    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Zonesense difficult to understand
    Scheduled Pinned Locked Moved Suunto Race
    36 Posts 13 Posters 7.7k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • luke55L Offline
      luke55
      Hello,
      I just start using zonesense on the Race with a Smart sensor belt, and I don’t understand what I see.
      I did a 1h run at a relatively intense pace, given my age.
      The SA reports this run as VO2Max, which is what I usually get.
      Below the graph says that, based on DDFA, I spend 39’ in aerobic and just 4min in anaerobic, which I find very surprising.
      In the zone details, the SA says that zone 2 is from 114 to 122, zone 3 from 122 to 130, and zone 4 from 130 to 137.
      And the graphs shows that I was above 130bpm most of the time, therefore in zone 4 and 5
      So I understand that DDFA index and heartrate based analysis are reporting totally opposite results.
      Based on DDFA, it was aerobic effort, and based on heartrate, it was mostly VO2max.
      Which one shoult I trust ??, and why are they so different ?
      Thanks for clarifying.
      H Brad_OlwinB VoiGASV 3 Replies Last reply Reply Quote 0
      • H Offline
        halajos Bronze Member @luke55
        @luke55 those HR values for the zones look very low, how did you find your zones? Being fully aerobic under 130 BPM is quite valid.
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @luke55
          @luke55 As stated before, your zones are incorrect. How did you determine your HR zones? For your workout, AT threshold is somewhere between 130 and 140, you were at no time in VO2Max. My AT is 142 and LT 163. My VO2M from the watch is 48, test is 55. Below is a run yesterday with Zonesense. BTW I am 67. You can see my AT from Zonesene in numbers is 140 but from the graph that is about where I enter anaerobic zone.
          0d5104a7-2b14-4c4c-b192-065d8243c013-Screenshot 2024-09-30 at 12.29.29 PM.png
          e2e56ab9-7c01-4d91-b14c-d33c852fd6ca-Screenshot 2024-09-30 at 12.28.45 PM.png
          Vector/T6c/Vertical 2 Ti
          luke55L 3 Replies Last reply Reply Quote 1
          • luke55L Offline
            luke55 @Brad_Olwin
            @Brad_Olwin
            I let the default values for all sports in the watch settings.
            Given that my max HR value is 158 (I am 69), these zone values did not look abnormal to me, and they are coherent with how I feel during activities, for example, above 130, I am hardly able to speak fluently.
            BTW, in a previous run, in the zone screen, there was one value (125 in front of 122) in the 2nd column.
            But in the last run , no value at all, not sûre what that mean
            • VoiGASV Offline
              VoiGAS Gold Members @luke55
              @luke55 I have nearly the same situation. I pushed into VO2MAX ( based on heart rate and personal feeling) and Zonesense gave me a little bit anaerobic and no VO2MAX. Maybe it takes more workouts to calibrate, I only did two with HR Belt
              Race S
              Vertical Titanium Solar
              Ambit3 Vertical
              Eon Core
                @luke55 said in Zonesense difficult to understand:
                @Brad_Olwin
                OK, it will vary depending on the exercise and day. If sufficient data are present you will get a value, for example my Zonesense AT has varied from 130 or below to 148. That reflects how I am feeling that day based on stress or prior workouts with AT getting lower when you are fatigued. This is exactly the benefit of ZoneSense. So, you did not have a suggestion in your last workout. It appeared mostly high zone 2 with a bit of anaerobic so should have been moderate and not easy. I am solely using Zonesense now for my training and ignoring HR.
                  Brad_Olwin Moderator @VoiGAS
                  @VoiGAS Or you did not spend enough time near or above VO2M, which is hard to do. ZoneSense is not good for short ≤3 min intervals. I would use Power for those.
                  • luke55L Offline
                    luke55 @Brad_Olwin
                    @Brad_Olwin
                    Your max HR is quite high, how did you determine it ?
                    For me, I used the formula 220 minus age, and increased it a bit, which gave me 158.
                    Zone values computed by the watch derived from this value, this why you find them so low.
                    Given the sensations I have at 150 bpm, I can’t imagine trying to push higher, so a max HR of 158 seems reasonable for me.
                    For the moment, I just did two run with zonesense, first was very relax, 17Km in 2 hours, second was much more intensive, 10Km in 56mn.
                    Definitely, I did not have similar sensations , 2nd was much more difficult, but zonesense reports almost the same result, aerobic in 97% for the first, and 89% for the 2nd, which I find hard to trust!
                    ? AntoineA Brad_OlwinB 3 Replies Last reply Reply Quote 0
                    • ? Offline
                      A Former User @luke55
                      @luke55 I did two mountain bike rides (Sunday and Monday) of similar distance but of different difficulty.
                      Sunday was some punchy climbs which will spike my heart rate, Monday was mostly flat gravel.
                      Sunday
                      Monday
                      You can see that Sunday I was in anaerobic more than I was compared to Monday. That seems to correlate to the type of riding I was doing, and how winded I was.
                      • AntoineA Offline
                        Antoine Bronze Member @luke55
                        @Brad_Olwin
                        You can try this to define HR zones:
                        https://moncoachdetriathlon.com/ressources-gratuites/calculateur-frequence-cardiaque/
                        Just put your email and you will be able dowload an Excel file and pdf file to compute your HR zones.
