    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Altitude/elevation fallback to GPS
    Scheduled Pinned Locked Moved Watches
    21 Posts 6 Posters 2.3k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Panagiotis KritikakosP Offline
      Panagiotis Kritikakos Gold Members
      Can’t find if this has been discussed again, but now that I face issues with the baro sensor and I don’t get altitude/elevation readings on S9P, was thinking that having an option to use GPS for altitude readings would be handy as an alternative option.
      Suunto Vertical Titanium Solar | 9 Peak | Ambit 3 Peak | 3 | Gekko
      Garmin eTrex 30x
      M 1 Reply Last reply Reply Quote 0
      • M Offline
        maszop Bronze Member @Panagiotis Kritikakos
        @Panagiotis-Kritikakos The GPS data will be so incorrect as to be essentially useless.
        Panagiotis KritikakosP 1 Reply Last reply Reply Quote 0
          Panagiotis Kritikakos Gold Members @maszop
          @maszop Not sure about that. In the past were watches from Suunto with non-baro (Suunto 9) and there are still GPS devices in the market that use GPS for altitude/elevation. Surely much more accurate than a faulty baro sensor 🙂 Also, considering how easily baro is affected on specific watches due to wind and rain, GPS would be more accurate. Right now, I’m relying on other platform’s mapping model data for getting my activity’s elevation but that’s post-activity which doesn’t help during the actual activity.
          Garmin eTrex 30x
          • M Offline
            @Panagiotis-Kritikakos Outside of very strong winds, Suunto altimeters are doing great.
            Other manufacturers are doing well also in strong wind, so it’s worth pushing Suunto to improve it.
            Using GPS to correct altimeter errors is a road to nowhere.
            Panagiotis KritikakosP Brad_OlwinB 2 Replies Last reply Reply Quote 0
              @maszop Agreed. The point here is not that baro is not doing good. I understand also specific conditions in relation to design etc. But as mentioned, I’m mostly talking about what could help a faulty baro sensor that delivers nothing. If I don’t send my 3.5year old watch for service (which would cost surely enough money that perhaps do not justify the fix) then I have zero altitude/elevation data. And by the way, FusedAlti is there. It is being used for fixing, why not for complete relying on faulty sensor?
              Garmin eTrex 30x
              • Brad_OlwinB Offline
                Brad_Olwin Moderator @maszop
                @maszop said in Altitude/elevation fallback to GPS:
                What @maszop said is spot on. GPS only is useless in my opinion as well. I have tested several watches Suunto 5 Peak and Suunto 5. Elevation gain/loss is not good.
                Vector/T6c/Vertical 2 Ti
                Panagiotis KritikakosP 1 Reply Last reply Reply Quote 1
                  Panagiotis Kritikakos Gold Members @Brad_Olwin
                  @Brad_Olwin I’ll repeat myself. Right now, I have no elevation because the sensor, or the software, do not actually work. That’s why I said “fallback”. What is more inaccurate than no data? Anyway. Close the thread if you wish.
                  Garmin eTrex 30x
                  Brad_OlwinB thanasisT 2 Replies Last reply Reply Quote 0
                    Brad_Olwin Moderator @Panagiotis Kritikakos
                    @Panagiotis-Kritikakos I think it requires different firmware as well. Not sure if this is present in watches with barometers
                    • thanasisT Do not disturb
                      thanasis Bronze Member @Panagiotis Kritikakos
                      @Panagiotis-Kritikakos there is a replacement watch on your desk 😉
                      • Stefano M64S Online
                        Stefano M64 Silver Members
                        from GPS the actual altitude can be derived with a certain known error, depending on the accuracy of the 3D fixing. Barometric altimeters give pretty accurate altitude readings, under the condition that no significant atmospheric pressure variations occur, otherwise they can be also wildly wrong, and there is no way to know if and how much the altitude is wrong. The longer the activity, the more probable that atmospheric pressure changes occur, especially on mountains.
