    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Dive planner
    Scheduled Pinned Locked Moved Suunto Ocean
    22 Posts 15 Posters 5.3k Views 16 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      diveman
      Hello all,
      I buoght the Ocean 3 days ago, and already dived with it.
      1. Its very visuall, and presents all most all the information about the dive. It will be great to add the option to edit the main view (scoba dive mod) like in other wattches/mods and also to add the option to use compass view with other data on the arc.
      2. After diving, how can I plan my next dive? Depth, time ext. Like in other dive computers , rest time and the next 2 dives…
      3. While I create structured workout - to add the option to repete evry day/2/3 days…every sunday wensday the next X weeks…
      Thx
      Brad_OlwinB ___Alejandro____ B 3 Replies Last reply Reply Quote 9
      • J Offline
        jfhensens
        Hello. I find this new Suunto watch amazing! However, the only reason I did not already buy it, is that I cannot find anywhere an info about the dive planning feature. Is it possible to have the watch compute the NDL based on chosen depth, considering the previous dive? Same with diving stops, can we estimate the TTS ? Thank you for your answer. 🙂
        1 Reply Last reply Reply Quote 7
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @diveman
          @diveman For a structured workout you can create one but do not assign a date. It will be then available any time you need it. For example, I have only about 5 different structured workouts. I design the core workout in the app. For example VO2Max intervals, mine are 3 min on, 3 min rest and vary in how many I do. So I set up only the interval workout in the app, make sure the workout is loaded and change number of intervals if necessary, run to where I want to start the intervals, start and finish then run back. I do not plan the warmup or cool down, those are easy to just perform.
          Alternatively, you can use a third party service and have all workouts delivered on specific days to the watch.
          Vector/T6c/Vertical 2 Ti
          • ___Alejandro____ Offline
            ___Alejandro___ @diveman
            @diveman For dive planning, can’t you use the DM5 software from Suunto?
            https://www.suunto.com/en-gr/Support/software-support/dm5/
            V 1 Reply Last reply Reply Quote 1
            • V Offline
              VasilisCY @___Alejandro___
              @Alejandro This is one of my questions. I just unpacked the watch and it seems to have a cable that is capable of only charging the watch. It only has 2 pins(USB needs 4). I’m going to open a new thread now asking about it.
              ___Alejandro____ 1 Reply Last reply Reply Quote 0
                ___Alejandro___ @VasilisCY
                @VasilisCY I think you will need to connect the DM5 software to your Suunto App, which will then sync to your dive computer. In other words, as far as I’m aware, there’s no direct connection between DM5 and your dive computer – your Suunto App is bridge between. Same for my Eon Steel.
                • A Offline
                  Adelynn
                  Hello everyone,
                  I have a suunto peak 9 right now, and I am also a instructor diver. I am then very interested to upgrade to a single watch + computer.
                  BUT I will only buy it if I can plan my dives. And I don’t speak of a workout schedule.
                  I speak of :
                  • I enter the depth and time I will be
                  • it gives me the NDL (no déco limit) or TTS (time to surface), number of decompression stops, time of each stop
                  • it considers my current N2 saturation from my precedent dives in case of successive dives.
                  I don’t have the DM5 software and online it does not say that it is compatible with the suunto ocean. Can we implement it on the App, and is it possible to have that feature of dive planner directly in the watch?
                  If not possible, I will be obliged to go to Garmin for a powerful dive watch 😥, while suunto has already so much to offer!
                  Kind regards,
                  Thank you.
                  D 1 Reply Last reply Reply Quote 6
                  • D Offline
                    diogao13 Bronze Member @Adelynn
                    @Adelynn I have an ocean. As a dive computer, I hope next firmware updates bring ocean close to main competitors.
                    Until there go for Tern TX, Teric, MK2 or MK3.
                    • D diogao13 referenced this topic on
                    • B Offline
                      Bart Vander Plaetse @diveman
                      Hi @diveman and all, I just bought my Ocean and used it a few times. I am absolutely dissapointed to see there is no dive planner… an essential element of a dive computer, so essential I unfortunately did not check for it when considering buying it. Except for that, kudos to Suunto, I like all the rest. I hope the compass function while diving will still be more upgraded, I now only see the heading…
                      Did anyone get an answer on the dive planner issue?
