    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Sleep tracking dos not work after update
    Scheduled Pinned Locked Moved Suunto Vertical
    25 Posts 7 Posters 1.4k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • dreamer_D Offline
      dreamer_
      Hello,
      Today sleep tracking has not worked for me (It was working before the update). I’m one of those users whose HR is usually under 40bpm while sleeping
      The watch is saying this:
      But I have slept 6 hours. I have also not received the morning report.
      Can anyone check if it has the same issue after the update? I will track again this night (UTC+1)
      JosaipluJ 1 Reply Last reply Reply Quote 0
      • JosaipluJ Offline
        Josaiplu Bronze Member @dreamer_
        @dreamer_ Hi
        I just check and my tracking went fine, duration is spot on and I just got my report with the sleep score
        Maybe punctual issue ? Have a nice day
        dreamer_D 1 Reply Last reply Reply Quote 0
        • dreamer_D Offline
          dreamer_ @Josaiplu
          @Josaiplu It is very strange and in fact the first (and only) day since I have the watch that I have had this issue. It was fine before.
          What is your HR while sleeping? The changes are for those below 40. Thanks for the answer.
          • JosaipluJ Offline
            @dreamer_ My resting HR is 50-55 so could be linked to your range indeed
            • dreamer_D Offline
              dreamer_ @Josaiplu
              @Josaiplu the changes are from those who have 40 or less bpm. That is not your range.
              These are the proves that sleep did not work:
              The HR is tracked ok during the sleep. Here you can see the 6 hours of the sleep:
              That means that the HR meassurements are fine. HR was tracked during the sleep
              And here is the sleep report, which is broken:
              Todd DanielczykT 1 Reply Last reply Reply Quote 0
              • Todd DanielczykT Offline
                Todd Danielczyk Gold Members @dreamer_
                @dreamer_ mine seemed to be fine this morning.
                • dreamer_D Offline
                  dreamer_ @Todd Danielczyk
                  @Todd-Danielczyk The same I was telling @Josaiplu . The changes in firmware for sleep tracking are for those that have 40 bpm or less. That is not your case either.
                  • sartoricS Offline
                    sartoric Moderator
                    I got the same figures (41/38) in the app , that could be a funny coincidence or a bug 😁
                    In the watch 39/38
                    SVTS - 2.40.38
                    SSSWHR BARO Amber - 2.8.32
                    Samsung A5 2016 - Android 7.0
                    Samsung A33 2022 - Android 14 - One UI 6.1
                    Suunto App Android 5.3.5 beta
                    Suunto App IOs 2.46.0 (19453) beta on MBP M1
                    dreamer_D 1 Reply Last reply Reply Quote 1
                    • dreamer_D Offline
                      dreamer_ @sartoric
                      @sartoric in fact as you can see, I have 40/38 in my watch and 41/38 in the app. With your similar bmp, your sleep tracking was fine?
                      Thanks!
                      sartoricS 1 Reply Last reply Reply Quote 0
                      • sartoricS Offline
                        sartoric Moderator @dreamer_
                        @dreamer_
                        yep the tracking was fine, at least the duration of it.
                        SVTS - 2.40.38
                        • dreamer_D Offline
                          dreamer_ @sartoric
                          @sartoric I Will check again tonight for sure. If I have the issue again, I’d like to help giving my logs or whatever is needed.
                          Thanks
                          • I Offline
                            Iggge
                            Do a soft reset. Mine works just fine (almost every time)
                            • dreamer_D Offline
                              dreamer_ @Iggge
                              @Iggge It worked!! Today the tracking is just perfect.
                              My bpm are a bit higher today (I have an exam and I’m not sleeping as much as I should)
                              @sartoric today I have the same info in the watch and the app but in the app I see in the first capture a minimum of 40 and in the second a minimum of 39. The watch says 40
                              • dreamer_D Offline
                                dreamer_ @dreamer_
                                Today the sleep tracking was again not accurate, after the update. It is not that bad like the first night (which was totally wrong), but It did not track correctly the sleep.
                                So from 3 days, I have a very bad tracking, a good one (after reset) and a not good one.
                                The watch detects that I’m sleeping at 1:19am but as you can see in the HR data, that is not true.
                                These accuracy issues are only happening after the update. Everything was fine before the update. All that I know is that I’m in the HR affected range of the update.
                                ManueleM 1 Reply Last reply Reply Quote 1
                                • ManueleM Offline
                                  Manuele @dreamer_
                                  @dreamer_ Hi,
                                  I am in the HR range of the update too, and, for now, I did not experience major differences from before, it seems that it is more precise in the awake time. Still it is not perfect, and I wish they will solve the licensing deal to obtain sleep stages and nap detection
                                  Suunto Vertical Titanium Solar
                                  • dreamer_D Offline
                                    dreamer_ @Manuele
                                    @Manuele thanks for the report. I will check again tonight restarting the watch perhaps. There’s something there different. But these days, with an exam there, I’m also more nervous than usual.
                                    I hope they can solve those licesing issues too. At the end, the Vertical is the best watch of the brand and that should be sorted, if possible.
                                    • dreamer_D Offline
                                      dreamer_ @dreamer_
                                      Last two days sleep tracking has been pretty solid. It is not 100% accurate but is definitively better as those two days I reported.
                                      Btw. About that licensing issues, which is the problem exactly? The Race S seems to have the same algorythms as the Race has.
                                      Thanks
                                      Mff73M 1 Reply Last reply Reply Quote 0
                                      • Mff73M Offline
                                        Mff73 @dreamer_
                                        @dreamer_
                                        Interpolate for new watches.
                                        https://forum.suunto.com/post/131343
                                        Suunto Spartan Ultra (since 2016) FW: 2.8.24 (retired)
                                        Suunto Vertical all black
                                        Wife : S9PP
                                        SA: Always the latest beta :)
                                        Android 13, Galaxy S205G
                                        • dreamer_D Offline
                                          dreamer_ @Mff73
                                          @Mff73 thanks. Very interesting that feedback. So it’s just a matter of time.
                                          The only thing perhaps I don’t agree, is the strategy of keeping the (for now) worse algorythm just only in their best watch. I’m not sure if it’s fair for the people that bought the Vertical. But Suunto knows more those whys than us, of course.
                                          • Mff73M Offline
                                            Mff73 @dreamer_
                                            @dreamer_
                                            Read better 😉, maybe it is not only suunto wishes, but also some contractual constraints.
                                            No insights here, but if a model was designed and “negociated” with certain “licensed” feature, it might be difficult to do without (legally speaking).
                                            Wife : S9PP
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