                        Suunto vertical solar
                        Coros arm HRM / Suunto wing 2
                        Android A55 Samsung
                        Suunto App latest official update
                          @Brad_Olwin
                          My max is set 3-5 bpm higher than the highest HR I had during the prior year. Since my late 30’s and early 40’s my Max has dropped from the low to mid 190’s. I do not know what your baseline fitness is. I have been training and racing ultras for the last 13 years.
                          • AntoineA Offline
                            Quite strange for me also:
                            According to publication on facebook:
                            Suunto ZoneSense
                            🟢 Aerobic (green) – covering Z1–Z2
                            🟡 Anaerobic (yellow) – Z3–Z4
                            🔴 VO2max (red) – everything beyond anaerobic threshold (Z5).
                            For me SuuntoSens mesured:
                            151bpm for VO2max (provided by suuntosens)
                            140bpm for z3-24 (anaerobic) (provided by suuntosens)
                            But 170bpm during 13 minutes are considered in z3-z4 on SuuntoSens graph.
                            Over 140 is yellow : ok
                            But over 151 is not red: ko
                            Android A55 Samsung
                            VoiGASV 1 Reply Last reply Reply Quote 0
                            • VoiGASV Offline
                              VoiGAS Gold Members @Antoine
                              @Antoine Looks like Zonesense just takes the HR when entering a zone. In your case the two peaks were when your heartrate was rather low (so not really in sync).
                              If that really is the way it works, then its rather useless because it will be wrong due to lag or other effects.
                              For me Zonesense looks more like a Proove of Concept than an actual working feature…
                              Race S
                              Ambit3 Vertical
                              Eon Core
                              • A Offline
                                alebalbis
                                As far I understand, zonesense is based on HR variability between beats and and this can only be measured with a chest HR sensor (it measures milliseconds differences between beats).
                                According to Suunto/MoniCardi this variability correlates with the lactate concentration in the blood, so the DDFA index is a indirect measure of lactate.
                                If you look at the @Antoine graph above you can see that between 36’ and 48’ HR goes down but zonesense starts to show red peaks of VO2 max. This is because between 20’ and 36’ there was an intense activity and lactate started to accumulate rapidly.
                                Another example is in @Todd-Danielczyk graph, look at the end, HR goes down but zonesense shows that you are in VO2max, lactate is high and certainly Todd was exhausted at the end.
                                I have installed zonesense in my SR watch and I think this is a valuable tool but we need to get used to it.
                                ? 1 Reply Last reply Reply Quote 3
                                • ? Offline
                                  A Former User @alebalbis
                                  @alebalbis Spot on assessment of how Zonesense can be used.
                                  *also you are right, I was exhausted as I recovered from that one 😊
                                    @VoiGAS said in Zonesense difficult to understand:
                                    That is not how ZoneSense works. Have you watched the video? Have you read the peer-reviewed manuscripts published in scientific journals? Have you read the white paper? Please stop speculating on what you think is happening. Perhaps educate yourself instead of making statements that are completely incorrect. I have replied to you many times stating this is not a measure of HR, so have others. It is not meant to follow HR nor is the measurement based on HR. It is based on relationships between IBI and in this manuscript, has been tested far more scientifically than anyone on this forum including me is likely to do. You refuse to acknowledge this. I am fine with you being skeptical of using it but understand how the feature works prior to continuing to assume it is synced to HR!
                                    Kanniainen et al. - 2023 - Estimation of physiological exercise thresholds based on dynamical correlation properties of heart r.pdf
                                    1 Reply Last reply Reply Quote 9
                                    • Stefano M64S Offline
                                      Stefano M64 Silver Members
                                      Hi, I started using the ZS some months ago and I quite intrigued by this new kind of analysis of the HR data. However, I find difficult to understand the results I get. The following graphs refer to the cardio activities I usually performed at the gym: I wear the Suunto smart HR belt at home and walked to the gym and back, so the “real” activity is the central part where the HR goes up. I wonder why in my case the ZS seems to be nearly anticorrelated to the HR data, going usually down during the more intense part of the recorded activity. Maybe the initial part il too long or too easy to correctly trigger the ZS detection? Any hint?
                                      At least, over 16 similar activities, I got 3 times consistent determinations of the Aerobic Threshold (133, 136 and 137 bpm)
                                      Suunto Vector . Vector HR . Core . Race & Race S
                                      HonzaSH 1 Reply Last reply Reply Quote 0
                                      • luke55L Offline
                                        luke55 @Brad_Olwin
                                        @Brad_Olwin
                                        How did you determine your max HR, it seems quite high at 67 !!
                                        For me, I just applied the formula 220 minus age, and increased a bit the result, and all zone values computed by the watch are based on that, this is why they seem so low.
                                        luke55L Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                        • luke55L Offline
                                          luke55 @luke55
                                          @luke55 sorry, wrong post, cant delete
                                            @Brad_Olwin
                                            I add a few bpm to my max for the last few months. Last set of uphill intervals I did the max was 178 bpm three days ago. Been routinely hitting 177 on these so 180-183 is probably about right. That is how I determine my max.
                                            BTW I am 68 now.
                                            Using age calculations is a bad idea IMHO, they are usually way, way off.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
