    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    No vibration
    Scheduled Pinned Locked Moved Suunto Race
    9 Posts 5 Posters 1.1k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • HoBartH Offline
      HoBart
      Hi there.
      I usually use the alarm just with vibration so I don‘t wake up my wife. Today the alarm didn‘t vibrate.
      I did not change any settings or did anything different as usual. Any ideas? What can I do?
      t6, Ambit, Traverse, Spartan Sport WHR, Suunto 7 (2 month! then sold it!, loved the watch but UI was pointless),Suunto 9, Garmin Fenix 6pro, Suunto 9 Peak Ti (it‘s a beauty), Garmin Epix Gen2, Suunto Race Ti
      Core Brushed Steel (Most beautiful watch ever)
      M EgikaE 2 Replies Last reply Reply Quote 0
      • M Offline
        Mattg576 @HoBart
        @HoBart did you have DND enabled as I found that vibration doesn’t work in any area with that enabled (even auto lap doesn’t vibrate if you start an activity with DND on).
        Race
        9 Peak
        Ambit 3 Peak
        Ambit 2R (sold)
        Suunto T3d (expired)
        • EgikaE Offline
          Egika Platinum Member @HoBart
          @Mattg576
          The alarm will sound and vibrate regardless of DND setting. Otherwise it would not be an alarm that wakes you up.
          @HoBart
          make sure you set the alarm sound and/or vibration in "Settings -> General -> Tones -> Alarm
          And also make sure your battery is not nearly empty. If the battery is below a certain percentage of charge, the vibration motor will be deactivated to save energy
          HoBartH M 2 Replies Last reply Reply Quote 0
          • HoBartH Offline
            HoBart @Egika
            @Egika yeah I think the empty battery was the issue. This morning it was at 3%. At what percentage does the Vibration turns off? Just to know for the next time….
            Brad_OlwinB 1 Reply Last reply Reply Quote 1
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @HoBart
              @HoBart below 10% you will likely lose vibration.
              Vector/T6c/Vertical 2 Ti
              HoBartH 1 Reply Last reply Reply Quote 0
              • HoBartH Offline
                HoBart @Brad_Olwin
                @Brad_Olwin Thank you. Good to know.
                • M Offline
                  Mattg576 @Egika
                  @Egika fair enough but DND does disable vibration in other ares & its caught me out before so I thought it was a valid comment…
                  Ps. I don’t use my watch as an alarm clock, my body clock takes care of that at 0500hrs every morning😠
                  Race
                  9 Peak
                  Ambit 3 Peak
                  Ambit 2R (sold)
                  Mff73M 1 Reply Last reply Reply Quote 0
                  • Mff73M Online
                    Mff73 @Mattg576
                    @Mattg576 said in No vibration:
                    Don’t you have an option to put your body in extended DND mode ? 😜
                    SSU (retired), SV1, SV2
                    Wife : S9PP
                    SA: Always the latest beta :)
                    Android + Galaxy S205G
                    M 1 Reply Last reply Reply Quote 1
                    • M Offline
                      Mattg576 @Mff73
                      @Mff73 said in No vibration:
                      Used to have it before the last update dropped but sadly not any more…
                      🏃I’ll get me coat😀
                      Race
                      9 Peak
                      Ambit 3 Peak
                      Ambit 2R (sold)
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
