    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 peak with polar verity sense
    Scheduled Pinned Locked Moved Suunto 9 Peak
    4 Posts 4 Posters 1.2k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • mtnsportsnutritionM Offline
      mtnsportsnutrition
      Using a polar verity sense paired with my Suunto 9 peak for better hr accuracy…if I change a field on my trail running screen to display heart rate, I know it will display the real time heart rate data coming from the Polar strap (even if I have the wrist based optical hr toggled off).
      But if I have the wrist based optical hr toggled off on the watch, the hr zone gauge (colored ring) on the watch remains dormant. If I toggle the wrist based optical hr on, it gives me readings on the colored hr zone gauge ring, but I think those readings are then coming from the watch’s optical sensors and not the polar verity.
      How can I get the hr gauge colored ring to reflect the polar verity’s current hr data?
      Also, when I then go to upload the run to the Suunto app is it pulling the hr data/ calorie data from my watch, or from the verity strap?
      TieutieuT 1 Reply Last reply Reply Quote 1
      • TieutieuT Online
        Tieutieu Platinum Member @mtnsportsnutrition
        @mtnsportsnutrition you can only mesure hr through one device a the time (belt or ohr), and you can’t change during an exercice.
        Be sure to wear your strap belt defore launching exercice. Then the green heart showing HR sensor will have « little wings » (representing belt) if your belt is detected (it should be, it is prior to ohr). If ohr you have a simple heart.
        You don’t need to unpin ohr in exercice settings (if you don’t wear your belt, Ohr will then work for mesurement)
        So if you’ve recorded your exercice with your belt (I guess you’ve paired it properly with you watch), the HR data’s will be from you belt.
        You’ll that explanation in the utilisation guide.
        Suunto’s devices at home :
        Vertical titanium solar
        Suunto Race S
        S9pp titanium sand
        Suunto Wing
        S9B titanium Ambassador edition, A3P, X6
        • M Offline
          moreusernameftw
          Hello, sorry for the very late reply w/this but just trying to track down what to do w/my Verity Sense and my Suunto 9.
          Do i turn off wrist heart rate on teh watch first --> connect the Polar sensor --> start the trail run activity?
          Any clarification(s) is appreciated and thank you.
          M 1 Reply Last reply Reply Quote 0
          • M Offline
            MKPotts Bronze Member @moreusernameftw
            @moreusernameftw
            First you need to pair the Verity Sense to the watch. You can do this now, no need to wait until you’re ready to run/exercise.
            To pair the VS sensor, put it on your arm and turn it on. Then go through the settings/connectivity/pair sensor menus on your watch and select “pair HR sensor”. It’ll tell you to moisten the sensor, which you can obviously ignore for an optical sensor and click to the next step. The watch will then search for and pair to the sensor within a few seconds.
            When you want to run or whatever exercise using the VS sensor, put it on, turn it on and then go to the exercise start menu in the watch. The watch will automatically connect to the VS, overriding the watch wrist sensor (no need to disable it). As above, you’ll know it’s connected because the heart symbol will have the little “wings” (belt). If you’re still not sure if it’s connected to the VS before you start running, take the watch off and check that the wrist sensor lights are off.
            • First post
              Last post
            Suunto Terms | Privacy Policy
