    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Open water swimming
    Scheduled Pinned Locked Moved Suunto Race
    16 Posts 8 Posters 3.2k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • K Offline
      karmazynowycukiereczek
      Why open water swim doesnt register any GPS track? Doesnt matter I use it on beach to test it, or I use it while crawl swimming?
      Will you repair this?
      Bike works very well.
      Running and hike also.
      EgikaE 1 Reply Last reply Reply Quote 1
      • EgikaE Offline
        Egika Platinum Member @karmazynowycukiereczek
        @karmazynowycukiereczek nothing to repair. It is working as designed.
        You can make sure to use the open water swimming sport mode and that inthe exercise settings GPS is on
        Then wait for the GPS arrow in the pre start screen to turn green. Your track will be recorded then.
        K S 2 Replies Last reply Reply Quote -1
        • K Offline
          karmazynowycukiereczek @Egika
          @Egika said in Open water swimming:
          @Egika Yes i am using it… and i am doing it… i read a lot topic, i am not only one person who have problems with that. It doesnt work even under my house, but bike work great.
          Danny polegD 1 Reply Last reply Reply Quote 1
          • S Offline
            Sta Rydziad @Egika
            @Egika I once waited 5 minutes and nothing. This is purely soft issue.
            • Z Offline
              zucchero
              I have the same issue with my Suunto Race S. No GPS recording for open water swimming. GPS recording for open water swimming is a must and should be fixed soon.
              GiPFELKiNDG 1 Reply Last reply Reply Quote 2
              • GiPFELKiNDG Offline
                GiPFELKiND Silver Members @zucchero
                @zucchero soon 😂😂😂
                If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                S 1 Reply Last reply Reply Quote 0
                • Danny polegD Online
                  Danny poleg Silver Members @karmazynowycukiereczek
                  @karmazynowycukiereczek Unfortunately, GPS does not receive signals underwater.
                  You need to make sure that you are swimming freestyle and when you reach a resting position, leave your hand with the watch out of the water on a buoy that you are swimming with.
                  K 1 Reply Last reply Reply Quote 1
                  • S Offline
                    Sta Rydziad @GiPFELKiND
                    @GiPFELKiND in my case, GPS doesn’ recive signals anywhere. Again, I switch the swimming mode on, waited for five minutes and went for a walk - nothing. Repeated the same distance but with walk mode on and it recorded the distance. So GPS works, swimming mode switches it off…
                    • K Offline
                      karmazynowycukiereczek @Danny poleg
                      @Danny-poleg yes i know, but i also make test not underwater but just walking…
                      • EgikaE Offline
                        Egika Platinum Member @Sta Rydziad
                        @Sta-Rydziad said in Open water swimming:
                        can you make sure that you select open water swimming?
                        In pool swimming GPS is supposed to be off.
                        Plus double check that in the training options of your open water swimming sport mode, battery mode is set to power and the GPS switch is on.
                        S 1 Reply Last reply Reply Quote 1
                        • S Offline
                          Sta Rydziad @Egika
                          @Egika I tried that, many times. I performed all kinds of resets, switched all off/on. Sometimes I get reading for 2 or 10 meters, and it’s off again.
                          • EgikaE Offline
                            @Sta-Rydziad maybe something is broken for your individual watch. Probably an issue with the antenna.
                            I suggest you contact service.
                            K 1 Reply Last reply Reply Quote 0
                            • K Offline
                              @Egika yes, antena is broken in open swim water mode, but in run, hike and bike works excellent 😛
                              • EgikaE Offline
                                @karmazynowycukiereczek antenna or something else.
                                My suggestion is the same: contce support. This is not a behavior by design…
                                • M Offline
                                  Marro
                                  Hi,
                                  Last Saturday I used Open Water Swimming mode for the first time and it failed to record my track as well.
                                  However, I did not get GPS fix before I started the activity. Why? When I was in the water some drops caused the touchscreen to swipe 😬 , and I had to reselect the activity once again. And it happened seconds before my race start, so I didn’t have time to wait for the fix. Can it be the reason?
                                  Once I got out of the water, the watch acquired GPS signal and recorded the rest ot my race (it was triathlon).
                                  Regards!
                                  gerasimosG 1 Reply Last reply Reply Quote 0
                                  • gerasimosG Offline
                                    gerasimos Bronze Member @Marro
                                    @Marro check this thread maybe help
                                    https://forum.suunto.com/topic/13279/open-water-gps-drifting
                                    Suunto Vertical Ti
                                    Suunto S9 gen1
                                    Suunto Ambit3 peak
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
