    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Pairing Garmin HRM-Pro Plus with Suunto Race
    Scheduled Pinned Locked Moved Suunto Race
    6 Posts 5 Posters 2.4k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Dam.GloD Offline
      Dam.Glo
      Hi everyone,
      I recently purchased the Garmin HRM-Pro Plus heart rate monitor and I’m trying to pair it with my Suunto Race watch. However, I’m having some trouble getting them to connect via Bluetooth or ANT+.
      Has anyone successfully paired the Garmin HRM-Pro Plus with the Suunto Race? If so, could you please share the steps or any troubleshooting tips that worked for you?
      I’ve tried following the usual pairing process, but so far no luck. Any advice would be greatly appreciated!
      Thanks in advance!
      isaziI Brad_OlwinB 2 Replies Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @Dam.Glo
        @Damian-Głowacki you need to use BLE, ANT+ is not supported by current Suunto watches.
        Blog: isazi's home
        • Brad_OlwinB Online
          Brad_Olwin Moderator @Dam.Glo
          @Damian-Głowacki This should work for BT. I have an HRM Pro that pairs no problem. ANT+ is not supported by Suunto (Owned by Garmin). Check Settings/Connectivity/PairedSensors. Is an HR belt paired? If so did you put on the HRM Pro+ and see if at exercise start screen that an HR belt is connected?
          Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
          Dam.GloD 1 Reply Last reply Reply Quote 0
          • Dam.GloD Offline
            Dam.Glo @Brad_Olwin
            @Brad_Olwin, You’re right. I misinterpreted the connected sensors to the watch. After following the steps according to your instuctions, everything works. Thank you!
            T 1 Reply Last reply Reply Quote 1
            • T Offline
              trotzendorff @Dam.Glo
              Hi there,
              I was wondering if the belt, when paired with the Race, also transmits the extended data—like running efficiency—to the Suunto app. Can you tell me more about that?
              Thanks in Advance
              Florian
              2 1 Reply Last reply Reply Quote 0
              • 2 Online
                2b2bff @trotzendorff
                @trotzendorff first of all those running metrics are only send over ANT+. But even if they would send it over BT as well, I doubt it would be implemented in Suunto firmware. Like the buffering only works with Suunto Smart Belt…
                Suunto Race S
                • First post
                  Last post
                Suunto Terms | Privacy Policy
