    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Altitude and elevation issue
    Scheduled Pinned Locked Moved Suunto Race
    2 Posts 1 Posters 551 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Clément LavabreC Offline
      Clément Lavabre
      Hi !
      I have owned the Race since its release.
      Everything was fine until the update on December 18.
      That was before :Screenshot_20240216-091355~2.jpg
      Beautiful curves, with altitudes and elevation differences correctly calculated.
      I do not use the automatic pause, put it when I am stopped, the watch displays the same altitude and does not accumulate any elevation gain.
      Everything goes wrong after update 2.30.38.
      I no longer have correct altitude data, the altitude differences are exaggerated, sometimes even double the altitude difference calculated compared to real (real compared with a 9 peak pro and Garmin instinct, as well as the GPX track integrated in DEM.
      and
      And there is also a permanent “noise” of the signal which sees changes of rises and falls where there should be only rise or fall.
      I tried to calibrate the altitude at the start, but as soon as I calibrated it varies directly. Even in world shows the alti is not good and varies constantly.
      Is this a software problem? an accelerometer that is dead? the baro sensor?
      I tried soft-reset and hard-reset but it didn’t change anything.
      I hope this is just a bug, and will be fixed in the next update.
      What do you think of that?
      Clément LavabreC 1 Reply Last reply Reply Quote 0
        Clément Lavabre @Clément Lavabre
        @Clément-Lavabre It is obvious in this comparison, on one side the 9 baro and on the other the Race
        9 baro
        And Race
        In movement, the precision of the Race is correct, without being excellent. The 9 baro is very precise.
        It’s when it stops that it gets bad. We see the flatness of the curve on the 9 baro while the Race varies constantly.
        This is how I end up with a lot more elevation
        • Clément LavabreC Clément Lavabre referenced this topic on
        Register Login
        • First post
          Last post
        Suunto Terms | Privacy Policy
