    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Problems After Software Update 03.07.
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    11 Posts 9 Posters 1.7k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • M Offline
      MichaelD55
      Hello,
      Since the last update of my Suunto 9 Peak pro, I can no longer switch between altitude, steps, sunset and training via touch on my watch face. What is the reason for this?
      Thank you very much
      isaziI Christian MuhmC 2 Replies Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @MichaelD55
        @MichaelD55 you can now customize the watch face with the complications that you want. Go to settings and customize.
        Blog: isazi's home
        • M Offline
          MartinaF
          Has anybody else problems after the Update with the step counter and the sleep tracking?
          Steps are not recorded correctly and the sleep does not get tracked correctly as well. My time frame for the sleep is from 8pm till 7am and it only records the sleep from midnight on (at least that’s what it seems to me), i have a small child and i’m awake a few times during the night. It was tracked correctly before the update…
          I walked for nearly an hour now through our house with the baby in the sling and it did record only 50 steps 😅
          pilleusP M K 3 Replies Last reply Reply Quote 0
          • pilleusP Offline
            pilleus @MartinaF
            @MartinaF
            Both features are working fine on my 9PP. May be a soft reset will bring back these features on your watch?
            https://www.instagram.com/moves.are.life/
            Suunto Vertical Black Lime
            Suunto 9 Peak Pro Black
            Suunto Spartan Ultra Stealth Titanium
            • M Offline
              maszop Bronze Member @MartinaF
              @MartinaF said in Problems After Software Update 03.07.:
              Maybe you don’t move your hand while doing it? The watch is on the hand, not the leg.
              Christian MuhmC 1 Reply Last reply Reply Quote 1
              • Christian MuhmC Offline
                Christian Muhm @maszop
                @MichaelD55 I have the exact same problems you described.
                Step counts are being done in jumps, sleep tracker is buggy, and step count doesn’t start right after wake up. It usually takes up to 10 minutes.
                Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                  Christian Muhm @MichaelD55
                  @MichaelD55 same problem with my watch.
                  Is it possible to perform a downgrade to an older SW version? I was happy with the last version.
                    Christian Muhm
                    After consulting support, I performed a HW reset. No change unfortunatley. Still steps are counted incorrectly. I hope Suunto is aware and considers a bug fix for the next SW release.
                      Dimitrios Kanellopoulos Community Manager @Christian Muhm
                      @Christian-Muhm it takes up to 10 mins but it will recursively add them if it detected you woke up
                      Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                      • K Offline
                        kt.nemeth @MartinaF
                        Hello,
                        Same problem occured to my 9PP after the software update. Incorrect steps registration and no sleep tracking at all. All went well before the update. Hope this issue will be solved fast.
                        • C Offline
                          cmiller6070
                          I have also been having issues with steps myself. I have a 9PP, and I was walking on my desk treadmill even walking for 2 hours at 1.0 (which should be 2 miles) I got 700 steps.
                          While I definitely think the improvements to not be as sensitive to every wrist flick is great, I think the scaling went a little too far where it will track accurately if I’m actually using gps or doing a jog and really moving my arms/motion.
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
