    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Issues with power meter
    Scheduled Pinned Locked Moved Suunto Race
    13 Posts 8 Posters 2.4k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Dawid WnukowskiD Offline
      Dawid Wnukowski
      Hello,
      I’m quite happy owner of Suunto Race (for almost 2 weeks). Unfortunately, I have a major issue connecting with a power meter. Pairing works smoothly but when I want to start the activity watch can’t connect to it and for that, it won’t receive data. Calibration in this case is also impossible of course…
      More information:
      • I double-checked that the sensor is enabled in activity settings
      • Inpeak power meter is able to send cadence data too. When pairing as Bike POD, cadence works nicely.
      • Soft reset is not helping.
      • Inpeak power meter works greatly with other devices (phone and cycling navigation device).
      I hope someone can help me, this is quite important to me.
      Mads Hintz-MadsenM 1 Reply Last reply Reply Quote 0
      • Mads Hintz-MadsenM Offline
        Mads Hintz-Madsen Silver Members @Dawid Wnukowski
        @Dawid-Wnukowski said in Issues with power meter:
        Hello,
        Do you have your power meter connected to a cycling computer (or phone) as well? If you do and the connection is using Bluetooth then the problem may be that your power meter only supports 1 Bluetooth connection. If your power meter and cycling computer also supports Ant+ then the solution is to use Ant+ for the power meter/cycling computer connection. The Race watch can then connect to your power meter using Bluetooth.
        If this is not your problem then I don’t have any idea what the issue may be.
        • S Online
          szleslie Bronze Member
          I have an issue with power reading using the Race and Inpeak V2 left arm power meter. It works but when I ride and raise my wrist to check the power value it shows zero. Then the power starts to increase gradually while reaches the actual value. It seems to me the watch does not show/calculate the 3s avg power and shows it on the display. Instead it starts averaging it after the display turns on. Of course I am pedalling when it happens.
          Does anyone have the same issue? It is not a huge one but it is time consuming to wait 3+ seconds to see the actual value. My Epix never did it with this Inpeak power meter. Checking the power graph it seems ok.
          N 1 Reply Last reply Reply Quote 0
          • N Online
            nseslija Bronze Member @szleslie
            @szleslie it is known issue after the last firmware update. We can just wait for the fix…
            Ambit 2S
            Ambit 3 Peak
            Suunto 9 baro
            Suunto Vertical Ti Solar
            S 1 Reply Last reply Reply Quote 1
            • S Online
              szleslie Bronze Member @nseslija
              @nseslija Thx for the info.👍
              • Steven LimmerS Offline
                Steven Limmer
                I’ve had consistent issues with power when indoor cycling. I use Assioma single-side pedals, and although they’re several years old, they’re very reliable.
                What I experience is frequent power resets when maintaining a consistent cadence. I’ll be spinning around 90 rpm, power will be reading as normal, then drops off to 0, and then takes 3 seconds (as that’s what i’m using to display power) to get back to the correct power value. It happens approximately every minute.
                I haven’t the pedals connected to anything other than my watch - I don’t use a headunit or anything like Zwift. I’ve never seen this with any other Suunto watch, or with previous head unit (Wahoo Bolt)
                Equipment: Suunto Race Titanium
                SA: Android (Beta)
                • N Online
                  nseslija Bronze Member @Steven Limmer
                  @Steven-Limmer Hi, it is a known issue discussed in other threads.
                  Ambit 2S
                  Ambit 3 Peak
                  Suunto 9 baro
                  • isaziI Offline
                    isazi Moderator
                    A new firmware release should be imminent, let’s see if the issue is fixed (I have no power meters to test).
                    Blog: isazi's home
                    L VoiGASV 2 Replies Last reply Reply Quote 0
                    • L Offline
                      Likarnik Gold Members @isazi
                      @isazi I’ll test that on first day when update arrives 🙂
                      isaziI 1 Reply Last reply Reply Quote 0
                      • isaziI Offline
                        isazi Moderator @Likarnik
                        @Likarnik well, real soon as far as I know
                        Blog: isazi's home
                        VoiGASV 1 Reply Last reply Reply Quote 1
                        • VoiGASV Offline
                          VoiGAS Gold Members @isazi
                          @isazi It also happens with the inbuild power meter, at least on Race S. Just try a Run with Power Sports Mode and you should see the Value dropping every few minutes
                          Race S
                          Vertical Titanium Solar
                          Ambit3 Vertical
                          Eon Core
                          • VoiGASV Offline
                            @isazi Good to know, then I will wait for it instead of ordering the new Coros Nomad just based on frustration about this issue…
                            Race S
                            Ambit3 Vertical
                            Eon Core
                            • isaziI Offline
                              isazi Moderator @VoiGAS
                              @VoiGAS grass is always greener 😄
                              Blog: isazi's home
                              Register Login
                              • First post
                                Last post
                              Suunto Terms | Privacy Policy
