    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Baro / temperature sensors issue
    Scheduled Pinned Locked Moved Suunto 9 Peak
    8 Posts 4 Posters 2.2k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Panagiotis KritikakosP Offline
      Panagiotis Kritikakos Gold Members
      For the last couple of weeks, the watch suddently stopped reading the correct altitute and temperature. During activities there is no elevation recorded. It just slightly changes along the course, for instance recording 100m of altitude difference instead of 1000. When not on exercise altitude is also not adjusting. The same with temperature, it is not displayed at all. I have tried multiple soft resets and the readings seem to get back to normal but after some minutes they are wrong again with temperature not displayed at all. The same happens with execrcise recording. I have lastly tried a hard reset with no result. Can’t really understand if this is a software or a sensor issue.
      Another thing to note is that when I load a track and use it during an exercise, the preloaded ascent is correctly decreased as I progress with finally reaching the total ascend that was calculated. Don’t know if this calculation uses the baro sensor or not but it made me wonder.
      I wouldn’t bother much for the temperature, but elevation is an important reading both on cycling and mountains. Does anybody have any advices?
      Suunto Vertical Titanium Solar | 9 Peak | Ambit 3 Peak | 3 | Gekko
      Garmin eTrex 30x
      Mff73M 1 Reply Last reply Reply Quote 0
      • Mff73M Online
        Mff73 @Panagiotis Kritikakos
        @Panagiotis-Kritikakos said in Baro / temperature sensors issue:
        The sensor is responsible for both temp and pressure=altitude.
        And it seems definitively faulty. No temp is a bad sign.
        SSU (retired), SV1, SV2
        Wife : S9PP
        SA: Always the latest beta :)
        Android + Galaxy S205G
        Panagiotis KritikakosP 1 Reply Last reply Reply Quote 0
          Panagiotis Kritikakos Gold Members @Mff73
          @Mff73 Indeed, I see the relation is obvious. The watch also seems to be restarting itself out of the blue when not recording an exercise. I haven’t noticed any pattern though. Perhaps if the sensor got issues it causes these crashes.
          Garmin eTrex 30x
            For the sake of the post, the watch keeps restarting itself, went into service mode, reported 1403 errors multiple times. Keeps working but with big problems. Will probably send it for service.
            Garmin eTrex 30x
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @Panagiotis Kritikakos
              @Panagiotis-Kritikakos A good idea, seems like there is a hardware issue
              Vector/T6c/Vertical 2 Ti
                The regional authorized service center, after getting in touch with Suunto, reported that there is a circuit problem that causes the issues and can’t be fixed. Suunto offered to send the device for destruction and provider S9PP at 250EUR. S9PP is out of the equation, so now the question is which watch should be next.
                Garmin eTrex 30x
                2 1 Reply Last reply Reply Quote 0
                • 2 Offline
                  2b2bff Gold Members @Panagiotis Kritikakos
                  @Panagiotis-Kritikakos Race S is the successor in a similar size I think. Unless you have to have the MIP display. Then there is only the Vertical left.
                  Suunto Race S
                  Garmin Epix Pro
                    Vertical it is 🙂
                    Garmin eTrex 30x
                    Register Login
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
