SA - saved tracks: how to use them
Hello there!
I have a question about using SA saved tracks from S9PP.
I would like to run again a track in order to compare the performance. For that reason I saved the first track recorded and named it in order to use it.
Where I can find it in the app?
Do you know how to import it in the watch to use it as breadcrumb and, then, delete it once used and not needed anymore?
Thank you in advance for your time! -
@misu763 update: found it! Dear admins, you can close the post! Thank you!
B Brad_Olwin locked this topic on
B Brad_Olwin unlocked this topic on
Register Login
