    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    HRV
    Scheduled Pinned Locked Moved Suunto Race
    39 Posts 21 Posters 9.7k Views 19 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • GiPFELKiNDG Offline
      GiPFELKiND Silver Members @mr.quality
      @mr-quality but what time suunto neasures the HRV? the first 4 hours from the sleep or the whole time from sleeping? No infos in the manual?!
      If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
      M 1 Reply Last reply Reply Quote 0
      • M Offline
        mr.quality @GiPFELKiND
        @GiPFELKiND According to the information directly in the app, the entire bedtime.
        • SuperFlo75S Offline
          SuperFlo75 Silver Members Bronze Member @mr.quality
          @mr-quality I just saw that RMSSD is used by Suunto, Polar, not sure by Garmin… Apple uses SDNN… but it seems that it is important that you compare the same test situation/setting… and I think that here are the differences
          Suunto Vertical 2 Titanium Sage
          Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
          Suunto Wing
          Suunto 9 Peak Pro Titanium (owns my wife now)
          Suunto Spartan Ultra
          SA iOS 3.12.0 (22937)
          Instagram @superflo75
          aslyszA 1 Reply Last reply Reply Quote 1
          • aslyszA Offline
            aslysz @SuperFlo75
            @SuperFlo75
            When you have S. Vertical on one hand and, for example, Garmin Tactix 7 Pro on the other - the difference in HRV is huge, e.g. Suunto shows 35 and Garmin shows 110 !!! (changing the hand, right or left, does not change anything). When in this case (i’m 44 y.o.) medical charts - age related - suggest readings approximate 35-45.
            Vertical Solar / Baro 9 Tit. … and in the past a lot of others Suunto dev. ;)
            SuperFlo75S EzioAuditoreE 2 Replies Last reply Reply Quote 0
              SuperFlo75 Silver Members Bronze Member @aslysz
              @aslysz Wow, the difference is huge! But if you look at the medical charts for your age… your value seems to be correct? If Garmin really uses RMSSD, your value seems to be too high? It‘s just my opinion, but I‘m orthopedist and not cardiologist 😂 Did you compare the trend of both watches? The trend of HRV should be comparable, that‘s what I expect. I only have my SV, so I cannot compare…
              Suunto Wing
              aslyszA 1 Reply Last reply Reply Quote 0
              • EzioAuditoreE Offline
                EzioAuditore Gold Members @aslysz
                @aslysz I tend to ignore the raw numbers and focus on the trends. Although yes Suunto gives me ~20ms and Apple/Garmin 40-60
                Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
                Suunto Wing
                1 Reply Last reply Reply Quote 4
                • M Offline
                  MKPotts Bronze Member
                  My S9PP - which I believe has the same sensor and presumably the same data collection and analysis protocols as the Race for HRV - has previously given the same HRV values as my Garmin watch (an Enduro).
                  I checked again last night after seeing this thread: Garmin 92ms; Suunto 90ms. Minimum HR was also within 1bpm.
                  During rest, sleep etc, I’ve never seen any meaningful difference between Suunto watches, Garmin watches or any other sensor for HR-based measurements. Whereas during exercise, Suunto wrist HR is generally unusable for me, with few exceptions. But my Garmin watch is barely any better in this respect, I just use an external sensor.
                  Garmin mention in this article the difficulty with comparing HRV values between devices that may use different methods of data collection and analysis: https://www.garmin.com/en-GB/garmin-technology/health-science/hrv-status/
                  Like any measurements of this nature, the extent to which this results in differences in summary values when using different protocols depends on the underlying data set. Perhaps these differences are less likely to be apparent with higher HRV values like mine and/or when HRV remains relatively stable during the measurement period.
                  • aslyszA Offline
                    aslysz @SuperFlo75
                    @SuperFlo75
                    It seems to me that my values ​​​​given by Suunto are consistent with most cards with averages of healthy people. The Garmin values ​​seem to be highly overestimated (when Suunto works, unfortunately the HRV measurement does not work at all), there are no such results in medical tests. I’m attaching some of the collected preview material 🙂
                    @EzioAuditore
                    I guess you’re right, trends and deviations may indeed be the most important.
                    @MKPotts
                    It’s the first time I read and see that these measurements are so consistent! I wonder why they are there for you and not for us (see above)?
                    EzioAuditoreE M 2 Replies Last reply Reply Quote 2
                      @aslysz if not medically approved device (none of the sports watches are) than we should not look for the reason I guess. It may be a lot of reasons. I.e: I see more light bleeding of the sensor on suunto than on the Ultra even though the Ultra is more loose, wearing it on left hand vs right hand also causes differences.
                      What I’ve always been able to correlate is the trend. If I am sick or too tired or beer it goes down. Much rested it goes up.
                      Now is my pre race week where I rest more and recover and the hrv is above my normal values
                      Suunto Wing
                      ? 1 Reply Last reply Reply Quote 1
                      • ? Offline
                        A Former User @EzioAuditore
                        @EzioAuditore that’s how I’ve been using it.
