    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Water temperature - how long will it take for correct temperature
    Scheduled Pinned Locked Moved Suunto Ocean
    28 Posts 10 Posters 7.7k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      Gosem Bronze Member
      Hi,
      I was wondering how the Ocean is measuring the water temperature?
      Is it similar to the Apple Watch Ultra with a second temperature sensor in the display? This would be much faster then with the normal sensor.
      I am asking because if jump into a cold river or lake will it immediately show and log the correct temperature?
      Would be grate and a reason to change from the fenix to the ocean … for me 🙂
      Many thanks for answering my question.
      tuxellaT G K Shane WatsonS Della GarryD 5 Replies Last reply Reply Quote 0
      • tuxellaT Offline
        tuxella Bronze Member @Gosem
        If this can help you, here is the temperature graph for an openwater swim in the sea which was 17°C
        (The air was around 20°C)
        Watch is a Suunto Vertical Titanium Solar, worn on the wrist.
        G 1 Reply Last reply Reply Quote 0
        • G Offline
          Gosem Bronze Member @tuxella
          @tuxella many thanks 🙂 … cool, that means around 10 seconds … that’s great
          sebchastangS 1 Reply Last reply Reply Quote 0
          • sebchastangS Online
            sebchastang Silver Members @Gosem
            @Gosem you should rather read 7 to 8 minutes
            Suunto Traverse
            G ___Alejandro____ 2 Replies Last reply Reply Quote 0
            • G Offline
              Gosem Bronze Member @sebchastang
              @sebchastang … ah ok! Thanks 🙈… but it is the Vertical, not the Ocean, perhaps the Ocean has other sensors
              • ___Alejandro____ Offline
                ___Alejandro___ @sebchastang
                Yes, looks like around 10 seconds to get the correct temperature reading (the entire swim was only 7 mins 57 seconds).
                  sebchastang Silver Members @___Alejandro___
                  @Alejandro My bad, sorry!
                  I thought 00:7’57 was the position of the cursor on the graph.
                  Suunto Traverse
                    @sebchastang 👍 No worries.
                    G 1 Reply Last reply Reply Quote -1
                    • G Offline
                      Gosem Bronze Member @___Alejandro___
                      @Alejandro … ok, so 10 seconds is correct 🙂
                      • tuxellaT Offline
                        Time is expressed as hours:minutes:seconds. The whole swim was around 40 minutes and the marker is at 7 minutes and 57 seconds.
                        G 1 Reply Last reply Reply Quote 1
                        • G Offline
                          @tuxella … thanks for clarifying 👍… do you know if this changed with the Suunto Ocean?
                            @sebchastang Seems you were correct after all! LOL
                            • G Offline
                              @Alejandro I am totally confused now 😂😂😂
                              Could anybody from Suunto answer my question if there is a second temperature sensor in the glass?
                              Thanks 🙂
                              • G Offline
                                Gosem Bronze Member @Gosem
                                @Gosem
                                Hi, could really nobody answer the sensor question?
                                Many thanks 🙂
                                K ___Alejandro____ 2 Replies Last reply Reply Quote 0
                                • K Offline
                                  Kramble @Gosem
                                  Sorry mistake, I thought you asked for time…
                                  Ambit 3 peak saphir
                                  Spartan Ultra (sold)
                                  S7 graphite copper
                                  S9 peak all black
                                  Vertical titanium green forest
                                  Wings
                                    ___Alejandro___ @Gosem
                                    @Gosem
                                    I’ve used a Suunto EON steel extensively for many years and the temp reading is stable within seconds as soon as you descend. If that is the only thing holding you back, then I think its safe to say that the temp recording on all Suunto dive computers is relatively “instant”. Hope this helps.
                                    Patrick Löffler 0P 1 Reply Last reply Reply Quote 0
                                    • Patrick Löffler 0P Offline
                                      Patrick Löffler 0 Bronze Member @___Alejandro___
                                      @Alejandro Now is the question if this super fast temperature pick up can be expected of the Ocean as well.
                                      Suunto Race, Vertical, Ocean, Race S
                                      Garmin Marq 2 Carbon (I know how stupid that is)
                                      Apple Watch Ultra
                                      ___Alejandro____ 1 Reply Last reply Reply Quote 1
                                        ___Alejandro___ @Patrick Löffler 0
                                        @Patrick-Löffler-0
                                        Yes I understand the question and, in the absence of a response from a SCUBA diver using the SO, I gave my answer based on my experience with an EON steel. Here’s another suggestion: buy it from Suunto direct and send it back for a full refund if it doesn’t meet your needs. Again, I hope this helps.
                                        Patrick Löffler 0P 1 Reply Last reply Reply Quote 1
                                          @Alejandro Apologies. 😊 I was excited by how fast it peaks up temperature based on your experience. So yes. Your experience definitely helps. My question was meant more like: would be so cool if the Ocean had the same capabilities.
                                          Apple Watch Ultra
                                          ___Alejandro____ 1 Reply Last reply Reply Quote 0
                                            @Patrick-Löffler-0
                                            As divers we learn that water is more stable than air in terms of temperature – not to mention that you will lose body heat about four times faster in the water than on dry land. In other words, it’s not that difficult for modern equipment to record fast, accurate temperature under the surface of the water. Hence I’m saying to the other guy just buy it and go diving… Then maybe he can tell us! 😁
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
