    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Zonesense difficult to understand
    Scheduled Pinned Locked Moved Suunto Race
    36 Posts 13 Posters 7.4k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Steven LimmerS Offline
      Steven Limmer
      Out of coincidence, does Zonesense only work for long, steady efforts? I do a lot of HIIT and Hyrox training, and I find that my feelings and regular BPM correlate, but Zonesense will show me as working mainly aerobically.
      Equipment: Suunto Race Titanium
      SA: Android (Beta)
      Stefano M64S 2 2 Replies Last reply Reply Quote 0
      • Stefano M64S Offline
        Stefano M64 Silver Members @Steven Limmer
        @Steven-Limmer said in Zonesense difficult to understand:
        that happens to me too (see my previous post)
        Suunto Vector . Vector HR . Core . Race & Race S
        • 2 Online
          2b2bff Gold Members @Steven Limmer
          Yes. ZoneSense needs about 2 minutes to catch up with reality.
          Suunto Race S
          Garmin Epix Pro
          • HonzaSH Offline
            HonzaS @Stefano M64
            @Stefano-M64 I have a similar experience. Big acceleration in the last kilometer and a drop in Zone sense.
            Suunto Vertical 2
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @HonzaS
              @Jan-Suchánek You are going downhill! I bet HR drops or does not change, this seems fine to me. This is a very short segment maybe a bit over 2 min or 3? Not what ZS is designed for. You can find a lot of information about ZS in the videos on this thread.
              Vector/T6c/Vertical 2 Ti
              HonzaSH Inge NallssonI 2 Replies Last reply Reply Quote 0
              • HonzaSH Offline
                HonzaS @Brad_Olwin
                @Brad_Olwin No, you’re wrong. This part was 400m long with 10m descent. Almost flat. My pace raised from 6:10 to 4:50 and my HR raised from 153 to 170 at the end of interval.
                Suunto Vertical 2
                • Inge NallssonI Offline
                  Inge Nallsson @Brad_Olwin
                  @Brad_Olwin Sorry for a bit off-topic but since you have so much experience with Suunto watches and the app, do you have any idea why my pace curves in the SA are so coarse? In the below screenshot I’ve set it up exactly like Jan’s shot (and this is on Android - which I think his is as well) with a 15 minutes window.
                  Granted that his pace scale is about twice my own, but that shouldn’t make such a difference. My pace data looks like it only have sporadic data points, but I’ve examined the .fit files and the ‘speed’ entries are logged every second and have normal variations.
                  I’ve never seen a finely plotted pace curve since I bought the Race S in Dec 2024.
                  Edit: The pace information while running, on the watch, is without any surprises and shows normal second variations. It’s just the graphs afterwards that lack definition, and frankly make them impossible to use for any insight as to what I actually did speed-wise:
                  Suunto Race S
                  • Ecki D.E Offline
                    Ecki D. Bronze Member
                    Those are results from some runs lately. Im not fit in the moment cause off a herniated disc. So no v2Omax at the moment. At the first picture it looks like zone sense has a negativ correlation to the HR but if you look at the other ones it looks more like the Zone Sense diagram is shifted to the left or to the right on the last picture.
                    Haven’t done a run after the latest update I think.
                    But maybe some with more insider oder sientific background can clarify this.
                    https://www.strava.com/athletes/37982563
                    https://www.instagram.com/macdev
                    Ecki D.E Brad_OlwinB 2 Replies Last reply Reply Quote 0
                    • Ecki D.E Offline
                      Ecki D. Bronze Member @Ecki D.
                      Here the “raw” data vizualized in runalyze for the first run (latest). I think the chart map better to each other. So maybe there is some kind of shift in the app.
                        @Jan-Suchánek So, I think ZS is working appropriately here. When you start the downhill run, ZS dips as does your HR. Continuing the downhill your HR rises faster at first and then less with a final rise before you reduce effort. ZS takes some time to respond as is well documented here and well documented in the videos. Your interval is quite short! A bit over 3 min?
                        During the initial drop in HR when you start downhill ZS decreases as expected, then as you continue to increase effort with a 1 to 2 min lag ZS then continually rises and peaks after you reduce effort, again consistent with how ZS works. So I see nothing wrong here.
                        You are expecting ZS to be HR or mirror HR and ZS does not do that. It is a calculation based on R-R. Your interval is very short and I as well as many others and Suunto state the ZS is not appropriate for short intervals.
                        I and others here have to keep repeating this point as well as repeat that ZS is not a proxy for HR. If you watch the videos you may get a better appreciation for how to employ ZS in your training.
                        HonzaSH 1 Reply Last reply Reply Quote 2
                          Brad_Olwin Moderator @Ecki D.
                          @Ecki-D ZS is not supposed to correlate with your HR, repeated often here! Watch the videos, the long ones.
                            Brad_Olwin Moderator @Inge Nallsson
                            @Inge-Nallsson Can’t help you here as I have iOS.
                            Inge NallssonI 1 Reply Last reply Reply Quote 0
                            • HonzaSH Offline
                              HonzaS @Brad_Olwin
                              @Brad_Olwin Thanks for Your time and answer! You’re right, the interval is short and the ZS seems to be affected with slowing down before it. I know, that it has nothing to do with HR. I used AlphaHRV before.
                              Suunto Vertical 2
                                @Brad_Olwin Did an experiment today by deliberately walking the first 30 seconds of a recovery run and the resulting pace graph became butter smooth even when zoomed in to a one minute window. Walking pace was ca 12:00/km and the fastest run pace 5:26/km.
                                This is a very strange app behaviour. Perhaps I should bring it up as a bug in the android section of this forum… But for now a ‘bug fix’ would be to end every run session with some 10 seconds of walking.
                                The below screenshot is of the first 15 minutes where both the walk and a pace increase are properly discernable:
                                Edit: Found a conversation about this in the ‘login-locked’ Android section from two weeks ago. Added my own comment today:
                                “Android - Bad plotting of Pace time graph”
                                https://forum.suunto.com/post/163977
                                Suunto Race S
                                  @Jan-Suchánek said in Zonesense difficult to understand:
                                  AlphaHRV uses a different method, don’t know if that is real time. Buried in Suunto info are peer-reviewed scientific papers on this subject. I have the pdfs and if anyone wants them PM me and I can send. I have attached them in posts in this thread as well. The science is solid and much more testing was done compared to what is reported here. Plus, I started testing this nearly a year ago so I have a fairly good idea of how my training/RPE and ZS match.
                                    @Inge-Nallsson Good, think this is an app issue and off topic here
                                    Register Login
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