                        Paying attention to the trends, run down, travel/ stress etc.
                        For example march was a combination of work travel, being sick and an injury. Trends picked it up. Now that the weather is better I’m doing longer exercises, eating cleaner and (what I find most important) staying hydrated.
                        • M Offline
                          MKPotts Bronze Member @aslysz
                          @aslysz
                          I don’t know why they match for me, I’d be speculating. It’s the opposite when exercising, all wrist sensors are bad for me but Suunto ones in particular.
                          Like the others, I just look at trends in HRV. For this, I find the scatter plot that Garmin uses better for seeing trends than the way Suunto presents it.
                          More generally than this, I find resting heart rate a better indication of recovery, impending illness etc than HRV and all watches I’ve had with wrist sensors measure that accurately.
                          • aslyszA Offline
                            aslysz @MKPotts
                            Ok!
                            Maybe you’re right, trends count.
                            The question remains why Suuntos do not measure HRV so often (despite the correct settings - often does not measure for weeks to measure 3 days in a row) - it is difficult for me to say whether it is a software defect or hardware failure?
                            Maybe someone knows better?
                            • ? Offline
                              A Former User @aslysz
                              @aslysz just so I understand, you don’t get an HRV value every time your sync after waking up? For me I’ll get a measurement and value every time as well as blood oxygen (24/7 HR and blood oxygen are turned on)
                              Example from last night
                              It could be hardware or the way you watch is sitting on your wrist while your sleep. If you are not wearing it above your wrist bone (2 cm above your wrist) and snug you may want to try that to see is it helps.
                              • SportsfreundS Offline
                                Sportsfreund Bronze Member @mr.quality
                                @mr-quality said in HRV:
                                @cjanevate said in HRV:
                                @szaboat74 Overnight HRV measurements for me are not optimal for many reasons, so I don’t trust these values at all (whatever the brand, of course).
                                A parallel comparison with Garmin and Polar shows that the measurement of Suunto is wrong. The sensors of Suunto seems to be outdated.
                                Mir zeigt meine Vertical auch ganz andere Werte an als mein Suunto Gurt per HRV App sowie eine medizinische Messung.
                                Meine Vertical zeigt ca die Hälfte des Wertes den meine Suunto Gurt und der Arzt misst.
                                • Stefan KerstingS Offline
                                  Stefan Kersting Platinum Member
                                  I have a SV1 and noticed a thing concerning HRV. The last weeks I slept not that good and less hours than usually. I noticed that the shorter the night the higher the HRV (about 80 with 5 hours of sleep). When sleeping about 7,5 hours it is ca. 60 even if I feel me good after 7-8 hours sleeping. Is there a correlation?
                                  Instagram: https://www.instagram.com/helgelandsbukken/
                                  https://www.instagram.com/suunto_adventures/
                                  IG: Helgelandsbukken, suunto_adventures
                                  Vimeo: vimeo.com/helgelandsbukken
                                  Blogg: https://turblogg.midnattsola.com
                                  R 1 Reply Last reply Reply Quote 0
                                  • R Offline
                                    runyx17 @Stefan Kersting
                                    @Stefan-Kersting Yes, I noticed that on my SV2 too. The shorter the sleep, the higher the HRV. Strange.
                                    Suunto: Ambit 3, Spartan, Vertical 2
                                    Garmin: FR 405, 935, 970 , Fenix 3, 6X, Epix2 Pro
                                    Stefan KerstingS pilleusP 2 Replies Last reply Reply Quote 1
                                      Stefan Kersting Platinum Member @runyx17
                                      @runyx17 so I am not alone. weird… Should think that enough sleep is positive for the HRV
                                      • pilleusP Offline
                                        pilleus @runyx17
                                        @runyx17
                                        Other brands use only the first 4 hours of the sleep to determine the hrv. May be to compare always the identical time of sleep?
                                        https://www.instagram.com/moves.are.life/
                                        Suunto Vertical Black Lime
                                        Suunto 9 Peak Pro Black
                                        Suunto Spartan Ultra Stealth Titanium
                                        E 1 Reply Last reply Reply Quote 0
                                        • E Online
                                          elbee @pilleus
                                          The models of garmin that are testen in a scientific way (not by some sport gadget blogger) shows that hrv isn’t that accurate on those models. (See https://the5krunner.com/2026/05/05/forerunner-265-hrv-study/ , links to sources on that page)
                                          I have no reason to believe other models or other brands are more accurate.
                                          Suunto t3c | Suunto Ambit 3 sport | Tomtom runner 2 | Garmin forerunner 935 | Garmin forerunner 965 | Suunto race s
                                          Stryd | Bryton Gardia R300L | Polar H9 | Polar oh1+ | Wahoo bolt v2 | 4iiii precision 3
                                          Register Login
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
