    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Problema altimeter
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    16 Posts 6 Posters 2.3k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • marcosM Offline
      marcos
      Hello good I have problems with my watch that every three times I have to adjust the altimeter and has not yet done 1 year will have warranty
      VoiGASV 1 Reply Last reply Reply Quote 0
      • VoiGASV Online
        VoiGAS Gold Members @marcos
        @marcos Did you use it starting an exercise or just as a display on the watch?
        If you start an exercise the altimeter will calibrate itself during the first 10 minutes or so.
        Without starting an exercise you have to calibrate it manually - that would be normal behaviour
        Race S
        Vertical Titanium Solar
        Ambit3 Vertical
        • flo7zF Offline
          flo7z Silver Members
          hello.
          I am also experiencing “big” altimeter changes (values changes from 490m - after calibration with the GPS . and then drops at 390m if I stay at the same altitude over 30 mins, without pressure changes - still 1021 hPa).
          I also noticed that the leevation gain during my workout has doubled for the same route, I believe since abou a month or two. Usually it would be 100m elevation gain and now it’s to 200m.
          As shown on the screenshot, there is a drop in the middle (from 551m to 417m, gray shaded curve) ; I took a break (auto pause on) and did not go high or down.Screenshot_20241224-140319.png I guess it’s the auto calibraiton with FusefdAlti that does its job after a few minutes ?
          But why the fluctuation when I stay at home jus after re-calibrating ?
          any idea about the reason for this stranfge beahvior ?
          I am using the S9PP with FW 2.37.48
          I checked the forum about this issue but could not find similar cases.
          thanks
          Florian
          Florian Z.
          Suunto 9 Peak Pro
          Suunto Wings
          Suunto D4
          Suunto Ambit 3 Peak
          flo7zF 1 Reply Last reply Reply Quote 0
          • flo7zF Offline
            flo7z Silver Members @flo7z
            @flo7z
            some pictures to illustrate the issue i am having (the pressure is correct, I checked the local weather app)
            the trend of pressure is overnight, so I slept in my bed, whs is the altitude doing these spikes ?
            Issues I am observing with workout are:
            Elevation gain is too high.
            Ascent and descent do not match anymore, 20% difference instead of a few percent before the issue started.
            For example, a trail run with 650 m ascend and 540 descent (it should match since it’s a loop) is corrected by Strava at 380m !
            Florian Z.
            Suunto 9 Peak Pro
            Suunto Wings
            Suunto D4
            Suunto Ambit 3 Peak
            • flo7zF Offline
              @flo7z
              I noticed that this issue started in early November.
              I checked the D+ against Strava and there is a clear difference (between the Suunto App and Strava), starting just after my 2-years warranty runs out…
              The issue is at the start of my activity, I have crazy values of altitude and then after 10 minutes it’s fine (see on picture attached, this is supposed to be flat). But this messes up the overall d+/d- calculation.
              Any suggestion on how to solve this ?
              I am going to contact support I guess.
              Florian Z.
              Suunto 9 Peak Pro
              Suunto Wings
              Suunto D4
              Suunto Ambit 3 Peak
              flo7zF A 2 Replies Last reply Reply Quote 0
              • flo7zF Offline
                @flo7z interesting to notice that by starting a second running workound just after finishing one, the issue is not happening.
                I am thinking it’s due to the FusedAlti that has still the proper altitude and the GPS signal was still active on my watch maybe ?
                Florian Z.
                Suunto 9 Peak Pro
                Suunto Wings
                Suunto D4
                Suunto Ambit 3 Peak
                • sartoricS Offline
                  sartoric Moderator
                  fusedalti needs 10 minutes to calibrate if the altitude is off.
                  try to wait a while in the activity screen before starting it.
                  anyway it should be applied retroactively
                  SVTS - 2.50.28
                  SSSWHR BARO Amber - 2.8.32
                  Samsung A5 2016 - Android 7.0
                  Suunto App Android 6.10.7 beta
                  Mff73M flo7zF 2 Replies Last reply Reply Quote 0
                  • Mff73M Offline
                    Mff73 @sartoric
                    @sartoric
                    Yes, it is the strange thing here : Fusedalti should have corrected beginning of altitude.
