    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Race - satellite settings
    Scheduled Pinned Locked Moved Suunto Race
    27 Posts 11 Posters 6.4k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • dreamer_D Offline
      dreamer_ @Mff73
      @Mff73 and like to keep things simple. It is usually a good thing: https://en.m.wikipedia.org/wiki/KISS_principle , but that doesn’t mean that things could not be improved. The custom Mode and the only GPS is not only for Garmin, but Coros or Polar.
      The Vertix 2s (MIP display) lasts 118 hours with only GPS (73 hours all systems and 43 all+ dual band). The Vertical does not allow that option. So there’s a very big difference there. You can look further for every watch/brand to note that it seems there’s something missing here, and that others have. And again, we are not comparing battery. Suunto excels at that but that same configuration is missing when in others not, and that’s clearly a disadvantage that It could be fixed for sure
      Garmin Fenix 8 Solar 51mm, Suunto Run
      • Stefano M64S Offline
        Stefano M64 Silver Members @dreamer_
        @dreamer_ said in Suunto Race - satellite settings:
        @Stefano-M64 about that, it has also no sense at all. Both are basically the same watch with a different screen. It is more like something has been forgotten there, like a “bug”
        maybe it’s just a commercial choice since Vertical was nearly twice the price of Race, so more customizations are bonus features.
        Suunto Vector . Vector HR . Core . Race & Race S
        • dreamer_D Offline
          dreamer_ @Stefano M64
          @Stefano-M64 about the custom mode, I have read that all battery modes that are not performance, disables the maps by default. But you can use the custom mode with you preferences and maps enabled. So removing that mode, created an issue for the Race (an issue that the Vertical does not have).
          So there’s an important thing here. Considering those 65/90h battery durations, I think that the custom mode should be enabled (as it is in the Vertical) so we can have at least the same workaround for the Race.
          @isazi.
          If I want to do a long walk or a run I should be able to maximize battery while having navigation. Navigation is specially important when you are working long.
          Perhaps it should be reported, if possible. To make a fix for the Race here and have both firmwares paired as much as possible. It’s Suunto’s code, with my total ignorance of that code and with both watches with similar software, perhaps we are lucky with things like this one.
          I can imagine that perhaps enabling this fix for the custom mode, it’s just a copy of the missing lines. And it’s another thing for the watch, which is always good, of course.
          • HonzaSH Offline
            HonzaS @TrailEyes
            @TrailEyes
            Ultra mode in Race seems that is not recorded with 1s interval, but about 2 seconds. At least according to intervals.icu which give me that info for Ultra mode test activity…
            I was surprised, that I can´t turn map on with other modes than Performance.
            Suunto Vertical 2
            TieutieuT Brad_OlwinB 2 Replies Last reply Reply Quote 0
            • TieutieuT Offline
              Tieutieu Platinum Member @HonzaS
              @Jan-Suchánek about maps available only on performance mode on SR and SRs, it’s been explained few times : battery consumption with map on is too high to provide battery life expected on other modes.
              Suunto’s devices at home :
              Vertical titanium solar
              Suunto Race S
              S9pp titanium sand
              Suunto Wing & Spark
              S9B titanium Ambassador edition, A3P, X6
              HonzaSH 1 Reply Last reply Reply Quote 0
              • HonzaSH Offline
                HonzaS @Tieutieu
                @Tieutieu
                Yes, I know that. I can surely live with that. The battery life in Performance mode is still much better than best setting in F7Pro…
                Suunto Vertical 2
                • Brad_OlwinB Offline
                  Brad_Olwin Moderator @HonzaS
                  @Jan-Suchánek There is power management in Ultra mode with the GPS chip so the recording interval will likely vary depending on the connection. The GPS fix will try every second but every second may not be recorded.
                  Vector/T6c/Vertical 2 Ti
                  Register Login
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
