    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Position on map
    Scheduled Pinned Locked Moved Suunto Race
    4 Posts 3 Posters 555 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • luke55L Offline
      luke55
      Is there a way to have my actual position kept at the center of the map when following a trace ?
      I may be wrong but I think it worked this way with initial software
      Today it’s no longer the case and I have to manually move the map every mn to check I am still on the track.
      freeheelerF ? 2 Replies Last reply Reply Quote 0
      • freeheelerF Away
        freeheeler @luke55
        @luke55
        this happens when you move the map manually. just tap the centre of the map and it will be re-centred with your position
        living sideways
        1 Reply Last reply Reply Quote 4
        • ? Offline
          A Former User @luke55
          @luke55 If you leave the watch on the map screen with touch screen enabled, and you use a sweather, jacket, or anything like that, the sweater or jacket touching the watch screen will often trigger a “touch”, which makes the watch no longer keep you in the center of the map screen. Double tapping the screen with re-center you on the map screen again. The easiest thing might be to disable the touch screen if you are using a sweater or jacket while leaving the watch on the map screen.
          luke55L 1 Reply Last reply Reply Quote 0
          • luke55L Offline
            luke55 @Guest
            @neonix
            Thanks for your answer, it is effectively probably the case.
            • First post
              Last post
            Suunto Terms | Privacy Policy