                        Suunto Vector . Vector HR . Core . Race & Race S
                        • M Offline
                          maszop Bronze Member @Stefano M64
                          @Stefano-M64 said in Altitude/elevation fallback to GPS:
                          For many years now, barometric altimeters have been doing very well even with large changes in atmospheric pressure.
                          In the case of Suunto, the only problem may be strong wind. Suunto copes very well with the rest of the factors, even during very long activities.
                          Stefano M64S 2 Replies Last reply Reply Quote 0
                            Stefano M64 Silver Members @maszop
                            How? the altitude readings are indirect measurements based on the variation of the atmospheric pressure at different heights. A barometer simply cannot be “aware” if such variations are caused by changing in the elevation or by the weather conditions. Sometimes my SR shows that I’m lying some tens of meters below the sea level and I’m not a scuba diver!
                            Mff73M M 2 Replies Last reply Reply Quote 0
                            • Mff73M Offline
                              Mff73 @Stefano M64
                              Suunto calls it : Fusedalti.
                              Baro altitude correction thanks to GPS measurement. Small variation are handled with baro, and potentially drift tendency or other calibration, with GPS (they are taking GPS “precision” to ensure that corrections are made when GPS altitude is significantly good.
                              Non speaking about wind, thus baro peaks, which are for sure another story.
                              SSU (retired), SV1, SV2
                              Wife : S9PP
                              SA: Always the latest beta :)
                              Android + Galaxy S205G
                              thanasisT Stefano M64S 2 Replies Last reply Reply Quote 0
                                thanasis Bronze Member @Mff73
                                @Mff73 well do the following … during an activity try to submerge the watch into water 🙂 while being stationary you may have a variation of several hundred meters . I did this while cross a 5m wide river and it showed as if I had 2000m ascent and descent 🙂 . Had it worked properly it could have used other sensors as well and limit the ascent -descent indication to a less arbitrary number
                                  Stefano M64 Silver Members @Mff73
                                  @Mff73 said in Altitude/elevation fallback to GPS:
                                  I was talking about “pure” barometric altimeters, of course FusedAlti should avoid wrong readings, but not always works as expected
                                    Brad_Olwin Moderator @thanasis
                                    @thanasis said in Altitude/elevation fallback to GPS:
                                    The sensor is sensitive to changes in pressure and measuring very small changes. Water is essentially a sledgehammer for the sensor. The deeper you go the worse the issue. Water flowing across or into the sensor area will cause this. When you use snorkel mode or mermaiding the barometric measurements change and the pressure underwater is measured. It is difficult to have a single sensor do both.
                                    I don’t know how the Ocean or Fenix 8 watches address this issue.
                                    • M Offline
                                      @Stefano-M64 It just works. At least in the case of Garmin and Suunto. These are more complex algorithms than the primitive calculation of pressure differences.
                                      What you are writing about does occur in Hammerhead (Karoo) equipment, where there are simply raw pressure values ​​converted to altitude, and in this case it works very poorly.
                                        I was driven in error by your sentence, “barometric altimeters” rely only on atmospheric pressure changes. Suunto’s FusedAlti uses the GPS to correct drifts in the barometer not related to altitude changes, so it’s a mix between barometric and GPS altimeter (but not always works as expected). The statement I read in this forum several times, that the Barometric altimeter are better then GPS’s, is basically wrong.
                                        • M Offline
                                          @Stefano-M64 Altimeter data from GPS alone is usually useless. There’s no point arguing about it.
                                          Even Strava automatically rejects it and replaces it with its own data.
                                          Stefano M64S 1 Reply Last reply Reply Quote 0
                                            The point here is not if GPS is good or better than baro. I think all have their pros and cons and it’s good to combine them when needed as with FusedAlti. My point is that it would be handy/useful to have it as a full fallback when there’s problem with baro.
                                            @thanasis hm… I’ll check it out when I get back 🙂
                                            Garmin eTrex 30x
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
