    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    EON Core Tank Pod Low battery warning?
    Scheduled Pinned Locked Moved EON
    5 Posts 3 Posters 1.7k Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • O Offline
      Odedco
      Hello, Is there a Tank Pod low battery warning any where, on the computer or on the Pod? In other words, Is there a way to know you are running out of battery?
      Or do you all (or anyone) just keep a battery replacing kit on hand at all times?
      Thanks
      ___Alejandro____ 1 Reply Last reply Reply Quote 1
      • ___Alejandro____ Offline
        ___Alejandro___ @Odedco
        @Odedco
        No, unfortunately, there is no low battery warning.
        https://www.suunto.com/en-gr/Support/Product-support/suunto_tank_pod/suunto_tank_pod/safety/pre-dive-safety-checks/
        See point 9. I changed mine when it stopped pairing with my EON steel. Fortunately, it’s fairly straight forward to change yourself.
        O 1 Reply Last reply Reply Quote 0
        • O Offline
          Odedco @___Alejandro___
          @Alejandro Thank you very much, Alejandro. Your answer actually sent me in the right way, to see that there is actually, or, supposed to be an indicator for the Pod’s battery level. I can’t check it right now because I’m not connected to air right now, but when going to “POD” on the computer it should show the Pod’s serial number, volume of air tank, and a symbol of a battery with approximately how much juice it still has… See here:
          https://www.suunto.com/Support/Product-support/suunto_tank_pod/suunto_tank_pod/pairing-and-unpairing/
          Look under ‘Pairing and Unpairing’ at Num. 4
          Thanks again.
            @Odedco Good find! Next time I’m connected to a tank I’ll check it out.
            J 1 Reply Last reply Reply Quote 0
            • J Offline
              jameslgarner @___Alejandro___
              While the POD battery level can be seen in the screen where you pair and unpair the POD, Suunto really should consider enhancing the EON to include (1) a warning capability for POD low battery levels and (2) configurable field to enable the POD battery level to be added to one of the EON screens.
              • First post
                Last post
              Suunto Terms | Privacy Policy
