Question about right charger
I’ve a small doubt about the correct charger for my SR/SRS: the provided cable is intended to connected to and USB-A port that usually outputs 5V, 0.5/1.0A.
What about using fast chargers used by recent smartphones, which can provide several different outputs?
For example, the charger of my Sony Xperia has: 5V/3000mA, 9V/2000mA, 12V/1500mA
Are they safe to be used? Is there any indication from Suunto?
Thanks! -
@gerasimos many thanks, I searched but didn’t spot that discussion
so, it should be safe, since the charger must provide 5V as default, unless the attached device asks for more
Register Login
