    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Race - very strange map elevation for canoe route
    Scheduled Pinned Locked Moved Suunto Race
    11 Posts 4 Posters 1.1k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • mikekoski490M Offline
      mikekoski490 Bronze Member
      Hi,
      Any experiencing issues with making a route on ocean? The route I made is SA seems correct (zero elevation gain/loss for paddle route), but if I bring up the same route on Race shows a 29,000 meter loss for the same trip (on ocean). And I’m not submarining.
      Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
      Current: Suunto Race Ti
      Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
      Suunto App running on Google Pixel 8/Android 14
      mikekoski490M Mff73M 2 Replies Last reply Reply Quote 1
        mikekoski490 Bronze Member @mikekoski490
        @mikekoski490 Just did it again. 13k route on ocean from start to finish. Elevation gain 1200, descent 80. (?)
        surfboomerangS 1 Reply Last reply Reply Quote 0
        • Stefano M64S Offline
          Stefano M64 Silver Members
          on ocean there should be “sea” level fluctuations caused by long waves, but at the end ups and downs should give similar gain/loss values … and in any case 29’000 m is quite a lot!
          Suunto Vector . Vector HR . Core . Race & Race S
          • Mff73M Offline
            Mff73 @mikekoski490
            @mikekoski490
            i might guess (without knowing) that SA is displaying a logic ascent for a route according to sportsmode, but after that, while transfering such route to the watch, “real” altitudes might have been transfered with “real” altitude loss (thus deep abyssal ones 🙂 )
            Just a guess.
            Maybe exporting route gpx could show this theory ?🤔
            SSU (retired), SV1, SV2
            Wife : S9PP
            SA: Always the latest beta :)
            Android + Galaxy S205G
            • surfboomerangS Online
              surfboomerang @mikekoski490
              @mikekoski490 said in Race - very strange map elevation for canoe route:
              Is this measured by the device? Could it be that wind, water and/or jacket is influcening the pressure sensor?
              (https://forum.suunto.com/topic/11142/suunto-vertical-altitude-difference-problem/6)
              Suunto Vertical Titanium Solar
              OnePlus Nord 4
              mikekoski490M 1 Reply Last reply Reply Quote 1
                mikekoski490 Bronze Member @surfboomerang
                @surfboomerang Hi. Thanks all for the replies I appreciate it! I realized I may not have explained this correctly. This is about making a route in SA that is a paddling route on the ocean, to be used with the Suunto Race - not using the Suunto Ocean diving. 🙂
                For some reason, no matter how many times I try, SA is assigning huge elevation to my completely flat track on the ocean. At no point does my track touch or hit land and its in the middle of an ocean channel (13km). Just wierd. I cant seem to draw the route without SA adding elevation gain or loss.
                Here is a small example: I made a route starting about 50 meters from shore, to paddle to a small island 5kms away, with the route ending 50 meters from shore (the Twin island itself has a max altitude of 15 meters).
                Suunto shows my flat paddle route gaining 419m.
                Ive deleted my route that was a 13km paddle, but the first version of the route had me losing 29,000 meters. NOTE: Here is the same route (13km paddle) drawn in Strava showing as it should 0M elevation gain, so its definitely a glitch in SA route mapping and how it shows up in Suunto Race.
                Ive saved this version as a .gpx file and downloaded to my Suunto Race, and will likely use
                the route mapping in Strava going forward, as here is the same route drawn in SA, using the same parameters as Strava, showing an almost 1000m elevation gain. My only question is does SA do the same when elevation matters?:
                surfboomerangS Mff73M 2 Replies Last reply Reply Quote 0
                  @mikekoski490 No idea where the altitude information is coming from, but when I draw your route in SA I also get ascent values of approximately 1000m. When I draw the same route in plotaroute.com I get an ascent of 0m.
                  Both are using openstreetmap afaik.
                  OnePlus Nord 4
                  • Mff73M Offline
                    Mff73 @mikekoski490
                    @mikekoski490
                    I also try, and draw a route near French coast : 0m ascent or descent.
                    I extended it with a 27000km trip across oceans 😂, still 0m
                    Maybe some small areas have issues.
                    Wife : S9PP
                    mikekoski490M 2 Replies Last reply Reply Quote 0
                      mikekoski490 Bronze Member @Mff73
                      @Mff73 Huh. Wierd. Thanks!
                      mikekoski490M 1 Reply Last reply Reply Quote 0
                        @Mff73 I completely changed the location to another area, and same thing. Creating a route for a short paddle gives an elevation gain. The more I extend the map, the more elevation gain.
                          @mikekoski490 OH, and I just noticed. The .gpx map that I downloaded from Strava? The one that correctly provided 0m elevation gain or loss when I created the route in Strava? Here is how it converted to when I review the route in my Suunto Race:
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
