    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    to buy or not to buy … a charging cable on AMAZ........
    Scheduled Pinned Locked Moved Suunto Race
    9 Posts 4 Posters 823 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Mister PYCM Offline
      Mister PYC Silver Members
      a Suunto charging cable on AMAZ…
      I would like to have a backup charging cable for my SUUNTO RACE watch in my professional satchel so when I travel I’m absolutelly sure that I will be able to refuel my watch even if I forget the original cable.
      Looking to SUUNTO web site I see almost always (this is the case currently) that the charging cable are out of stock …
      Looking to AMAZ… I can see some, also with a price divided by 2 …
      Now the question is … are they reliable ? will they not endanger the watch ? will you have bough such cable from here ?
      Please avoid easy answers such as “a copy does not worth the orignal” or “you take yoru own risks” but you personally what are you doing ???
      All is possible in IT
      Driven by you fear you stay on the ground, driven by your dreams you fly
      ? M 2 Replies Last reply Reply Quote 0
      • ? Offline
        A Former User @Mister PYC
        @Mister-PYC i bought the following one for a backup and it seems to work. Cable is longer so works well for my home set up.
        Charger Dock Intended for SUUNTO 9 Peak Pro & SUUNTO Vertical & SUUNTO Race, Race S & SUUNTO Ocean Portable Magnetic Replacement Charging Stand Adapter with USB Charging Cable Cord Accessories https://a.co/d/1rlCRdP
        I use the OEM with the shorter cable for travel
        Mister PYCM 1 Reply Last reply Reply Quote 0
          Mister PYC Silver Members @Guest
          @Todd-Danielczyk said in to buy or not to buy … a charging cable on AMAZ........:
          • M Offline
            MRC01 Bronze Member @Mister PYC
            @Mister-PYC I use a cable from Amazon, much cheaper than the Suunto OEM cable, and it’s longer. Works just fine.
            VoiGASV 1 Reply Last reply Reply Quote 0
            • VoiGASV Offline
              VoiGAS Silver Members @MRC01
              Did anyone find one with usb-c socket? This would be great…
              Race S
              Ambit3 Vertical
              • ? Offline
                A Former User @VoiGAS
                @VoiGAS I haven’t seen one but USB C to USB sockets are readily available if you need to convert.
                https://www.amazon.com/s?k=usb+c+to+usb+adapter&adgrpid=1331509144926209&hvadid=83219392544657&hvbmt=be&hvdev=c&hvlocphy=103315&hvnetw=o&hvqmt=e&hvtargid=kwd-83219665750629%3Aloc-190&hydadcr=18031_10521444&msclkid=7aa0b7c15cb5185dc7fdd0c14d6d05c2&tag=mh0b-20&ref=pd_sl_40kbzhcd27_e
                • VoiGASV Offline
                  VoiGAS Silver Members @Guest
                  @Todd-Danielczyk Thank you, I meant a charging pod without cable. But you are right it would also work with an attached cable plus adapter. Just a little bit more bulk - but not too much
                  Race S
                  Ambit3 Vertical
                  • ? Offline
                    @VoiGAS I haven’t found any other combination out there outside of this.
                    Using an adapter I can charge it off my phone if I needed to as long as I have the charging cable, but my Nitecore power bank has both USB A and USB C so I can charge the phone and watch in remote areas and would be the more common situation for me.
                    • VoiGASV Offline
                      @Todd-Danielczyk Great idea with the phone!
                      Race S
                      Ambit3 Vertical
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
