    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Magene h603 pairing
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    12 Posts 5 Posters 4.2k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • daniels770441D Offline
      daniels770441
      Hello,I am a new user of a 9 peak pro and I want to pair with my magene h603 HR meter butt this is a no goπŸ₯Ί
      Are there here persons with this combination?
      Other with some pairing tips?
      The magene works perfectly with my wahoo roam2.
      Greetings from Belgium
      L 1 Reply Last reply Reply Quote 0
      • pilleusP Offline
        pilleus
        Make sure the h603 is not connected to the magene app before pairing it with the Suunto watch.
        https://www.instagram.com/moves.are.life/
        Suunto Vertical Black Lime
        Suunto 9 Peak Pro Black
        Suunto Spartan Ultra Stealth Titanium
        daniels770441D 1 Reply Last reply Reply Quote 1
          daniels770441 @pilleus
          @pilleus thanks for your reaction, putt in new battery and the pairing went ok.
          This app is not in use by me.
          Now when I putt the 9PP on my handlebar and I view my πŸ’“ with te widget It says: busy with measuring but nothing on the screen.
          going later this day on a walk with watch in pocket and the H603 on my chest. Hope that the device will record. Keep u posted.
          daniels770441D pilleusP 2 Replies Last reply Reply Quote 0
            daniels770441 @daniels770441
            Just back from a walk and still no πŸ’“ recorded. Downloaded the magene app to verify my firmware and I am one the latest v1.20.
            This app is also recording my πŸ’“.
            Checked with my wahoo and immediately I have a puls.
            Think my cheap device is beter than my expensive one😁
            • pilleusP Offline
              pilleus @daniels770441
              @daniels770441 said in Magene h603 pairing:
              Now when I putt the 9PP on my handlebar and I view my with te widget It says: busy with measuring but nothing on the screen.
              You have to start an activity and activate in the section sensors your h603. Then you can see your hr during a bike ride or walk.
              The widget is used by the hr sensor in the watch.
              • L Offline
                larrybbaker @daniels770441
                @daniels770441 make sure it is not paired with any other app or device. Go to the watch pairing menu and make sure you can pair it to the watch. If paired to the watch and turned on/active when you start an activity you should see the HR icon with a small block on either side. Has to be BT. Watch will not support ANT.
                Vertical Ti Solar
                Vertical 2
                Race 2
                iPhone 17 Pro
                daniels770441D 1 Reply Last reply Reply Quote 0
                  daniels770441 @larrybbaker
                  Hr sensor is connected and visible in the Suunto menu, itt picks up my πŸ’“ butt then nothing anymore. Did a walk with in the settings the HR sensor included butt no signal on the Suunto.
                  Installed the magene app and here works the device perfectly. Also on the wahoo.
                  Closed all the apps only Suunto and magene and no info on the display. Time to buy a Suunto heartbeat sensor a suppose 😏
                  AudaxjoeA 1 Reply Last reply Reply Quote 0
                  • AudaxjoeA Offline
                    Audaxjoe @daniels770441
                    @daniels770441 when you say β€œdid a walk”. Did you start an activity?
                    Photos may help but as mentioned above the belt is only used during an activity so if you are just checking HR on the widget the built in OHR will be used.
                    Suunto Vertical
                    Suunto 9 BARO
                    Garmin Fenix 3, 5
                    Suunto Vector
                      daniels770441 @Audaxjoe
                      @Audaxjoe yes did a recorded walk with in the settings HR monitor, put my watch in my pocket and no registration of the HR.
                      Next week I have a wahoo Tickr fit to use of a buddy of mine, hope this will work.
                      Greetings and happy New year
                      • Brad_OlwinB Offline
                        Brad_Olwin Moderator @daniels770441
                        @daniels770441 The only belt that has a memory function with Suunto watches is the Smartsensor Suunto sells. If the watch cannot detect BT signals from the belt it will not record.
                        Are you sure the watch is recognizing the belt. The HR symbol on the watch should not be just a heart but a heart symbol with a belt on either side.
                        Not this
                        Should look like this:
                        Vector/T6c/Vertical 2 Ti
                          daniels770441 @Brad_Olwin
                          @Brad_Olwin thanks for this advice, downgraded the software to previous version and then connected the Wahoo Tickr fit and this works like a charm.
                          Going tomorrow ( if the weather allows itπŸ˜‰) on a bike trip to check this setup out.
                          Did the downgrade because at night ( and sometimes overday) the HR stopped. With the previous version everything works fine.
                          Greetings from Belgium and thank you all for the support.
                          daniels770441D 1 Reply Last reply Reply Quote 2
                            Hello,
                            It works perfectly with my Wahoo Tickr fit so probably the magene HR band made an error.
                            Going to work with the wahoo then.
                            Thank you all for the support.
                            With your input, this post could be even better πŸ’—
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
