    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    UI lag
    Scheduled Pinned Locked Moved Suunto Race
    11 Posts 9 Posters 2.1k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      savvase
      I am in the market for a new sport watch and i really like the suunto race but i have watch the review on YouTube from dc rainmaker and he is complaining about the overall UI lag is it really that bad or has been fixed with software updates thanks.
      TieutieuT General_WittG vjakubV 3 Replies Last reply Reply Quote 0
      • TieutieuT Offline
        Tieutieu Platinum Member @savvase
        @savvase unless if you intend to spend all your time navigating into menus (and even then), you can serenely go for the Race.
        I still don’t get why reviewers point something that is clearly not very perceptible to my mind, as if it was turning the watch useless…
        Look at maps reactivity compare to other brands (several videos online) and you will see what a laggy use means !
        Suunto’s devices at home :
        Vertical titanium solar
        Suunto Race S
        S9pp titanium sand
        Suunto Wing & Spark
        S9B titanium Ambassador edition, A3P, X6
        L 1 Reply Last reply Reply Quote 11
        • General_WittG Offline
          General_Witt @savvase
          @savvase Lag has been reduced with the latest update but it wasn’t that bad even before.
          There are a bunch of latest gen phone users who expect the same responsiveness in every device they use.
          I prefer a good compromise between battery duration and UI performance than a super speedy UI that I can frantically browse at the expense of some hours of battery duration.
          GiPFELKiNDG 1 Reply Last reply Reply Quote 5
          • GiPFELKiNDG Offline
            GiPFELKiND Silver Members @General_Witt
            @General_Witt the “lag” is maximal reduced when you Turn Off the Vibration Feedback from the digital crown! 👍Try this
            If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
            David lD 1 Reply Last reply Reply Quote 2
            • L Online
              larrybbaker @Tieutieu
              @Tieutieu Exactly!
              Vertical Ti Solar
              Vertical 2
              Race 2
              iPhone 17 Pro
              • T Offline
                TitaniumDave Bronze Member
                Unless you really need it, turn off the vibration and beeps when you use the crown and pushers. This will help since the OS is trying to time things with vibrations and beeps.
                • vjakubV Offline
                  vjakub @savvase
                  @savvase This was my concern when buying SR two months ago. I agree with others - I also wouldn’t point it out as an issue.
                  • David lD Offline
                    David l @GiPFELKiND
                    @GiPFELKiND said in UI lag:
                    If you do that, will it then not vibrate exercising with laps etc?
                    Cheers
                    • S Offline
                      savvase
                      Thank you all for your feedback I am between two watches the garmin forerunner 965 and the suunto race the garmin offers a lot more features (contact less payments, off-line music using Spotify and the ability to choose whatever watch face you want) but i like the looks of the suunto more so probably i am getting the suunto.
                      vjakubV 1 Reply Last reply Reply Quote 2
                      • vjakubV Offline
                        vjakub @savvase
                        @savvase I came from Garmin world because I could hardly appreciate all the metrics that Garmin provides. As a example - it’s nice to know how many breaths I took but never really found it useful. Offline music sounds great unless you’re having here and there issues with scratching sound in your earphones or playback in general. Nevertheless if you fancy neardy-like metrics and custom watch-faces, Garmin is the way to go. Suunto is a bit more on the feeling note but with excellent elevation amd GPS tracking. Either way good luck!
                        1 Reply Last reply Reply Quote 3
                        • Brad_OlwinB Offline
                          Brad_Olwin Moderator @David l
                          @David-l You can turn just the buttons off, I don’t like the buttons reacting anyway so I have both tones and vibration for buttons off.
                          Vector/T6c/Vertical 2 Ti
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