                      • H Offline
                        hijodelmar
                        I bought a new suunto ocean with Tank Pod, I was really happy when I did my frist dive with it, battery is cool and also the Oled screen is amazing, I can use my watch on the gym or when I workout, my surprise was when I discovered that there is no Dive Planner on it, having a Suunto Vyper and Suunto D5, how Suunto did removed this option? I’m desapointed about this feature as I do several dives a Day, I don’t use any dive panner on computer like the DM tool, many of us that are diving everyday doing 2-3 dives even in the recreative world this option is mandatory.
                        Suunto please add this option in your next update.
                        1 Reply Last reply Reply Quote 4
                        • MF_DiverM Offline
                          MF_Diver
                          Hi, I have just bought a Suunto Ocean as a long time Garmin user. Overall I think the watch is really cool and I like the fact that it combines outdoor and diving. That’s a big Plus.
                          However I was also irritated to find out that there is absolutely no planning feature in the Suunto Ocean, which is hard to accept for the flagship product. Especially since all the information is included on the watch anyway. This should not be too difficult to add. I really hope the software will be updated accordingly because with this defect it’s a big no go for my fellow diving colleagues, despite all the other nice features. At the end of the day a dive computer has to be functional and not just beautiful. Please do this upgrade !
                          And as a long time Garmin user, one small remark, I really miss the option to view my app data on a normal website on a normal computer…
                          Otherwise it’s a cool product and it performers well for the standard Diving features!
                          isaziI 1 Reply Last reply Reply Quote 0
                          • isaziI Offline
                            isazi Moderator @MF_Diver
                            @MF_Diver as far as I know, the (on watch) dive planner should come to the watch with Q4 2024 update
                            Blog: isazi's home
                            K 1 Reply Last reply Reply Quote 2
                            • MF_DiverM Offline
                              MF_Diver
                              Thx @isazi, I am glad to hear! That’s really the main feature this Dive computer needs. Can’t wait to see it!
                              • K Offline
                                KerrenL @isazi
                                @isazi when is the Q4 update likely to land?
                                • pavel.samokhaP Offline
                                  pavel.samokha
                                  Dive planner arrived with Q4 release https://forum.suunto.com/topic/12184/suunto-ocean-sw-update-2-38-42-2024-q4/2
                                  Opinions expressed are solely my own and do not express the views or opinions of my employer
                                  Redhat6R 1 Reply Last reply Reply Quote 1
                                  • Redhat6R Offline
                                    Redhat6 @pavel.samokha
                                    @pavel-samokha Yes, it’s nice. On the other hand, how do you plan your dive when using several gases? I have the impression that you can only plan with the use of a single active gas
                                    VoiGASV 1 Reply Last reply Reply Quote 1
                                    • VoiGASV Offline
                                      VoiGAS Gold Members @Redhat6
                                      @Redhat6 I think you input the gases you have and the dive planner tells you the depth to change from one to the other. At least thats what my Mares does, if I’m not mistaken (never used it so far)
                                      Race S
                                      Vertical Titanium Solar
                                      Ambit3 Vertical
                                      Redhat6R 1 Reply Last reply Reply Quote 0
                                      • D Offline
                                        The current NDL planner is very limited, with Suunto opting for the easy way out. It should allow users to plan consecutive dives using the watch or the app, and then transfer the data to the watch.
                                        Considering that the Suunto Ocean is a recreational dive computer, having a good dive planner is essential.
                                        Until we receive a better dive planner, I am using the free app “Diveplanner Tec & Rec” from the Play Store. Suunto could take inspiration from it.
                                        • Redhat6R Offline
                                          Redhat6 @VoiGAS
                                          @VoiGAS said in Dive planner:
                                          This is unfortunately not the case: I tried to prepare a dive with 3 gases, it only offers me to plan with the active gas, it does not give me the depths and gas change times
                                          • VoiGASV Offline
                                            @Redhat6 That doesn’t sound good and Unfortunatly the user manual of the Ocean is not updated to clarify it. Especially with multiple gases the planner would be useful… 🫤
                                            Maybe the Ocean was released a little too early
                                            Race S
                                            Ambit3 Vertical
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
