    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Battery draining too quickly
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    11 Posts 6 Posters 2.8k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • R Offline
      ruisg
      After the last software update, the battery is draining very quickly. I charged the battery yesterday (100%) and today it is already at 69%! How to solve this problem?
      ? freeheelerF ? C 4 Replies Last reply Reply Quote 1
      • ? Offline
        A Former User @ruisg
        @ruisg you may want to do a battery recalibration. After a firmware update battery drain is common so discharging completely until charge icon shoes up and then charging to 100% will reset the battery consumption.
        https://forum.suunto.com/post/95333
        R 1 Reply Last reply Reply Quote 0
        • freeheelerF Away
          freeheeler @ruisg
          @ruisg
          please double check screen backlight settings, too
          living sideways
          • ? Offline
            @ruisg S9PP here as well and I do not see any regression on battery
            • R Offline
              ruisg @Guest
              @cjanevate Good for you.
              • R Offline
                ruisg @freeheeler
                @freeheeler Thanks for your suggestion.
                • R Offline
                  ruisg @Guest
                  @Todd-Danielczyk I didn’t know about this battery calibration procedure. I will try this procedure. I just hope I don’t run out of 0% battery on the mountain trail! 🙂
                  sartoricS 1 Reply Last reply Reply Quote 0
                  • sartoricS Offline
                    sartoric Moderator @ruisg
                    @ruisg
                    Do not drain it completely, around 2% you should get an alert to charge it and no more watchface. Do it 😉
                    SVTS - 2.50.28
                    SSSWHR BARO Amber - 2.8.32
                    Samsung A5 2016 - Android 7.0
                    Suunto App Android 6.8.9 beta
                    • ? Offline
                      A Former User @sartoric
                      @sartoric I completely forgot that the watch holds “some charge” (in this case 2%) and should have stated until the charge icon shows up.
                      Thanks for clarifying the percentages! 👍
                      • sartoricS Offline
                        sartoric Moderator @Guest
                        @Todd-Danielczyk
                        Should be 2% or 5% … anyway the icon shows up 😁
                        SVTS - 2.50.28
                        • C Offline
                          claenn @ruisg
                          @ruisg
                          Pls check airplane mode
                          I have to go into the settings, connectivity, to activate the airplane mode for real, and to cut the bluetooth connection to the iPhone.
                          But the airplane switch in the control panel has no effect. Regardless of whether you switch it on or off.
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
