    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    suunto race s heart rate issue
    Scheduled Pinned Locked Moved Suunto Race S
    35 Posts 20 Posters 9.4k Views 18 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • E Offline
      erik_ibk
      suunto race s heart rate problems.
      My Suunto no longer records my heart rate, sleep score and so on. It is all set up correctly. Resetting to factory settings only worked for a few hours, after which the same problem occurred. No green lights!! The settings are all correct. With a chest strap, the heart rate recording is fine.
      I need help.
      Thanks Erik
      isaziI E K emilia_vE 4 Replies Last reply Reply Quote 1
      • isaziI Offline
        isazi Moderator @erik_ibk
        @erik_ibk a trick that may or may not work, instead of rebooting, is to start a SPO2 measurement. A firmware update to fix the issue should be released soon.
        Blog: isazi's home
        E 1 Reply Last reply Reply Quote 1
        • E Offline
          erik_ibk @erik_ibk
          @isazi I hope the firmware update will coming soon and fix the issue. A SPO2 measurement failed.
          • E Offline
            erik_ibk @isazi
            @isazi For over a month now, my Suunto has not been working properly. No update. Unfortunately,
            2 1 Reply Last reply Reply Quote 0
            • 2 Offline
              2b2bff Silver Members @erik_ibk
              @erik_ibk have you contacted support?
              Suunto Race S
              Garmin Epix Pro
              GiPFELKiNDG 1 Reply Last reply Reply Quote 0
              • GiPFELKiNDG Offline
                GiPFELKiND Silver Members @2b2bff
                @2b2bff there is a update fix promised… Lets wait this before sent to repair
                If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                2 1 Reply Last reply Reply Quote -1
                • 2 Offline
                  2b2bff Silver Members @GiPFELKiND
                  @GiPFELKiND contacting support is not the same as sending it back. I meant that the community can’t sort his issue out…
                  Suunto Race S
                  Garmin Epix Pro
                  • D Offline
                    disadisa
                    @erik_ibk would you be so kind to share with us info about following items:
                    1. Software version on you race S?
                    2. Version of model number and hardware version?
                    3. Where is manufactured, made in Finland or made in China?
                    Thank you a lot
                    • E Offline
                      erik_ibk @disadisa
                      @disadisa Hi,
                      1. 2.39.20
                      2. OW 233 Serial No. 242210000695
                      3. MADE IN Finland
                      Thanks, Erik
                      ? 1 Reply Last reply Reply Quote 1
                      • ? Offline
                        A Former User @erik_ibk
                        @erik_ibk The “made-in-China” reason has just lost the race.
                        1 Reply Last reply Reply Quote 3
                        • D Offline
                          disadisa
                          @erik_ibk if is not to much for you to send us info. Did you experience wifi connectivity issue on watch? How old is your watch race S? Did you make wifi connection before update to sw version 2.39.20 or initial/first wifi setup was after update 2.39.20. Please check your full hardware list info at this according this topic https://forum.suunto.com/topic/12335/suunto-race-s-wifi-problem-after-update-2-39-20/71
                          Did you try as workaround to revert back to previous software version on watch using hidden menu as proposal from suunto support?
                          Once more thank you for your effort and helping us to find out common issue.
                          • K Offline
                            ksvnix @erik_ibk
                            @erik_ibk said in suunto race s heart rate issue:
                            I need help.
                            Thanks Erik
                            Hi.
                            Same here!
                            Firmware 2.39.20 and about 1 month experience.
                            HR sensor was turned off (no green light) and sleep cycle not tracked at all.
                            M 1 Reply Last reply Reply Quote 0
                            • M Offline
                              mando Bronze Member @ksvnix
                              Me too, race s with latest firmware. I need to power off and on about once a week
                              • Y Offline
                                YannH
                                Hi, I’ve the same issue. I’ve a Suunto Race. Everything is perfect except the heart rate measurement.
                                Not reliable at all.
                                I’ve already resetted the factory setings without any improvement.
                                For instance, last training : 1st hour was perfect around 130 bpm, then the last 3 hours were at 180 bpm which is not possible! same pace rate.
                                I need help
                                Thanks
                                Yann
                                Brad_OlwinB E 2 Replies Last reply Reply Quote 0
                                • Brad_OlwinB Online
                                  Brad_Olwin Moderator @YannH
                                  @YannH Suunto OHR does not work well for me either running or SkiMo. I use a belt. OHR varies for individuals. Even my Apple Watch does not work well for running intervals.
                                  For sleeping 24/7 day use the OHR is great for me.
                                  Vector/T6c/Vertical 2 Ti
                                  • E Offline
                                    Elipsus Silver Members @YannH
                                    @YannH If you notice your BPM reading getting funky, what you can do is stop running for 1 minute, usually your HR goes much lower and “external noises” (like the bumps from running) are non existent, which allows the HR sensor to lock again on the correct beat.
                                    Also, pay attention to the watch placement for optimal HR :
                                    • Place the watch on the “meatier” parts of your wrist (ideally at least one cm before your wirst bone)
                                    • wear it tight enough so that there is no movement
                                    • Make sure you are warm on your wrist, with gloves and stuff, because the cold weather makes your blood vessels constrict on the limb extremities where its not needed, thus make it much harder to read
                                    • F Offline
                                      far-blue
                                      The HR recording on my RaceS stopped yesterday. I didn’t get any sleep score this morning but kind of thought it was just an oddity and didn’t notice the lack of green light but I noticed after my yoga session that there was no HR data and then noticed I was also missing HR data all day.
                                      Checking back in the app, it looks like HR stopped being recorded after I partially charged the watch from 14% to 74% yesterday about 10am. My run yesterday was was fine because I use a belt but the rest of the data is missing.
                                      I rebooted the watch and HR is back but I noticed the watch face, while the correct style, had reset its complications and highlight colour. I just thought it worth mentioning that in case it was an indication of a corrupt config file or something.
                                      I am on the latest firmware and I’ve not had this issue before.
                                      tomclownfischT 1 Reply Last reply Reply Quote 0
                                      • tomclownfischT Offline
                                        tomclownfisch @far-blue
                                        I have to reboot from time to time. first the HR starts getting more and more inaccurately. Then it hangs on a fixed value for a time or jumps between to values - 129 an 68 for example in a yoga session last week. after rebooting the watch, it works fine again for a time (3 days to 3 weeks)
                                        https://www.allesnursport.de/
                                        • W Offline
                                          watwatch
                                          I am considering getting a Race S , is there are any positive reviews of users about ohr at rest and general movement . Don’t mind Hr strap for actual exercise .
                                          2 O 2 Replies Last reply Reply Quote 0
                                          • 2 Offline
                                            2b2bff Silver Members @watwatch
                                            @watwatch I think it is usable for everyday tracking…
                                            If you wanna have a review for this, watch dc rainmaker… He was very positive about this.
                                            Suunto Race S
                                            Garmin Epix Pro
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
