    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    FusedTrack works great - for 16 Minutes or 2,5km
    Scheduled Pinned Locked Moved Suunto 9 Peak
    31 Posts 5 Posters 5.1k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • VoiGASV Online
      VoiGAS Gold Members
      Hi,
      I have a Problem with FusedTrack. I am using my Peak 9 since nearly a year and it works great most of the day. Yesterday I tried FusedTrack the first time and it really worked great for the first 16 Minutes of the run. Then it just stopped, easy to see in the recordings because then it jumps from one GPS position to the next directly. Tried another run today on a different route, with the same behaviour
      On both runs I calibrated the compass before and waited for the GPS Signal. My firmware ist the latest
      Any ideas? I really like to use FusedTrack because it works really great
      Race S
      Vertical Titanium Solar
      Ambit3 Vertical
      Eon Core
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @VoiGAS
        @VoiGAS in the first 15 minutes the watch uses the performance mode, and moves to endurance/ultra/tour only after 15 minutes.
        Blog: isazi's home
        VoiGASV 2 Replies Last reply Reply Quote 0
        • VoiGASV Online
          VoiGAS Gold Members @isazi
          @isazi Thank you, thats why it works that good in the beginning. But this would mean that FusedTrack doesn’t work at all. Just GPS jumps from one point to the next
          I forgot to mention that I used the Custom Battery Mode with GPS Mode good. So maybe this doesn’t trigger FusedTrack? I don’t want to use Endurance or Ultra because it disables Wrist HR
          Edit: I have to correct myself, Wrist HR should work with Endurance. I will try it on the next run
          Race S
          Ambit3 Vertical
          Eon Core
          Mff73M 1 Reply Last reply Reply Quote 0
          • Mff73M Offline
            Mff73 @VoiGAS
            @VoiGAS
            Isn’t fused track only available for S9? Not for S9P or S9PP.
            SSU (retired), SV1, SV2
            Wife : S9PP
            SA: Always the latest beta :)
            Android + Galaxy S205G
            VoiGASV Łukasz SzmigielŁ 2 Replies Last reply Reply Quote 0
            • VoiGASV Online
              VoiGAS Gold Members @Mff73
              @Mff73 As far as I know it all the Suuntos since 9 have it - at least I hope so
              Race S
              Ambit3 Vertical
              Eon Core
              • Łukasz SzmigielŁ Offline
                Łukasz Szmigiel @Mff73
                @Mff73 1s fix for Endurance is available since 9PP. 9P should have FusedTrack as the original S9.
                S9PP 2.50.28
                • Mff73M Offline
                  Mff73 @VoiGAS
                  @VoiGAS
                  @Łukasz-Szmigiel
                  OK, my bad.
                  Wife : S9PP
                  • VoiGASV Online
                    @isazi Tried again in Endurance Mode, same behaviour: Only straight lines, no FusedTrack effect. I compared it to online reviews, there it is not perfect - but its doing something.
                    Could it be a defect? Compass works, at least in standalone mode
                    Race S
                    Ambit3 Vertical
                    Eon Core
                    Łukasz SzmigielŁ isaziI 2 Replies Last reply Reply Quote 0
                      Łukasz Szmigiel @VoiGAS
                      @VoiGAS did you register a normal run with Performance mode before? So that the watch got calibrated for your moves?
                      S9PP 2.50.28
                      VoiGASV 1 Reply Last reply Reply Quote 0
                      • VoiGASV Online
                        VoiGAS Gold Members @Łukasz Szmigiel
                        @Łukasz-Szmigiel Yes, a lot. Really strange
                        Race S
                        Ambit3 Vertical
                        Eon Core
                        • isaziI Offline
                          @VoiGAS and this is running right, not cycling?
                          Blog: isazi's home
                          VoiGASV 1 Reply Last reply Reply Quote 1
                          • VoiGASV Online
                            @isazi Yes, and I just counted the “jumps” in the track - it is just one position marker per minute, nothing in between 😞
                            I read the watch should request a compass calibration when Endurance mode is chosen. I never had a message like this
                            Race S
                            Ambit3 Vertical
                            Eon Core
                            • isaziI Offline
                              @VoiGAS did you already try to reboot your watch?
                              Blog: isazi's home
                              • VoiGASV Online
                                @isazi No, I will try that
                                Race S
                                Ambit3 Vertical
                                Eon Core
                                  Łukasz Szmigiel
                                  As far as I’m aware - this should always work for running activities in Endurance and Ultra if the watch has calibrated wrist movement to GPS, which typically takes one 15+ minutes run in Performance mode.
                                  @isazi, will such data get refreshed with only a soft-reset?
                                  S9PP 2.50.28
                                  • isaziI Offline
                                    isazi Moderator @Łukasz Szmigiel
                                    @Łukasz-Szmigiel I would say that a reboot is the first step, then maybe a factory reset could be necessary. Hopefully not.
                                    Blog: isazi's home
                                    VoiGASV 2 Replies Last reply Reply Quote 2
                                    • VoiGASV Online
                                      @isazi ok, so Soft Reset + AGPS Sync (then wait 15 Minutes) + 15 Minutes Performance Run to calibrate + Compass Calibration + Endurance Run is the way to go . This will be one of my most intense training weeks 😀
                                      Race S
                                      Ambit3 Vertical
                                      Eon Core
                                      Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 1
                                        @VoiGAS remember to sync the watch after soft reset and then wait 15 minutes in order for the watch to unpack the AGPS data.
                                        S9PP 2.50.28
                                        • VoiGASV Online
                                          VoiGAS Gold Members
                                          Soft Reset & Performance Run done, next Test on friday for FusedTrack. Funfact: Ray tested FusedTrack in a 10 Minute Run. Guess what - it worked great 😉
                                          https://analyze.dcrainmaker.com/#/public/1e2d78d0-2e27-4219-7a46-9e64e4526069
                                          Race S
                                          Ambit3 Vertical
                                          Eon Core
                                          • isaziI Offline
                                            @VoiGAS honestly not sure if the watch was doing 15 minutes of performance when in endurance mode at that time (2018, the time S9/S9B were introduced). As you can see from the track, the watch was not in performance mode.
                                            Blog: isazi's home
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
