch.
                                      And that was also the case - them having been added below the default Race S watchface in the list on the watch itself. After clicking on the watch icon in the SA and having the usual ‘sync’ update messages on that page, the two new watch faces were visible in the “My SuuntoPlus watch faces” list, where I successfully clicked UNINSTALL on the Rangelands Analog - since it was too basic - and it still remaining in that list with an INSTALL option.
                                      Suunto Race S
                                      EgikaE 1 Reply Last reply Reply Quote 1
                                      • EgikaE Offline
                                        Egika Platinum Member @Inge Nallsson
                                        @Inge-Nallsson yeah, this two-stage process (bookmark list in app vs. actually installed on the watch) can be a bit confusing.
                                        I guess this has been introduced since the storage for watch faces in the watch itself is limited.
                                        So you can mark your favourites in the app and select out of these which to have in the watch.
                                        Inge NallssonI 1 Reply Last reply Reply Quote 1
                                        • Stefano M64S Offline
                                          Stefano M64 Silver Members
                                          Really like the Forest Ranger Analog, the best among the analogs for me 👍
                                          Suunto Vector . Vector HR . Core . Race & Race S
                                            Inge Nallsson @Egika
                                            @Egika Ah, I believe you misunderstand. There is some kind of bug, since normally you can bookmark a watch face in the ‘store’ and it immediately shows up in the ‘list’ of your installed and/or bookmarked faces. This is the first time the bookmarking action in the store needed physical installation to the watch before those faces (after a sync) showed up in the “My SuuntoPlus watch faces” list.
                                            Suunto Race S
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
