    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    cadans sensor bluetooth
    Scheduled Pinned Locked Moved Suunto Race
    7 Posts 3 Posters 819 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      andre 3sen
      I know that you can only connect a bike sensor to the suunto racer with Bluetooth.
      But wenn i try that , the connection is there but only for speed , not for cadans .
      I have to fill in de size off the wheel , but i don need it.
      When i try it to my garmin venu watch , he find it as cadans.
      Does some one have the answer.
      It a magene speed/cadans sensor , whwn the lights shines red it for cadans , when it leds green its for speed.
      At the bike it leds red.
      Whats the solution ?
      AudaxjoeA A isaziI 3 Replies Last reply Reply Quote 0
      • AudaxjoeA Offline
        Audaxjoe @andre 3sen
        @andre-3sen I am not sure what unit you are using but I have a cadence and Speed sensor and both values are recorded by the watch.
        You do need a combination unit, annoyingly Suunto only allow one bike pod connection.
        Suunto Vertical
        Suunto 9 BARO
        Garmin Fenix 3, 5
        Suunto Vector
        • A Offline
          andre 3sen @andre 3sen
          @andre-3sen thanks for the reply.
          I have a magene speed and cadence sensor.
          One with a red led for cadence , and one with a green led .
          And both Ant+ and bluetooth, i only use the one with de red led , for cadence , but the watch registrate it as a speedsensor. ( even as the red led )
          Its a pitty that suunto don’t have a compatible list for this kind of sensors.
          • A Offline
            andre 3sen
            what kind of unit are you using ?
            AudaxjoeA 1 Reply Last reply Reply Quote 0
            • AudaxjoeA Offline
              @andre-3sen I only have a cheap Amazon one. Can’t remember the make. I only use it on the indoor bike. And I hate using the indoor bike…
              I did need to input the wheel dimensions but in my experience this is totally normal with a wheel speed sensor.
              I don’t use it outdoors with GPS.
              Suunto Vertical
              Suunto 9 BARO
              Garmin Fenix 3, 5
              Suunto Vector
              • isaziI Offline
                isazi Moderator @andre 3sen
                @andre-3sen I had the same magene sensor but I gave it away, so cannot check (it was working when I had it).
                Blog: isazi's home
                • A Offline
                  andre 3sen @Audaxjoe
                  @Audaxjoe , Thanks.
                  De speed sensor led green and is speed and works.
                  De Cadance leds green and doesn"t connect .
                  Also wenn i change the batterie and the red leds goes green the same effect , no connection with the cadence.
                  So i gone a buy an other cadence sensor , hopes the garmin with blue tooth works.
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