                    It looks like a very old behaviour 🙄
                    SSU (retired), SV1, SV2
                    Wife : S9PP
                    SA: Always the latest beta :)
                    Android + Galaxy S205G
                    • flo7zF Offline
                      flo7z Silver Members @sartoric
                      @sartoric my altimeter is always on and it’s going crazy even when I’m at home, doing nothing
                      Florian Z.
                      Suunto 9 Peak Pro
                      Suunto Wings
                      Suunto D4
                      Suunto Ambit 3 Peak
                      • A Offline
                        ademgassymov @flo7z
                        @flo7z
                        After you start moving in a running/trekking types of exercise auto mode of alti-baro starts to measure altitude with gps that’s why you start getting correct readings. If you stop or when you’re in time mode it switches to barometric altitude and there’re several factors which influence - sea level pressure reference, actual pressure and temperature. I noticed that in summer when there’s not much temperature difference readings are usually correct. But in winter in this mode altitude can change even when you pull the watch from under your down jacket sleeve and temperature on the sensor drops quickly.
                        Recently I had an issue when altimeter suddenly started rising up to 9000m while I was quickly descending from 3700 to 3400 after a 15 minutes stop.
                        flo7zF 2 Replies Last reply Reply Quote 1
                        • flo7zF Offline
                          flo7z Silver Members @ademgassymov
                          @ademgassymov
                          I noticed the same, depending if I have a glove or not it changes the altitude accuracy.
                          Same when I take a small break, the watch goes on auto pause and this changes the altitude even if I don’t move .
                          What is strange to me is that the altitude was fine during two years and now it starts to go crazy.
                          Florian Z.
                          Suunto 9 Peak Pro
                          Suunto Wings
                          Suunto D4
                          Suunto Ambit 3 Peak
                          • flo7zF Offline
                            @ademgassymov
                            I finally got a proper elevation gain on a trail run. I succeeded because I left my watch 10 minutes outside, about 5°C, before to start my run.
                            The temperature seems to influence the altitude calculation a lot.
                            Florian Z.
                            Suunto 9 Peak Pro
                            Suunto Wings
                            Suunto D4
                            Suunto Ambit 3 Peak
                            Mff73M 1 Reply Last reply Reply Quote 0
                            • Mff73M Offline
                              Mff73 @flo7z
                              @flo7z
                              it should not.
                              Altitude is correlated to sensor temperature, ok, but ascent/descent shouldn’t be influenced.
                              You might be facing a sensor issue (dirty or faulty).
                              Wife : S9PP
                              • flo7zF Offline
                                flo7z Silver Members @Mff73
                                @Mff73
                                I am sending it back to the Suunto repair center, after long discussions with the Support.
                                Will see.
                                Florian Z.
                                Suunto 9 Peak Pro
                                Suunto Wings
                                Suunto D4
                                Suunto Ambit 3 Peak
                                A 1 Reply Last reply Reply Quote 1
                                • flo7zF flo7z referenced this topic on
                                • A Offline
                                  ademgassymov @flo7z
                                  @flo7z
                                  So is your guarantee still on after 2 years?
                                  I switched altimeter profile to alti (gps) in exercises to actually eliminate barometer. It didn’t help much. Yes it doesn’t send me to 9000m but still does strange things like showing that I ascended 200m during trekking while I was only descending. It’s a pity because I was ready to give up on barometer but not altitude readings at all.
                                  • flo7zF Offline
                                    @ademgassymov
                                    Yeah seems so
                                    Florian Z.
                                    Suunto 9 Peak Pro
                                    Suunto Wings
                                    Suunto D4
                                    Suunto Ambit 3 Peak
                                    Register Login
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
